#267 |
Drives: Toyota 86
AUDM 86GT 6MT with ZA1JA10G ROM.
So I did a test reflash with the BRZbeta EcuFlash my stock .bin file and the Tactrix OP2.0 wrote to the ECU ok. Took about 98 seconds to write the 08000-13ffff block. I've then reflashed a modified ROM with RomRaider Editor checksum correction. Changed VVT settings with associated fuel and ignition tables, changed default IAM to 1.0, CL/OL transition settings and increased rev limit to 7600 as per suggestions by Shiv 1.3 and mad_sb. I have not changed idle or DBW settings so I can assess former changes without having increased zip by reducing pedal travel. Car turns over and starts fine, will report back after a few days of driving. Now waiting for logging capabilities on the Tactrix. |
| The Following User Says Thank You to ztan For This Useful Post: | nelsmar (11-13-2013) |
#268 |
Drives: 2013 LTD BRZ
Anybody else having issues saving roms with the ECUflash beta? I just noticed that it says it saves the file, but when looking at the directory (or file) it isnt written to the file. Just curious.
#269 |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I had this issue when testing on my Outback, but not the BRZ... Also I was able to save SRF but not BIN. Nothing is appended to the log when I attempt either.
#270 |
Drives: Toyota 86
#271 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I would suggest reporting all of this to MikeyPSF on RR, so that Colby can debug when he's back.
#272 | |
FYI:
| The Following 4 Users Say Thank You to Td-d For This Useful Post: |
#273 |
can't wait for logging... get me off of brzedit once and for all
#274 |
Drives: 13 BRZ
That is such great news!!
#275 |
So an update on my logging attempts:
I did some packet sniffing on ecutek logging today... was nothing like what I was expecting to see =x. I am extremely curious to see what Colby's datalog packets look like. I was able to send in packets after pulling the ecutek cable out and putting in my own hardware and poll AFR through non standard call. It wasn't SSM or J1979 based. I have no idea what the basis is lol. Looks like I was able to come up with some math to convert their hex to an actual AFR / Lanbada though! Gonna take me years to go through and write definitions for all of these points. EEP! I was unable to get SSM to give me any data back it just gave me read permission errors =/. I need to try out techstream and see if it pulls via SSM or 1979. Going to try to do that later this weekend. At least I actually got some progress though and have a way to at least find a list of commands by ticking 1 log parameter at a time! lol edit: just found a file on github for romraider logging definitions and the AFR math matches mine. I'll have to check if some of these other ones match up.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#276 |
Drives: GT86
#277 |
Hey nelsmar - nicely done. The conversion of the parameters has not changed much from what I've seen in the rom, so most of the RR logger defs should work.
Sent from my iPad using Tapatalk HD |
#278 | ||
Now if only I had the time... I could actually get the logging rolling hardware wise in my car within about a day or so (i still need to write SD saving, refresh rates, and write a more advanced alert system, and then optimize the hell out of it since i'm running short on ram). I am waiting for scantools to email me back. These commands work when I send with my hardware but not with an STN1100 family chip. Its odd, I think its a configuration issue. People "say" you cant send 15765 propriety messages over a 327 but yet you can send literally everything else. I think most people are confused with driver & software support and confusing a 327/1100 with a j2534. However the STN1100 series worked great for packet sniffing
| The Following User Says Thank You to nelsmar For This Useful Post: | jamesm (11-16-2013) |
#279 | |
Drives: Toyota 86
Just tried to run some basic standalone logging with the OpenPort 2.0. Using CAN addresses in the basic sample Subaru CAN logcfg.txt file (RPM, load, MAF) , I just got a whole bunch of false data and lots of .csv files. Am I doing something wrong, or have addresses changed for us? |
#280 | |
| Close | iJason | Member's Car Journals | 1 | 08-04-2013 09:26 PM |
| Close | pche | Engine, Exhaust, Bolt-Ons | 3 | 08-04-2013 03:04 AM |
| Sorry. please close. | finch1750 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-31-2013 02:00 AM |
| please close | abutterman | Wheels and Tires | 0 | 07-05-2013 10:40 AM |
