Drives: FRS
Nameless or HKS front pipe?
I am looking for a front pipe to keep my exhaust note as tame as possible. Would I be better off with a high flow cat and helmholtz (as with the nameless), or two in line resonators (as with the HKS)?
#2 |
Nameless. You get the overpipe piece with it. Its by far the best designed front pipe on the market with custom options.
#3 |
Drives: FRS
Thanks for the plug. Trying to consider noise as the primary issue at this point. I do prefer the nameless from a design point. I just don't know enough about resonators to know which will keep the noise/rasp to a minimum.
#4 |
If you have something like the Perrin resonated, that resonator is massive. So is the stock midpipe one. Cat + Helmholtz is plenty to tame it. My nameless pipe has a second resonator in it but its still loud since its 3".
#5 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Rasp is caused by the thickness of the metal and flow of exhaust gas through the exhaust. The H-resonators won't do anything for rasp, they are there to fix or attenuate exhaust drone. Best way to reduce rasp would be wrapping it up in exhaust header wrap near the Y section.
I personally have used the HKS dual in-line front pipe with resonators, that was slightly louder than my MOTIV *CATTED* front pipe(which is slightly quieter now). Haven't had any experience with Nameless as I'm situated in Australia, and freight is a bitch of $$$ and even then when emailing the company a year ago, they would not ship it out. |
#6 | |
Boosted
Drives: Not a supra....yet
#7 |
#8 |
Drives: Pavement MT GR86
^^^we'll see as nameless hasn't been good at bringing stuff to market lately.
GR86 MT premium
#9 |
Drives: WR Blue BRZ, 240Z
If you get the Nameless front pipe with the cat, and you retain the stock manifold, you wont need the helmholtz resonator. I don't get any drone with my Nameless catted front pipe/axleback system. Others report the same.
This combo is how the exhaust should have sounded from the factory.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#10 | |
Drives: 2012 86
![]() Apart from HKS and Nameless are there anyone else making a DP with a resonator? |
#11 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
nameless,, wait a litter long.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#12 |
Drives: FRS
#13 |
Drives: 2013 Scion FR-S Raven
I have the Nameless Catted Helmholtz Equipped Pipe.
It fixed the rasp that the Perrin Catted Front Pipe couldn't. My Signature has the exhaust system details.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#14 |
Boosted
| Questions about Nameless Front pipe with Helmholtz Resonator | Xdragonxb0i | Engine, Exhaust, Transmission | 67 | 08-28-2016 12:47 AM |
| Sold, please close | pche | Engine, Exhaust, Bolt-Ons | 5 | 10-08-2013 08:10 PM |
| Nameless Over/down pipe? | umpadupa | Engine, Exhaust, Transmission | 8 | 10-06-2013 06:38 PM |
| FS-CA-Nameless Track pipe | executivekoala | Engine, Exhaust, Bolt-Ons | 2 | 09-23-2013 02:10 AM |
| P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? | Xdragonxb0i | Engine, Exhaust, Transmission | 23 | 04-24-2013 12:29 PM |
