Old 10-22-2013, 09:31 AM   #29
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
If someone could take a picture under the car to check the angle of axle when at stock height would be great.
Envoyé de mon ST18a en utilisant Tapatalk
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 10-22-2013, 09:43 AM   #30
xXDeathMaliCeXx
xXDeathMaliCeXx's Avatar
Drives: Scion FR-S
To the people who put on the DSS axles, how long have you been driving/tracking on them? And no clicking/creaking/etc issues whatsoever?
2013 SWP Toyota GT86 -- Daily Duty
xXDeathMaliCeXx is offline   Reply With Quote
Old 10-22-2013, 09:50 AM   #31
sierra
Drives: Skoda Yeti DSG diesel 4x4
I just went out and checked mine. No pic.
It's almost perfectly horizontal but with a slight rise from the diff to the wheel.
sierra is offline   Reply With Quote
Old 10-22-2013, 10:40 AM   #32
Foobar
SLO NO MO
Foobar's Avatar
Has anyone encountered this issue with the stock suspension?
The Following 4 Users Say Thank You to Foobar For This Useful Post:
kodyo (10-22-2013), Pseud0logik (05-20-2014), strat61caster (10-22-2013)
Old 10-22-2013, 01:31 PM   #33
dsgerbc
Drives: BRZ(sold), STI
And at stock power level.
The Following 5 Users Say Thank You to dsgerbc For This Useful Post:
Carwhisperer (10-29-2013), kodyo (10-22-2013), Pseud0logik (05-20-2014), strat61caster (10-22-2013)
Old 10-22-2013, 04:29 PM   #34
nelsmar
@Ninjin I believe started clicking at near stock power. Just TRD intake and tune.
My flickr - Canibeat
Local magazine scout
Old 10-22-2013, 05:18 PM   #35
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Hard to tell in my case, I went from "basically stock" to "full retard" in about two weeks. I don't recall ever hearing the clicking noise stock though.
Sent from my GS4.
Old 10-22-2013, 05:41 PM   #36
nelsmar
Sent from my GS4.
Oh clicking was after the header & front pipe ? I thought you had it before. My bad! Regardless he is still NA. So i guess he is off the board for stock power.
Old 10-24-2013, 03:26 PM   #37
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Im having this same problem and I am gonna try to bring it to the dealer tomarrow morning. I think its been happening to me even before i got my mods. Right now I have coils and for a while I maxed them out so I was pretty low. Sound has gotten so much worse. My friend told me it was because I used my ebrake to drift but now I know that its an axle problem.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
Old 10-24-2013, 07:32 PM   #38
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
I will post this picture from an old thread here:
As far as I know, nearly all the breaks are in the same area and every one of them has been on a car that is lowered. Some have been tracked or autox but not all. But all have been lowered which apparently is adding additional stress to the CV joints. If you watch the above video you can get a better understanding of why that may be the case. That car is on RCE yellows with a drop of only 20-22mm (.80 inch approximately). Look at the angle of the axle during cornering and large bumps. Now think of what the angle would be with the car lowered 2-3 times that much.
This is a problem on many cars with independent rear suspension that are lowered not just the BRZ/FR-S.
Rampage is offline   Reply With Quote
The Following 5 Users Say Thank You to Rampage For This Useful Post:
funwheeldrive (02-06-2014), normancw (11-09-2013), Pseud0logik (05-20-2014), strat61caster (10-24-2013)
Old 10-24-2013, 07:45 PM   #39
sierra
As far as I know, nearly all the breaks are in the same area and every one of them has been on a car that is lowered. Some have been trtacked or autox but not all. But all have been lowered which apparently is adding additional stress to the CV joints. If you watch the above video you can get a better understanding of why that may be the case. That car is on RCE yellows with a drop of only 20-22mm (.80 inch approximately). Look at the angle of the axle during cornering and large bumps. Now think of what the angle would be with the car lowered 2-3 times that much.
A longer shaft in a lowered car would be a good start. It's tracking at the end of the race and you can see where it pulls itself down under power to cause the indents towards the outer range of that movement.
That wear suggests the car was lowered early on and either heavily tracked or had engine mods?
It's no wonder they are failing when the CV's are being pulled to their limits at an angle.
The Following User Says Thank You to sierra For This Useful Post:
Old 10-25-2013, 10:06 AM   #40
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
So am I getting this right? Any power mods and suspension mods (as in lowering) will cause premature axle wear/break?
Eurasianman is offline   Reply With Quote
Old 10-25-2013, 10:57 AM   #41
sierra
That sounds reasonable generally except the problem here seems to be the shafts are a bit short.
Could the diff be raised by the amount the suspension has been lowered to keep the shafts straight?
bakerr6 (11-21-2013)
Old 10-25-2013, 11:06 AM   #42
nelsmar
I lean more towards suspension ride height and lower physical travel is the likely
Culprit. I'm not saying power isn't. But the lower you go the faster the axles seem to wear. I'll try and get some video this weekend of where mine is as I am near the lowest height on ksports. I am sure once we get enough fees back from users with a list of what they have done, driving style, and the event of breakage, as well as a vendor that sees the interest we an come up with a solution. Hell I know a local CNC shop that would love to start producing product for our platform if we get enough concrete info.
more money than brains, stance bro
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
