Old 10-13-2013, 08:43 PM   #1
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
Car "Clicks" When Weight is Transferred Back and Forward
So I just put on Gram Light 57Xtreme's, 18x8.5+33, 225/40 in the front and 18x9.5+40, 255/35 in the rear. The rears are spaced out +15mm. The suspension is completely stock, thanks to the gov't shutdown and not getting my bonus. After I put them on, I noticed a clicking sound from the rear, under the car during any kind of sudden weight transfer forward and aft, like a hard acceleration or sudden downshift. Tried all combinations of spacers, stock wheels and Gram Lights, but to no avail, the clicking remains. Not sure if it's the suspension or the diff, has anybpdy else ad this problem or is able to shed some light? I also checked that the springs were seated properly at the recommendation of one of my friends, but they are. Open to any suggestions...
disgruntld is offline   Reply With Quote
Old 10-15-2013, 10:53 AM   #2
Shanahan
Shanahan's Avatar
I get the same "clunk" and you can feel something is settling. Typically it is most evident after you come to s top and release the brakes. I've torn everything apart and not been able to figure out what it is either.
Shanahan is offline   Reply With Quote
Old 10-15-2013, 11:06 AM   #3
Bullnettles
Drives: Scion FR-S 2013
Same here, subscribed...
Bullnettles is offline   Reply With Quote
Old 10-15-2013, 11:10 AM   #4
celica73
My first thought was a loose wheel, but it sounds like the sound has persisted between wheel changes.
Next I'd check and make sure all brake parts are tight and where they belong (caliper guide pin bolts, and caliper bracket bolts). Otherwise, it could be an axle or a diff, but that's where I'd check last.
Old 10-15-2013, 11:48 AM   #5
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Many people on these forums have advised that this noise is Axle related
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 10-15-2013, 05:43 PM   #6
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
I know this may sound silly, but Ive had this happen before and it was because I forgot to torque one nut down on one wheel. Id hit your wheels with a torque wrench incase you missed one.
lickitysplit is offline   Reply With Quote
Old 10-15-2013, 05:47 PM   #7
SkullWorks
Drives: SSM LT MT BRZ
it will be the axle nut, take the center cap off a wheel and look at the factory "dimple" in the sleeve at the outside of the nut, if it isn't centered on the shaft anymore you have found your culprit...had the same issue, I hit it with an impact gun until the dimple moved to the other side of the groove in the shaft and haven't had any issues since.
The Following 2 Users Say Thank You to SkullWorks For This Useful Post:
CSG Mike (10-15-2013), Pete156 (10-15-2013)
Old 10-15-2013, 06:04 PM   #8
DSlayerZX
Drives: 2010 Corolla, 2013 Fr-s
have you tried this?
http://www.ft86club.com/forums/showt...=13451&page=22
DSlayerZX is offline   Reply With Quote
Old 10-15-2013, 06:58 PM   #9
CSG Mike
CSG Mike's Avatar
Check axle nut first, and then the axle itself.
Carwhisperer (10-16-2013), SkullWorks (10-15-2013)
Old 10-17-2013, 08:12 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Im getting the same thing since i installed my rce springs. Glad this thread is here.
Old 10-18-2013, 07:33 PM   #11
vgi
Drives: frs
Put my car in neutral and moved it back-n-forth - only thing I hear is clunking what the driveshaft play. There was a thread showing how much it actually moves (rotates) until locking. Maybe that's what you hear?
vgi is offline   Reply With Quote
"dEAD CLICKS" ON TEIN ST FLEX Khánh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-10-2019 03:36 PM
Is there a collective "stock parts weight" thread? Bullnettles Scion FR-S / Toyota 86 GT86 General Forum 1 05-28-2013 02:46 PM
Long "Scion" sticker on back bumper CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-12-2013 11:31 AM
My Wife Found a New "Cat Back" Exhaust Toyota86Fan Other Vehicles & General Automotive Discussions 6 10-15-2012 09:17 PM
the "Your order has been pushed back" support group Surok AUSTRALIA 143 09-11-2012 03:52 AM
