Old 02-04-2012, 08:28 PM   #1
Levi
Drives: Toyota
BRZ / FR-S Boxer Engine Dyno Powerband revealed
Official BRZ/FR-S Boxer dyno chart from the new Official BRZ JDM website
Needs a tune ?
Levi is offline   Reply With Quote
Old 02-04-2012, 08:50 PM   #2
balance
Drives: 86 & Picanto
Maybe? But then, how much more power would a tune get?
Can you share us the source of this graph? 25% drivetrain loss is quite a lot.
I don't like that dip in the tq curve around 4k rpm. Wonder why...?
balance is offline   Reply With Quote
Old 02-04-2012, 08:55 PM   #3
OrbitalEllipses
Drives: Attitude
Looks similar to the extrapolated curves we saw based on the now deleted video of the 86. Same drop at 4000rpm even. How many kW is that, ~147? 147kW = ~188hp according to the conversion table I'm using. Might be an engine dyno rather than a chassis dyno.
Look at the units. It's kW, not HP. And the dip in 4K, I believe, has theoretically been attributed to the D-4S system switching over injectors.
Old 02-04-2012, 09:00 PM   #4
serialk11r
Drives: '06 AM V8V Coupe
It's in kW, and 147kW is 197hp as advertised.
OrbitalEllipses, no it hasn't been attributed to that, may I suggest you go read the intriguing discussion we had on this?
Port injection is turned off well before 3000rpm. Currently that drop is somewhat of a mystery. I believe it can be tuned away.
Old 02-04-2012, 09:03 PM   #5
balance
Thanks for the heads up on the units. Makes sense now.
Hope the tuners can work their magics and alleviate the torque dip with simple mods like ECU tune (probably not an easy feat to accomplish though...)
Old 02-04-2012, 09:04 PM   #6
OrbitalEllipses
Drives: Attitude
Oh? I thought that's what I read on it. Is it in the D-4S thread or the 170rwhp thread? Link?
WHOOPS. Read the wrong line. I was looking at 140kW. So it's chp and not whp...
Also heads up: torque units are wrong. It's in N-m not kg-m.
Old 02-04-2012, 09:09 PM   #7
Levi
Drives: Toyota
The dip should not be a problem, as I have it on my Alfa and I with a tune I can flatten it without problem. But with DI it could be different though, but I still don't think so.
Old 02-04-2012, 09:10 PM   #8
serialk11r
Engine tech. Well, arghx7 copied a chart from the 2GR-FSE technical paper that showed the port injection/direct injection usage map. We dug up some info on how VVT-i is controlled, and found that there is a large amount of internal EGR going on for emissions reduction apparently, and the particular way that they set this up could be affecting midrange torque. However seeing that torque is very strong at 3000rpm suggests something else is at work.
However it could just be an intake/exhaust tuning thing, in which case you probably can't dial it out in the ECU.
Old 02-04-2012, 09:25 PM   #9
Levi
Drives: Toyota
Without the drop you would get maximum torque from 3.000 RPM to 7.000 RPM what would be a 4.000 RPM band, as better than its turbocharged rivals. It is nice that the torque keeps up to max power.
Old 02-04-2012, 09:30 PM   #10
balance
Agreed on the unwearying tq up to 7k. Very nice indeed! What was the cause of the dip in Alfa (albeit the absence of DI)?
Curious to see how much we can get out of the normative I/H/E and the tune... Hopefully, we will able to see at least 10% gain.
Old 02-04-2012, 10:08 PM   #11
dabocx
dabocx's Avatar
Drives: Scion FRS
I have a good feeling about N/A on this car. Hopefully alot was left on the table
dabocx is offline   Reply With Quote
Old 02-05-2012, 12:52 AM   #12
70NYD
70NYD's Avatar
Drives: RX8 S1
I'm sorry but that's bs
It sais 200kg/m. Realy? 200nm yea but kgm hell no
70NYD is offline   Reply With Quote
Old 02-05-2012, 01:34 AM   #13
dabocx
dabocx's Avatar
Drives: Scion FRS
They most likely meant 20.0 kg/m or N·m
Old 02-05-2012, 01:49 AM   #14
serialk11r
The sharp drop in torque at 7000 suggests there is probably quite a bit of power that can be picked up imo, yea
2013 Porsche Boxer is revealed early DIG1992 Other Vehicles & General Automotive Discussions 62 09-05-2012 01:26 PM
Next Gen Boxer Engine 4U-GSE WingsofWar Engine, Exhaust, Transmission 33 12-10-2011 01:04 AM
Toyota Reconfirms Production 2012 FR-S / FT-86 Boxer Engine, 6MT, 6AT, LSD Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 30 05-02-2011 04:30 AM
Could this be the base FT-86 boxer engine? iff2mastamatt Engine, Exhaust, Transmission 2 02-10-2011 11:55 PM
More proof of FT-86 Boxer engine appears in logo Hachiroku Engine, Exhaust, Transmission 33 01-03-2011 02:47 AM
