Old 10-08-2013, 12:13 AM   #169
soundman98
ProCrastinationConsultant
soundman98's Avatar
well then i'll make it easy!
http://www.autowindow.com/orderTAP.html
Old 10-20-2013, 12:33 AM   #170
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
And now time for something completely new....
made a custom Tapturn for myself to try a few concepts out.
Have a look on my Legacy.
Not sure if signals like this are legal? A quick double blink for Tapturn and regular signaling.
These are stock incandescent bulbs, so kinda sluggish ramp up and down.. If you have LED's these would be very crisp strobes.
[ame]http://youtu.be/TJicpUuo0WM[/ame]
Here is wag-wag in strobe effect, these blink two times per side.
[ame]http://youtu.be/OzgcUnM57yU[/ame]
And a slow motion wigwag (aka the easter egg mode) rendered in strobes, these blink 4 times per side.
[ame]http://youtu.be/b2GJkYz098k[/ame]
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 10-20-2013, 12:53 AM   #171
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
^I like the wig wag strobe
need to order my tap turn soon
SpeedyJay is offline   Reply With Quote
Old 10-20-2013, 01:27 AM   #172
scottmcphee
Well it won't take long to get there from Sherwood Park when you do order. And use e-transfer to save a couple bucks.
Cheers!
Old 10-20-2013, 10:15 AM   #173
scottmcphee
I've rigged up this Tapturn with strobes using a second processor inside, so it's a dual core flasher, believe it or not!
It has configurable modes:
1. Behave just like a normal Tapturn, no strobing.
2. Strobe Hazards but only when car is off / parked, normal hazards otherwise. This applies to hazard modifiers too, wig wag and slow motion.
3. Strobe Hazards any time you use hazards, parked or driving, applies to modifiers as well.
4. Strobe all, which is all hazards and signaling too. This includes signals done by the tap feature, and conventional signaling too.
Old 10-20-2013, 11:43 AM   #174
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Send one to me! I'll try it out
I already bought this, guess I need v2 now
Sent from my GT-I9500 using Tapatalk
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-20-2013, 06:45 PM   #175
scottmcphee
I got a couple strobe packed Tapturn's out testing in the field already, thanks tho.
Talk to @KAR on this forum! He's got a prototype installed. Here's his DIY page for his install.
http://www.ft86club.com/forums/showt...hlight=tapturn
KAR's unit has hardware switches to select strobe mode.
I've since figured a way to make these software selectable... using just your signal stalk, hazard switch, and ignition switch in combination.
Old 10-20-2013, 06:51 PM   #176
scottmcphee
As customer appreciation I can retrofit the software selectable Strobe Pack processor onto existing Tapturn's bought after Aug.2013 if you send it in for service, PM me for the dollars first. Got an earlier unit than that, it's a replace, sorry.
I have not set a price yet to have Tapturn come with strobe pack already installed, but it will cost a bit more than standard Tapturn for the dual core new functions.
Anyway, with Strobe Pack you'd get all four modes (mentioned a couple posts back) user programmable which one you want to run with. Change it at will when the car is parked for the next drive, takes seconds to do.
Old 10-21-2013, 10:19 PM   #177
mid_life_crisis
Drives: FR-S 10 #103 AT
@scottmcphee
I just wish you had gotten enough help to bring the window controls to market.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-23-2013, 12:53 AM   #178
scottmcphee
Originally Posted by mid_life_crisis View Post
@scottmcphee
Ya, oh well.
Old 11-02-2013, 08:58 AM   #179
scottmcphee
I should mention that any of the strobe modes also strobes the alarm confirmations given by using the remote lock buttons.. This is just a bonus effect that looks pretty cool and reminds you that strobes are enabled on the car.
And the most intense strobe mode (4) also strobes the blink count setting indications while you're changing the number of Tap blinks from 3 to 6... Sort of as a reminder that your taps and signals will be strobed.
Cheers
Scott
Old 11-03-2013, 12:25 AM   #180
KSpider
KSpider's Avatar
Drives: '14 S4
Wish I knew about this before installing my Tom's relay... I don't really wanna slice my hand open again doing another swap : ( I do really want the multiple blinks.
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 11-03-2013, 09:35 AM   #181
scottmcphee
Tapturn will improve your TOMS too, by getting rid off the retarded first blink problem with that flasher.
I did put a thread about it over here in hopes to catch TOMS light buyers before doing the under dash work.
http://www.ft86club.com/forums/showthread.php?t=46691
Spread the word! If you're doing flasher may as well do it once, for the life of the car and get Tapturn!
Old 11-03-2013, 09:23 PM   #182
cerealcable
Drives: 2013 Dark Gray Subaru BRZ
Subscribing. Definitely interested in this, though just got the BRZ so I'll wait for a little bit!
cerealcable is offline   Reply With Quote
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 03:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 10:26 PM
FINALLY My Turn! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 10 06-12-2012 12:52 AM
