Old 10-07-2013, 10:34 PM   #85
Mixlplix
Subscribe
Mixlplix is offline   Reply With Quote
Old 10-11-2013, 04:26 AM   #86
PantsDants
Drives: Scion FR-S A/T, Whiteout
Update: Looks like I'll be dropping my car off in the evening this Sunday, and hope to have it back on Monday or Tuesday.
Once I've got it back and have driven it around to get a feel for it, I'll post my impressions on it. You know, provided that it actually installs cleanly, which I'm fairly confident it will, given the think-tank that is this forum. I'll clean up the first post here to include what was actually used in the installation so others going forward have a recipe to follow. I may consider making another thread specifically as a guide to what is needed to do this, hopefully as a sticky.
PantsDants is offline   Reply With Quote
The Following 8 Users Say Thank You to PantsDants For This Useful Post:
8686 (10-11-2013), Freeman (10-11-2013), Knickstape (10-12-2013), L8Apex (10-11-2013), mike_ekim1024 (10-11-2013), SportInjected (10-11-2013), Trac Toy (10-11-2013), zoomzoomers (10-11-2013)
Old 10-11-2013, 09:22 PM   #87
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
Picture pleaseeee.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 10-15-2013, 05:28 AM   #88
PantsDants
Starting day 2 without the car; theoretically I'll get it back later today. Of course I HAD to pick the busiest damn diff shop in the state. Good excuse to work from home though! Haha
Old 10-15-2013, 05:54 AM   #89
Fast_Freddy
Drives: Passat
Working at home while the rest of us wait patiently for updates = FAIL
It's this or FI for my FRS. Despite adding 25-30 whp my AT FRS still bogs badly on initial WOT. The serious lack of torque would be fine if I had a clutch to slip but in lieu of that I need some wheel spin and the leverage to get it. Looking forward to good news.
Fast_Freddy is offline   Reply With Quote
Old 10-15-2013, 11:06 PM   #90
PantsDants
SUCCESS!
Everything went together very smoothly. The only minor hiccup we ran into was that the IS300 carrier has axle stubs on it (the big wheel looking things on the sides) and the FR-S version does not. The IS300's axles are shorter and actually bolt onto these, whereas the FR-S axles just shove straight into the carrier. The spline pattern on the FR-S axle is identical to what's on the axle stubs though, so it's just a matter of popping them out.
As for my impressions of driving it, I can't give a full review just yet. Since the gears are brand new, they have to be broken in for a few hundred miles before I can really get on it. Just from babying it on the way home though, the only way I can describe it is that it feels like there's just less resistance to accelerate. Like the engine had been walking around with weights on and it just took them off.
I can't detect any gear noise coming from the back. Also the speedo is still dead on and the transmission shifts where it used to. Just higher revs while cruising on the freeway now, (sitting at almost exactly 2500 rpm when going 65) which on the stock exhaust is not any louder than where it was before. So far so good! I'll add more after I can have some real fun with it. I guess this was a complete success!
Now about those 3.9 gears... Who wants them?
The Following 4 Users Say Thank You to PantsDants For This Useful Post:
37 (10-16-2013), Fly Guy (04-22-2014), nos145 (10-16-2013), SportInjected (10-16-2013)
Old 10-15-2013, 11:09 PM   #91
Captain Insano
Great news! Let us know how it feels once broken in.
Captain Insano is offline   Reply With Quote
Old 10-15-2013, 11:10 PM   #92
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
Thank you.
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
The Following User Says Thank You to Mr. For This Useful Post:
Account Attempt No. 4 (06-29-2014)
Old 10-16-2013, 12:02 PM   #93
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
Originally Posted by PantsDants View Post
SUCCESS!
dear sir, what RPM is 75 mph at? That's my average cruising speed on hw. im just thinking how this will affect my fuel consumption.
Another questions i have... what do you think would be the effect of having similar set up and then having a turbo on top of it?
Thank you very much
nos145 is offline   Reply With Quote
Old 10-16-2013, 06:55 PM   #94
37
degrees
37's Avatar
Drives: 6MT BRZ
SUCCESS!
Nice! That's an accurate way to describe the effect. Glad to hear the 4.88 (most likely) turned out to be the right ratio for you. Keep us posted.
That's a bad idea. If anything you would want taller gears with a turbo, not shorter. Shorter gears + turbo means you'll have traction issues in gears 1-2-3 above and beyond what you might already have with a 3.9.
Get the turbo first and decide if you have traction issues down low. If you do then that's when you should consider changing your final drive with a taller (not shorter) ratio. However, if you have an automatic then I doubt you'll want to change anything since your transmission already makes the overall ratio taller.
37 is offline   Reply With Quote
The Following User Says Thank You to 37 For This Useful Post:
nos145 (10-17-2013)
Old 10-16-2013, 09:14 PM   #95
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Awesome! Now, who's the best person to talk to at weir about acquiring the right parts?
Thank you for being the guinea pig for this, your efforts are much appreciated.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
nos145 (10-17-2013)
Old 10-17-2013, 04:43 AM   #96
PantsDants
Thank you very much
Hit 75 briefly on the freeway just for you, it looked to be just under 3000 rpm. Keep in mind this is on the automatic transmission, and I didn't stay there for any appreciable length of time so it may actually be slightly lower than that at cruise.
As for a turbo setup, @37 is absolutely right. You'd want to go taller. It will both help with traction on the low end, and let you stay in each gear longer so you stay in boost. Now if you had something like a centrifugal supercharger that ramps up with rpm, then a lower final drive does make sense, because you get up to max boost faster. This may be the route I go if I decide to go FI.
@SportInjected, I'm going to make a more concise thread with all of the pertinent information in one post, so be on the lookout for that in a bit.
The Following 2 Users Say Thank You to PantsDants For This Useful Post:
nos145 (10-17-2013), SportInjected (10-17-2013)
Old 10-17-2013, 05:54 AM   #97
PantsDants
The final "recipe" for this swap can be found here: http://www.ft86club.com/forums/showthread.php?p=1275527
The Following 5 Users Say Thank You to PantsDants For This Useful Post:
Freeman (10-17-2013), JimmyMac (10-18-2013), mike_ekim1024 (10-17-2013), SportInjected (10-17-2013), uncivilised (10-17-2013)
Old 10-17-2013, 06:29 PM   #98
uncivilised
Drives: 86 GT
Thanks for this guide,
Trying to find a spare 86 lsd carrier for a decent price was difficult. As soon as you mention 86 the price is in the thousands lol
I have sourced an is300 lsd for a good price and I have some 4.55 diff gears to go into this, cant wait lol.
uncivilised is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 11:31 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
