#1191 | |
Drives: 4 wheels and a steering wheel
This is driving me insane, I think something told the amp portion of the unit to route the sound elsewhere or mute it, and nothing told it to turn it back. What's been driving me crazier is that NOTHING seems to reset the firmwares settings. A bunch of settings like tv mode, radio region etc.... For example, I renamed my phone's BT "expy BT" and nothing I do changes that. Reflash, restore to default, Diconnect all power overnight, reset... "Expy BT" is still there, and so are many other settings, so I wonder if a "stay quiet" internal invisible magic setting is there too. Someone On the xda forums with a unit that originally had a 2.11.** firmware reported he downgraded with the Hal9k and he doesn't have any problem so It must be something else. The supplier sent me a link to an old MCU, so that was worthless... I'm still trying to get the right MCU from them, but I suspect the problem is elsewhere... Been trying to install and uninstall apps like winamp to see if I can get one to "unmute" the audio. I also tried to connect to external BT speaker through my BT dongle, still no sound even out of the external speaker... I'm reaching the baking point and about to pull the plug and return the thing... |
#1192 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Return it and get another I reckon. Hopefully they will accept it back rooted as they should be able to reset it.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#1193 |
Drives: WRX my11
ok so i have read all 55 pages now.. man that was a long read
i have also noticed there are some other units on the market that are offering 1gb ram think this would still work with the hacked rom link: http://www.ebay.com/itm/190901883660...84.m1423.l2649 also this one says its also has windows CE but its the right sharp / model http://www.ebay.com/itm/190892858003...84.m1423.l2649 not sure if its the right one? any help would be good and one last thing has anyone played around with the steering wheel controls ? |
#1194 | |
Drives: Burnt Orange GT86
#1195 |
For all you folks wanting to get standard Android app audio to work properly, it looks like there is a 'The 3rd party application priority' tickbox in Settings->Sounds that you could try selecting. All of a sudden the sound on Angry Birds started working correctly without having to run Video or anything beforehand.
I've played with my system and turned the key beep on - that sounds like a hardware beep that is probably completely independent of the audio routing. I also assigned the mute function to one of the keys and it seemed to work as you'd expect. Mute/unmute worked, as well as using the volume knob to unmute. @sciallo: Is it possible that there is a hardware/cabling reason for the muting behaviour? I can't think of all the lines out the back of the unit off the top of my head, but could any of those being shorted result in volume muting? (There is a Sounds setting for muting the volume during reversing, for example - if the unit always thought you were in reverse, then that could explain things) I know that you mentioned 'factory wipes' - are you referring to the Factory Reset option in the menu? When I get some time, I might sit down and record every configuration in the settings menu - it might help to play spot-the-difference. |
#1196 |
Copy of the T7019 settings menu structure (plus my settings) attached.
#1197 |
Drift King
Drives: '13 Firestorm FR-S 6MT
@GreenPants Hey you got mentioned a few times so you probably missed the post tuat Nzer mentioned you for me. I found a new unit on tradesolytion with orange/amber led's that is a toyota fit, running android 4.0. And i was wondering if you can help out with a root at all. Or if you know anything about one. This unit is the T6229A . I've made serveral posts with questions on page 54, and here is the post you were mentioned in.
http://www.ft86club.com/forums/showp...postcount=1183 Thanks in advance for all your help
'13 6MT Firestorm FR-S
#1198 |
Sorry Brody602, but my part of the equation didn't deal with the actual rooting of the device. I just took an Android image where someone else already did the hard lifting and tweaked it a bit.
I think your best bet would be to study the resources over on xda-developers to see if there are any generic ways to gain root on a device. I've only done it once on my phone - but even that was a step-by-step howto guide specifically for my phone type. |
| The Following User Says Thank You to GreenPants For This Useful Post: | Brody602 (11-12-2013) |
#1199 |
Remember me?
Drives: BRZ Series.Blue
do any of these Chinese headunits have capacitive touch screens?
#1200 |
T7019a and TUN21 both have capacitive screens.
#1201 | ||
I have experimented with backup mute, enabling that and connecting the reverse wire. I also tried connecting to a bluetooth speaker through the dongle and I get no sound out of that either. CD/DVD is one app the active wallpaper doesn't seem to sense. I'm at a loss, and about ready to figure out how to ship it back to china :-( I've used linux for years, so I'm not new to command line, but I'd say I'm new to hacking android, however this little sound problem is getting me to dig deeper than I have before into android inner-workings ![]() Got your list of settings and it seems pretty consistent with mine... If I could ask a favour to anybody, would you mind sending me the output of a couple of commands in a terminal: Code:
cat /proc/asound/cards Code:
getprop Code:
alsa_amixer Code:
getprop > /sdcard/extsd/getprop.txt Also do take a look at those files, some interesting things: seems like there is a setprop for backlight and the alsamixer has a bunch of options, one in particular looks like is about mic sensitivity... Of course not hearing anything out of my unit my experimenting tells me very little other than "no dice, you're not getting audio back this easy" Another kind of interesting discovery, was messing with a wireless keyboard (logitech k400) pressing fn+esc and fn+-> (end) puts the unit in some weird almost-sleep-state, screen off music still plays (unfortunately) and by 'plays' I mean it doesn't pause, not that I can hear it... dunno about sound, but it lower it's consumption (my power supply makes noise proportionally not that I measured it), also, if I press the button I assigned to screen dim, the screen comes on but not the unit, not until I press home or something else or press the above combination again... Just kind of interesting to know, as I was thinking of ways to wire the unit to not have to reboot for short stops... (By the way I am NOT at this point suggesting you try as I don't know that keyboard and it's short-cuts aren't what caused my problem)Quote:
I am considering one if I end up returning this one, but not if there is no root... |
#1202 |
@sciallo - will hopefully get to that later, but I think the area you really want to be looking is the sbd driver, rather than the linux/android sound subsystem.
From what I have gathered by looking at some of the decompiled stock app binaries is that the sbd driver is responsible for the audio routing. If I read my notes correctly, then possibly: Code:
sys/virtual/sbd/misc/source |
#1203 | |
#1204 | |
Code:
# ls /sys/devices/virtual/sbd/misc/ uevent subsystem/ power/ source lheadrest rheadrest phone reverse navi reset # any clue what that "reset" file/device is? I was hoping it could give me that master reset I've been wishing for. Thing is set for write only, and even changing that I can't get even cat to read it... Experimenting I see the "cat reverse" switching from 0 to 1 if I connect the wire, but writing to it does nothing... Like I said it's a bit above my head. ![]() Also a 'cat /sys/devices/virtual/sound/timer/power/control' returns 'auto' and 'cat /sys/devices/virtual/sound/timer/power/wakeup' returns an empty string... Wouldn't mind being able to try to set to 1...? I have so much to learn |
| Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) | JPxM0Dz | Canada Classifieds | 2 | 01-19-2013 11:51 PM |
| chinese man sues wife for being ugly: wins | wrxgoose | Off-Topic Lounge [WARNING: NO POLITICS] | 15 | 11-07-2012 10:58 AM |
| Counterfeit Chinese Airbags | @Art_Mighty | Other Vehicles & General Automotive Discussions | 11 | 11-03-2012 03:20 AM |
| JDM Vs. KnockOff | SIRvive | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 03-05-2012 05:32 PM |
| Gang of Chinese kick, yell, and drag a little caucasian boy | Giccin | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 01-20-2012 10:47 PM |
