Drives: 2013 WRB Subaru BRZ
Bluetooth and Nav System
So I've been having some problems with my navigation system lately. Specifically since I had friends in my car and we linked their phones to my car. The auto connect frequently fails now and sometimes my phone disconnects. I've also noticed the time it takes to establish the bluetooth connection is even longer.
Has anyone else noticed this? Do you have multiple phones linked to your car? What did you do? Erase the data? Set yours to the default? Im not sure what to do and I think its time I bust out the Nav System manual and do some reading. Last edited by slizoth; 10-19-2012 at 01:30 PM. |
#2 | |
Drives: Traded BRZ for Supra
I think only one phone can be connected to navigation system at any one time. The more phones you add, the longer it will take to connect, since navigation system tries all phones in some sequence. |
#3 |
I have had issues with disconnecting and reconnecting for a couple months now. It worked great the first month or so. I have tried a bunch of stuff. I am using a Samsung Galaxy Blaze 4g.
I updated my operating system on my phone, which did not fix the issue. It actually made it worse, I would lose the bluetooth connection while taking on it. I ending wrecking my phone trying to root it to access some bluetooth files. Luckily my plan covered a replacement phone. While I was without my samsung the bluetooth worked perfect with my old LG phone. It also works perfect now with my replacement phone. Based on my experience it is the phone that is the issue, not the car. I would delete all the phones form your head unit and re-pair your phone. If that does not work I would try rebooting your phone and taking the battery out. That actually made mine work for a short time. In the end it is likely the result of some additional software you added to your phone. As a last resort I would flash your phone back to the stock form, don't add anything and see if that fixes it. It probably will. Then you can add stuff one at a time and see if the issue arises again. Edit: I wanted to add that the xfinity mobile app may have been my issue. I have not reinstalled that yet. I was just looking on line about that app, which is a major POS and found this under permissions: "create Bluetooth connections Allows the app to view the configuration of the local Bluetooth tablet, and to make and accept connections with paired devices. Allows the app to view the configuration of the local Bluetooth phone, and to make and accept connections with paired devices." Good luck! Pat Last edited by fasteddy; 10-17-2012 at 12:41 PM. |
| The Following User Says Thank You to fasteddy For This Useful Post: | slizoth (10-19-2012) |
#4 |
Unfortunately it doesn't appear to be the sequence of top to bottom as displays on the Settings Connections menu you. Also, sorry about the terrible typos/grammar in my original post, after reading the quote I had to fix it.
#5 | |
#6 | |
Drives: 2013 SWP 6MT BRZ Limited
#7 | |
#8 | |
Sent from my HTC One |
| The Following User Says Thank You to Xx-Ness-xX For This Useful Post: | avp1 (11-01-2013) |
#9 |
| Bluetooth | grgonium | CANADA | 22 | 10-24-2012 01:52 AM |
| bluetooth problems | whitefrs | Electronics | Audio | NAV | Infotainment | 1 | 10-17-2012 07:13 PM |
| Be Spoke system/ BRZ system navigation swap | Mrqb22 | Electronics | Audio | NAV | Infotainment | 4 | 09-27-2012 06:48 PM |
| Bluetooth/Nav | inimitable | Electronics | Audio | NAV | Infotainment | 40 | 09-26-2012 09:35 PM |
| FRS bluetooth set up | jym89709 | Electronics | Audio | NAV | Infotainment | 16 | 09-08-2012 04:04 PM |
