go_a_way1
Old 11-18-2013, 01:32 PM   #2549
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hmmm. I don't think mine is engaging. And Im pretty sure it was engaging before. I think I need to blow the tube again.
Installed Mods:
Old 11-18-2013, 01:44 PM   #2550
Robftss
Drives: VW
-Car off.
-Arm system.
-pull 1/8" tube off intake brass port.
- Simulate vacuum, suck on 1/8 tube, compressor will activate. blow to de-activate.
Robftss is offline   Reply With Quote
Old 11-18-2013, 01:53 PM   #2551
Sojhinn
Sojhinn's Avatar
Originally Posted by Robftss View Post
-Car off.
-Arm system.
Not working.
Installed Mods:
Old 11-18-2013, 02:01 PM   #2552
Sojhinn
Sojhinn's Avatar
Not working.
Also note full throttle activation is working fine.
Installed Mods:
Old 11-18-2013, 04:42 PM   #2553
Sojhinn
Sojhinn's Avatar
Tried every which way. Any ideas?
Installed Mods:
Old 11-18-2013, 09:34 PM   #2554
fenton
Something blocked in the hose?
Sorry I'm not sure what else unless the actual sensitivity needs to be raised in the controller itself. Rob should be able to walk you though it.
Sent from my Nexus 10 using Tapatalk
fenton is offline   Reply With Quote
Old 11-19-2013, 12:14 PM   #2555
Boosted69
Drives: New and Old POS
I have a question. All of this is based on a 24v or 28ah setup. would you be able to add additional voltage say bring it up to 36v?
Would that get you more rpm in the motor and thus a few more PSI?
I'm asking for future use. if I needed to make more boost with this system all in place. Or because the controller is 24v setup thats all you can run. I would have to change motor or compressor accordingly?
Boosted69 is offline   Reply With Quote
Old 11-19-2013, 12:57 PM   #2556
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'm not sure of all the specs of the phantom system, but most likey to operate at a higher voltage would require a different motor/controller/charger.
Also this system is pushing the limits of max RPM of these type of motors. As the motors get larger even though power goes up, max RPM generally goes down. One option would be to switch to a larger compressor with a larger motor turning at a lower RPM.
The Following User Says Thank You to neutron256 For This Useful Post:
SloS14 (11-19-2013)
Old 11-19-2013, 02:14 PM   #2557
Sojhinn
Sojhinn's Avatar
Looks like the sensor went out. Im just lucky that way. I think this sensor has been flaky since I had it. If you remember I had problems with it initially. Im going to keep the controller for the short term to knock out the tune and dyno, and then Im sending the controller back to Rob for a quick look and fix.
Installed Mods:
Old 11-19-2013, 08:23 PM   #2558
Boosted69
Ok. That's what I figured.
I had spoken to Thomas Knight the other day ( the guy that has successfully made a electric roots blower ) and he was telling me that he uses a larger compressor wheel modified for the housing so he can spin it at what the motor is capable so it may be 4x as large as what would normally be used but spinning 4x as slow as a typical turbo to get the pressure needed ( something like that. not actual true specs). I think having the electric drive with no lag issues and coming on so early in the rpm band throws away traditional needs to be conservative on wheels sizes. I wonder if a different wheel can be used in this system to get the extra air needed if so desired.
I also don't really know what I'm talking about, just really reading to learn and throwing ideas out there.
Old 11-19-2013, 08:34 PM   #2559
fenton
This is already a completely customized system to fully utilize the rpm the motor can output.
What you are talking about Rob has already done in this product. Its was engineered by him. Everything is custom built to his specs, the motor is reinforced to handle the extra load and speed, the control box built to scale out the kW as people always want more. His has been through countless designs (compressor wheel and compressor housing) to get where he is today.
Rob has spent years to get where he is today(many different platforms)....50 to 85 percent torque gain in the dip leveling to 25-35 percent gain at redline out of this system is amazing.
Sent from my HTC One using Tapatalk
Old 11-20-2013, 02:02 AM   #2560
Fast_Freddy
Drives: Passat
Fenton, I do wish you would stop exaggerating the whp/wtq gains achieved by the Phantom ESC. Where you claim 50-85% I see ~50% and where you claim 25-35% I see ~20%. I'm going by all of the dyno results that you've posted and I just can't find any that support your claims.
It's not like this is snake oil but by selling it like snake oil you introduce doubt. Well, IMO anyway.
Thanks in advance.
Fast_Freddy is offline   Reply With Quote
Old 11-20-2013, 09:59 AM   #2561
HunterGreene
Hail Magnet
HunterGreene's Avatar
Thanks in advance.
If fenton was the one selling this system, I could see your beef, but he's just the first test monkey. Excuse him for being excited by the system. He hasn't indicated that he is involved with the professional promotion of this system other than as a tester. Granted, there could be some shenanigans here and he is secretly Rob in disguise (anything is possible) but I highly doubt it.
It has priests in it?
Old 11-20-2013, 10:50 AM   #2562
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Thanks in advance.
I choose one chart, it was the graph showing 205.7 HP that is listed on the first page of the thread. There may be better or worse graphs...but I chose this one.
I charted the results below. Note, I chose 500 rpm increments, and there are better results between those intervals. But Fenton's claims are supported. For example the chart below shows a ESC torque at 4000 and 4500 at 182, but between those points the graph shows peek ESC torque of 184 while OEM torque at 4250 is 110...a 74 ft-lb increase or 67%. On this graph the gain is 50% to 69% in the torque dip and 24% at redline. Fenton's claim in the post above is "50 to 85 percent torque gain in the dip leveling to 25-35 percent gain at redline". The chart below supports a claim in this range. I'm sure there is a chart showing a 85% gain in the torque dip...but at this point it's on you to show me where I'm wrong.
My point, Fenton is being upfront with his data and his claims
...........OEM HP...OEM TQ...ESC HP...ESC TQ...d HP...d TQ...% HP...% TQ
3000.......75.........131........100........175... ......25.....44......33%.....34%
3500.......80.........117........117........175... ......37.....58......46%.....50%
4000.......82.........108........137........182... ......55.....74......67%.....69%
4500.......95.........120........157........182... ......62.....62......65%.....52%
5000......125........133........175........182.... .....50......49......40%....37%
5500......135........126........185........175.... .....50......49......37%.....39%
6000......145........126........180........168.... .....35......42......24%.....33%
6500......160........126........202........165.... .....42......39......26%.....31%
7000......168........125........205........155.... .....37......30......22%.....24%
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following 3 Users Say Thank You to Gary in NJ For This Useful Post:
DAEMANO (11-20-2013), normancw (11-21-2013), WRB5titch (11-21-2013)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
