#15 |
I say this in every post, but about this, disconnect the rear sway bar end links at the bar and zip tie them up and test drive.
The end links connect to the OEM with such low torque and are so easy to strip that if they have any play when you lower it will clunk like as if you had a blown shock. It's impossible to re-create except at low speeds. I also went through and replaced both control arms (precaution) and all suspension bolts as recommended by service manual when doing any removal and install. If you don't at the very least use red thread lock on bolts as that is how the factory pieces come. See picture
#16 | |
Drives: Vortech Supercharged FR-S
I was just praying that its not a issue of axis. So if the problem is like this, I only hav to change the end links, not sway bar, correct?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#17 | |
If you are lower than -2.0" then you should just go straight to adjustable endlinks as the OEM links will be heavily pre-loading the bar.
#18 | |
Thanks
#19 | |
If it's not your links, find the problem first before changing anything else.
#20 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
it would make sense why i dont have the noise you speak of...i put in kartboy endlinks when i put in my coilovers.
#21 | ||
I remember you have front sway bar only, correct? I dont have any noise from front suspension, which is strange. Cus I drop more at the front and the front link is recommended to be changed. Quote:
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. Last edited by Figo; 10-28-2013 at 08:51 PM. |
#22 |
the tuna, no crust.
stock front bar/endlinks.
rear kartboy endlinks. |
#23 |
No rice, no life
Drives: 2013 Asphalt FR-S
Man why have there been so many threads about clanky KW V3s lately? It makes me hesitate on buying some.
#24 | |
It may just under steer a bit more other than that no mechanical risks.
| The Following User Says Thank You to Dezoris For This Useful Post: | Figo (10-29-2013) |
#25 |
I dont think the clanking comes from KW V3. Cuz it doesnt hav any issue before. I heard the clanking after drop the car alot.
#26 |
sounds cool...why not get front endlink? lol.
#27 |
the tuna, no crust.
didn't think i'd need it? i'm going to do the front swaybar come spring anyway so i'll do that together.
| The Following User Says Thank You to Jive Turkey For This Useful Post: | Figo (10-29-2013) |
#28 | ||
thank u so much. I fixed the problem already. It was the springs on my coilovers. when they adjusted height, the springs moved a little bit and was not at the correct position.
| Suspension DEALS from Moddiction! AVO, Whiteline, Perrin, KW, Eibach, Tein, Cusco+++ | Moddiction | Brakes, Suspension, Chassis | 122 | 03-02-2018 09:34 AM |
| **BLOWOUT SALE ON ALL SUSPENSION PARTS FROM CUSCO AND WHITELINE!!** | genometuning | Brakes, Suspension, Chassis | 163 | 01-12-2015 08:21 PM |
| B2autodesigns Suspension and Brakes Cusco, Eibach, Tein, H&R, Whiteline and Stoptech | b2autodesigns | Brakes, Suspension, Chassis | 44 | 01-17-2013 12:18 PM |
| Whiteline|Cusco|TEIN|Perrin|KW & More! All your suspension needs here @ CMS | Circuit Motorsports | Brakes, Suspension, Chassis | 64 | 12-18-2012 03:25 PM |
