Old 10-07-2013, 11:10 PM   #253
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Scalzo View Post
Anyone with turbos try this out? or am I gonna be the only one lol
I know of a couple customers who are currently in the process of installing turbo kits and then either tuning it themselves or taking it to a tuner. I'll be installing a supercharger in our car soon as well. So it won't be long until we have good turbo/sc base maps available for anyone to download
And thank you to everyone else for the kind words. We are thrilled that you guys are happy with the OFT!
shiv
Shiv@Openflash is offline   Reply With Quote
Old 10-07-2013, 11:11 PM   #254
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
shiv
Sounds good, Do you by any chance know JS-Tuned from Montreal?
Scalzo is offline   Reply With Quote
Old 10-07-2013, 11:12 PM   #255
Shiv@Openflash
Drives: 2013 FRS
Doesn't ring a bell. But with my terrible memory, that's not saying much
Old 10-07-2013, 11:50 PM   #256
Scalzo
Scalzo's Avatar
When will this work with the Ecutek tune?
Old 10-07-2013, 11:54 PM   #257
Shiv@Openflash
Drives: 2013 FRS
We will not officially be supporting Ecutek tunes with the OFT. It's not just a good idea based upon the security that Ecutek introduces to thwart such things. Really the best thing that you can do if you have an Ecutek tune and what an OFT to store/edit maps yourself, I recommend just flashing your tune back to stock (with the Ecutek cable) and then installing the OFT like normal.
Those tuners who are familiar with tuning with Ecutek, will find that they can do the same with the OpenFlash tuning software (Tuner Pro). The same tables are available for editing. In fact, I think they even have the same table names in many cases.
Old 10-08-2013, 12:16 AM   #258
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@shiv@vishnu, what there any appreciable increase from the airaid over the stock airbox and drop in filter?
Intent > Content
Old 10-08-2013, 12:20 AM   #259
Shiv@Openflash
Drives: 2013 FRS
Noting really significant. We have found that the intake restriction is the snorkel ducting, not the filter/airbox. So as long as that is still in there, all the intake (stock or otherwise) are going to perform about the same. The only time the AirRaid intake picked up a few hp (over stock) was when you removed the lid. While this eliminates all intake restriction, it not longer is a "cold air" box. Probably doesn't matter when the car is in motion (since underhood temps are close to ambient) but really does heat things up in stop and go traffic.
my 2c,
shiv
Old 10-08-2013, 12:26 AM   #260
solidONE
solidONE's Avatar
So if I have drop in filter and exhaust, do I reflash with the stg.1 stock intake map on OFT?
Intent > Content
Old 10-08-2013, 12:44 AM   #261
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
I live in alaska and only have access to 90 octane gas.. will the base tune work for me?
Furtive is offline   Reply With Quote
Old 10-08-2013, 02:14 AM   #262
Shiv@Openflash
Drives: 2013 FRS
Yes it should work fine. There is a fair bit of learning that the ECU is capable of. We only get 91oct here in CA so your fuel isn't that different. And I'm guessing your weather is cooler too (which helps).
Old 10-08-2013, 03:54 AM   #263
tracerit
Drives: '13 SSM BRZ Limited 6MT
curious about this as well. I just have a Cosworth drop in filter, Perrin inlet hose and a Perrin resonated catback 2.5". These are the only hardware performance mods i'm 95% sure i'll ever have.
tracerit is offline   Reply With Quote
Old 10-08-2013, 04:33 AM   #264
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
If you are still using the stock airbox/maf housing, you should probably be using the stock intake tune. If you are using an intake that replaces the maf housing, you will likely want a tune customized for that intake. At this moment, only a tune for the Airaid intake is available. From what I understand, @shiv@vishnu and company will be releasing tunes for other intakes in the future as time and available testing parts allow.
FrX is offline   Reply With Quote
Old 10-08-2013, 08:43 AM   #265
vgi
Drives: frs
shiv
i'm curious which supercharger kit will be the guinea pig? and what do you guys use currently for logging, the beta version logging of OFT or something else?
vgi is offline   Reply With Quote
Old 10-08-2013, 10:45 AM   #266
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hey Shiv, I was curious if you will be creating the maps for the other intakes using remote tuning? That way you wouldn't need to install a bunch of different parts on a frs/brz in house.
Installed Mods:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
