Old 02-05-2012, 01:55 AM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by 70NYD View Post
I'm sorry but that's bs
It sais 200kg/m. Realy? 200nm yea but kgm hell no
Originally Posted by dabocx View Post
They most likely meant 20.0 kg/m or N·m
The specs are 147kW and 205N-m, as per Subaru. The chart is mislabeled, I said that.
Old 02-05-2012, 02:08 AM   #16
ahausheer
Re-member
Drives: Toyota camry
The dips in torque and hp may be caused by a valve controlled variable intake, which Toyota uses in many of their engines. What I mean is, by way of a valve, the intake length is effectively changed. All of the dyno charts I have seen from engines that use this type of variable intake suffer from significant dips in torque and slight dips in hp near the switchover point. Some (all?) lexus motors use three stage intakes to better avoid these dips.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 02-05-2012, 03:00 AM   #17
serialk11r
Drives: '06 AM V8V Coupe
That's a good point, I did not think about that for some reason.
The sharp drop at 7000 is a bit strange though, my guess is that will be easy to remove and thus make the last 500 rpm of the rev range more useful.
Old 02-05-2012, 04:13 AM   #18
OrbitalEllipses
Drives: Attitude
Perhaps they let off the throttle at 7000?
Old 02-05-2012, 04:58 AM   #19
serialk11r
In the ECU programming?
Old 02-05-2012, 05:07 AM   #20
cossey
Drives: Reanult Megane R26
soft fuel cut? it is only ~400 rpm so it is probably intentional to stop people driving hard into the limiter.
cossey is offline   Reply With Quote
Old 02-05-2012, 05:16 AM   #21
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Hey, it is DBW after all.
With such a precipitous drop off it's either artificial, or the airflow is choking somewhere, hopefully not in the head.
old greg is offline   Reply With Quote
Old 02-05-2012, 05:21 AM   #22
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
And noone's mentioned yet that that is clearly a very "smoothed" graph - so the sharp cutoff at 7000 will be a transition rather than a quick reduction when we get a true dyno chart.
I would however say that I'm surprised they haven't used different cams to bring the torque band back a bit, bringing the power peak back in the rpm range as well - this should have given a flatter torque curve (less of a dip in the middle), and I don't see why they couldn't have made the same power with that setup... :S Maybe for modifications - maybe the cams are designed slightly more for people raising the stock rev limit or making high flow mods (I/H/E) to get the most power?
Snaps is offline   Reply With Quote
Old 02-05-2012, 04:34 PM   #23
catharsis
Drives: honda civic si 08
After looking at the chart, I feel a big optimistic. The torque maxing out at 3k rpm is very nice indeed. Especially if you want to autox or track this car. I think the lines can be smoothed out with a simple tune and bolt ones, it still won't be a monster. But for autox it might do quite well depending on its class.
catharsis is offline   Reply With Quote
Old 02-05-2012, 04:58 PM   #24
vivix
vivix's Avatar
Drives: 2007 Focus ZX3, 1972 Buick Skylark
that torque table that just plummets after 7k could probably be extended a good bit. its going way too strong for that much of a drop off naturally. heres hoping they left it all on the table, ready for tuners to unlock
vivix is offline   Reply With Quote
Old 02-05-2012, 05:09 PM   #25
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
does anyone here think they can do an overlay of this graph
over this graph (size and strech it accordingly) so i can see how much better the fa20 is compared to a stock 2zz-ge
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 02-05-2012, 05:35 PM   #26
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
It's not scaled the same...
Jordo! is offline   Reply With Quote
Old 02-05-2012, 05:38 PM   #27
serialk11r
Yea but the torque drops off more on the 2ZZ (120ft-lb to 100ft-lb before the cams switch) than the FA20's drop at 4000 (200Nm to 180Nm). The FA20 is smoother, although it starts off weak in the low range because of the fixed duration cam.
Old 02-05-2012, 05:48 PM   #28
bambbrose
Wiring Nerd
bambbrose's Avatar
Drives: 1994 Supra
Freehand bitches :happy0180:
One is at wheels and the other is at crank. Can't compare, so I did it with 15% loss
yellow and purple are best guesses.
midrange torque is dramatically improved.
bambbrose is offline   Reply With Quote
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 01:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 01:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 04:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 02:47 AM
