Old 06-03-2013, 11:19 AM   #15
Shanahan
Shanahan's Avatar
Couldn't you use something like the PAC modules and pick what to use as you input device? I've used them in the past and had good luck.
http://www.pac-audio.com/products.aspx?categoryid=29
Shanahan is offline   Reply With Quote
Old 06-03-2013, 11:23 AM   #16
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by rmjjensen View Post
I never thought about producing this since the original thread got absolutely 0 traction so I stop contributing.
DO IT. i know a lot of people would be really interested in this...
Jive Turkey is offline   Reply With Quote
Old 06-03-2013, 11:46 AM   #17
Rinzler
Rinzler's Avatar
Drives: BRZ Limited
I would definitely be interested in this.
Rinzler is offline   Reply With Quote
Old 06-03-2013, 03:12 PM   #18
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
I have a friend who is big into PCB etching - I'll hit him up to see how much it would cost to commercialize an etched board. The ICs themselves are dirt cheap but I'll have to tweak the schematic so that it's easy for the everyday user to select the correct output pin and adjust the resistance accordingly.
rmjjensen is offline   Reply With Quote
Old 06-03-2013, 04:10 PM   #19
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i was thinking about this here
http://www.sonicelectronix.com/item_...Fcmf4AodwxEAEg
not sure about build quality but it could be a quick and somewhat clean way of making it happen
abutterman is offline   Reply With Quote
Old 06-03-2013, 05:07 PM   #20
nalc
Drives: 13 BRZ Limited 6MT GBS
Are pins 21 and 22 installed in the factory harness, or do we need to either crimp pins on some spare wire and insert them into the connector, or use some aftermarket harness?
If it's the former, do you know what pins we can buy that will work?
nalc is offline   Reply With Quote
Old 06-05-2013, 12:08 PM   #21
nalc
I am not having any luck figuring out where to get extra pins. I will look at my factory wiring when I get home this weekend, but I doubt that Subaru would have included pins and wiring that don't go to anything.
I found the resistance values for the 2008 Impreza on MP3car
http://www.mp3car.com/car-audio/1209...preza-wrx.html
I don't know if that's the same for our car, but I think that might be a decent starting point to start figuring it out, unless someone can get their hands on a 2012+ Impreza or Forester SWC module and measure the values the Fujitsu Ten is expecting.
Old 06-05-2013, 01:30 PM   #22
mid_life_crisis
Drives: FR-S 10 #103 AT
Might have better luck with a universal version as the starting point.
http://www.sonicelectronix.com/item_...ss-RFASWC.html
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 06-05-2013, 01:55 PM   #23
abutterman
abutterman's Avatar
Woops yea thats the one i meant to link. Looks like it could be decent
Old 06-05-2013, 02:04 PM   #24
mid_life_crisis
Considering how many of the twins have a Pioneer H/U installed from the factory, there are a lot of people who might be interested in that unit.
Old 06-05-2013, 02:33 PM   #25
kuhlka
Drives: 2013 BRZ Limited AT
I REALLY like the cruise stick functions you showed in the YouTube clip. However, I'd only be interested in doing this mod if pressing the cruise toggle button to enable cruise mode disabled the head unit commands.
kuhlka is offline   Reply With Quote
The Following User Says Thank You to kuhlka For This Useful Post:
TIE Pilot (06-05-2013)
Old 09-06-2013, 06:07 PM   #26
foglesre
Drives: BRZ Limited
This is the alternative that I'm working on:
http://www.ft86club.com/forums/showthread.php?t=44827
Placing the controls on the center console instead of the wheel. They will lay right where I normally rest my hand.
foglesre is offline   Reply With Quote
Old 11-13-2013, 03:49 PM   #27
Jive Turkey
the tuna, no crust.
any updates on this, i want this, bad.
Old 11-20-2013, 03:35 PM   #28
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
Has any tried this with the BRZ HU and does it work with it?
kakarot1657 is offline   Reply With Quote
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 01:56 AM
Steering wheel radio controls brillo Electronics | Audio | NAV | Infotainment 6 12-26-2014 11:03 PM
What happened to steering wheel-mounted controls? Stu L Tissimus BRZ First-Gen (2012+) — General Topics 31 07-19-2012 04:52 PM
Steering wheel controls / Stock Player? StevenDavisPhoto Electronics | Audio | NAV | Infotainment 7 01-27-2012 04:18 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
