#225 |
Thanks! It felt almost too stable, such that I was wondering if EBD was stepping in. There was a tight downhill "corkscrew" where I thought for sure the rear end would come around under trail-braking, but it stayed put. Not at all what I was expecting. Felt completely benign. The nose just tucked in and that was that.
2022 BRZ Build 2013 FR-S Build |
#226 |
Drives: WR blue
#227 | |
Drives: 2013 SWP BRZ
I'm only running like -1.6 or so, and it is DEFINITELY not enough. |
#228 | |
Also, can you get me 1 of each tire (and tell me which is which)? |
#229 | |
#230 | |
However, as a rule of thumb, -3 is a good starting point for the front on a track car. Lower rates will need more camber, and vice versa. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | BRZ NA (11-04-2013) |
#231 |
Yeah I had a feeling that might be the case. How's the car under moderate trail-braking with the pedal dance?
#233 | |
Drives: WR blue
Bone stock showing worn on the edge like the pic,but I m aiming for the rs3 and thinking of the size and camber need.So can't go too hard on the stock tires cause will end up sliding lol |
#234 | |
I still need to work on that... |
#235 | |
Drives: 2013 GBS BRZ (AT)
I got a set of plastic hub rings when I got my TC105Ns. I asked if they would melt and was told that they would be OK. Should I take them off before I do a HPDE? |
#236 |
i'm sorry, what?
Drives: Canada
through brake control?
#237 |
We don't run hubcentric rings at all. The lugnuts will force the rims to center automatically. If they're metal, they're fine, but I'd avoid plastic ones.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | amram (03-28-2014), Pokeguyjai (11-04-2013) |
#238 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
