Old 10-19-2013, 03:23 PM   #1
KAR
Drives: Whiteout 6spd
DIY Tapturn Flasher Install with Strobe Option
first off I would like to thank @scottmcphee from tapturn for making this a reality..
BEST USE WITH LED TURN SIGNALS
Go to Page...
scottmcphee
If you have done or replaced your flasher already, you will not need these DIY for this is an actual PLUG n PLAY product.
Here is a pic of the new flasher
compared to stock
KAR is offline   Reply With Quote
Old 10-19-2013, 03:39 PM   #2
KAR
for the Install, pretty straight forward
you can reach under the steering wheel to install but Im showing you guys where it is located.
first I pull off the side panel on the driverside
Old 10-19-2013, 03:44 PM   #3
KAR
there is A screw inside the panel and underneath the dash right below the ignition.. remove them and gently pull back the under panel
Old 10-19-2013, 03:50 PM   #4
KAR
now you can see where the flasher is. I use a small screw driver to unclip the flasher from its mount.. you stick it in to unclip its from it mount and push from behind towards the rear of the car.
unplug the stock one and plug the tapturn flasher and your done
Old 10-19-2013, 03:53 PM   #5
KAR
end results, click on image to see the video
keep in mind you can use this as regular Tapturn flasher and has the function as the regular flasher, you just need to swith it off, you can also flick a switch to where these function will only work with the car OFF
Old 10-19-2013, 09:09 PM   #6
KAR
Photobucket sucks, videos are slow..
Old 10-20-2013, 10:05 AM   #7
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
looks cool though
Enraged21 is offline   Reply With Quote
Old 10-20-2013, 11:54 AM   #8
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
This is a 120 second mod. Lay down under dash with flash light. Disconnent cable from stock relay. Use a cable tie to secure the the new relay leaving the stock relay alone. Plug in harness. It doesn't need to be anymore complicated than that
Sent from my GT-I9500 using Tapatalk
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 10-20-2013, 07:07 PM   #9
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
I posted up some video (on youtube) of a unit like this working in a test vehicle (my car!). Youtube shows the action a little smoother like it really is.
http://www.ft86club.com/forums/showp...&postcount=172
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 10-20-2013, 07:40 PM   #10
KAR
Send me your email and I'll email the video to you
Old 10-23-2013, 12:57 AM   #11
scottmcphee
Done
Thanks!
Old 11-15-2013, 02:22 AM   #12
ReThink
ReThink's Avatar
Drives: Sc10n FRS "DCLXIV"
Strobe option...I already have a Tapturn Flasher, but how do I get one of these with this strobe option?
Sc10n FRS #0664
ReThink is offline   Reply With Quote
Old 11-15-2013, 10:14 AM   #13
scottmcphee
PM me !
Old 11-15-2013, 04:29 PM   #14
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
PM me !
same here i already have the tapturn.... sending pm
xDBOYx is offline   Reply With Quote
TapTurn flasher - convenience signaling for LEDs or stock bulbs! scottmcphee Exterior Parts - Lighting 120 09-22-2017 01:45 PM
TapTurn - best signal flasher upgrade for FR-S BRZ scottmcphee Audio/Visual, Electronics, Infotainment, NAV 160 03-30-2015 11:15 PM
My New LED+TAPTURN=COOL KAR Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2013 02:26 AM
FS: gently tested TapTurn flasher scottmcphee Exterior Parts (Aero, Lighting, Etc.) 7 09-02-2013 11:14 PM
Blue/Red Strobe Lights? 636 Cosmetic Modification (Interior/Exterior/Lighting) 15 11-04-2012 10:10 PM
