Old 11-04-2013, 11:09 AM   #575
Cross
It's the Mad Cow
Cross's Avatar
Originally Posted by jvincent View Post
Quick question for the OFT guys.
The winter tires just went on so now I get to look at my TPMS light for the next 4-5 months.
Can this be disabled by the OFT?
I believe someone else asked this and the answer for now is that it cannot. It might come much later down the line but it cannot do anything with it currently.
Old 11-04-2013, 11:35 AM   #576
jvincent
jvincent's Avatar
Yep, you are correct. Thanks.
A search of this thread found the answer way back on page 7.
Old 11-04-2013, 11:42 AM   #577
Cross
It's the Mad Cow
Cross's Avatar
No Problem, with how many threads on OFT there are it can sometimes be confusing to find every little thing you are looking for or remember where you found it. Glad you were able to find your answer.
Old 11-04-2013, 01:34 PM   #578
Mike86
Drives: Scion frs
if i have acess to 94 oct and have a headerback would stage 2 map still be too agressive without actually having a header im guessing 94oct is more knock resistant just wouldnt wanna do anything that would damage the car thanks alot for any input!
mike
Mike86 is offline   Reply With Quote
Old 11-04-2013, 02:27 PM   #579
cnk
Drives: '13 DGM BRZ Limited
mike
Stage 2 is only for catless headers. Has nothing to do with what octane gas you have.
Old 11-04-2013, 06:49 PM   #580
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
OFT ordered this morning
Danklvr is offline   Reply With Quote
Old 11-05-2013, 08:45 AM   #581
no chrome
She said member
Drives: fr-s firestorm
@shiv@vishnu
Hopefully this is an easy question: how would I raise my cold idle rpm?
I see several idle tables with -40, -30, -20...
At current 1800 I have an extremely loud resonance, I can hold the idle up a bit and quiet it down a lot.
I'm running borla uel and catless front pipe with stg2
no chrome is offline   Reply With Quote
Old 11-06-2013, 01:00 PM   #582
no chrome
She said member
Originally Posted by no chrome View Post
@shiv@vishnu
At current 1800rpm I have an extremely loud resonance, I can hold the idle up at 2000 and quiet it down a lot.
Any of you self-made tuners want to take a crack at this while shiv is at sema?
Old 11-06-2013, 01:37 PM   #583
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
A few pages back it was mentioned that the -40, -30 etc numbers were coolant temps I believe. And the other number is the RPMs (obviously). You could try editing the RPM numbers in the Idle Target tables and see if that works for your needs.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 11-06-2013, 02:52 PM   #584
brn12345
brn12345's Avatar
@shiv@vishnu
I hear you on the resonance, especially when the car is cold. This was something I had on the K20A Honda as well and drove me nuts until I figured out that it was cam phase and ignition timing related. I believe the idea is to get the Cat heated up quickly upon start up. I was able to modify the cam phasing to minimize it on the Honda and I think we can do the same here especially since when we get rid of the cats, there is no need for this procedure anyways.
brn12345 is offline   Reply With Quote
Old 11-06-2013, 03:20 PM   #585
jamesm
@shiv@vishnu
just edit the idle target tables (there are like 6 or 7 of them) to be whatever rpm you want at whatever coolant temp you want.
this brings up a good feature request for tunerpro though, units (or anything other than just a bare number with no description) on the tables would be extremely useful in understanding what you're dealing with. tunerpro is great software, but the lack of any type of units or description on the tables makes the learning curve steeper than it needs to be.
fwiw though you can always just poke around romraider to determine what tunerpro doesn't tell you, then transfer the knowledge over, but it'd be a 'nice to have' for people using tunerpro anyway.
Old 11-06-2013, 04:49 PM   #586
3essess
Drives: frs
I've been playing with those tables...I presume those temps are in Celsius?
Also the temp vs maf is in g/s?
Do you have the link in romraider you mentioned....I've been searching their forums and only find older info.
3essess is offline   Reply With Quote
Old 11-06-2013, 04:51 PM   #587
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
http://www.romraider.com/forum/viewt...hp?f=34&t=9999
Td-d is offline   Reply With Quote
Old 11-06-2013, 11:35 PM   #588
bryce-o
Drives: '08 bmw 135i
nice work, shiv. the OF tablet works very nicely on my 335i. i'm considering picking up an FR-S and it's nice to see you here supporting this platform. cheers
bryce-o is offline   Reply With Quote
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
