Old 10-04-2013, 09:13 PM   #1
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
To those who modified their cars...rattles!?
Hi guys,
I just want to run a general consensus on this topic. I have recently started modifying my frs. I put stiffer coilovers in and also white line swaybars (18mm rear, 20mm front with end links). That's all for now and my car has become much stiffer and in my opinion more fun to handle.
However it has come at a cost! I am now hearing much more rattles and funny noises throughout the car. Is this a normal occurrence with cars that have been modified or do all modded cars except mine run super quiet like stock? I ask because I have never been in a real hardcore track car and am just wondering if there is seriously something wrong with my semi modded frs and these rattles I'm hearing. Or can it just be because the car is much more rigid from stock?
Thanks
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
Old 10-04-2013, 09:16 PM   #2
Burrcold
Drives: Subaru BRZ Limited
Any time you stiffen up the suspension you're going to get more rattles from the relatively cheap plastics in the interior. You're also going to have a better chance of clips, and little things coming loose.
The Following 2 Users Say Thank You to Burrcold For This Useful Post:
FutureFT86 (10-05-2013), Marchy (10-09-2013)
Old 10-04-2013, 09:25 PM   #3
vividracing
vividracing's Avatar
it's common. I have the same kind of setup in my Evo and i get a lot of rattling. The Sacrifice is well worth it.
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
Old 10-05-2013, 12:23 AM   #4
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Originally Posted by FutureFT86 View Post
Hi guys,
Thanks
Any car will rattle when you lower it and have stiff suspension. I have KW club sports on my E90 M3 and things do not ride smooth like stock.
Even my 2013 M5 you could slightly start to hear some creaking noises just on lower springs alone.
So no worries just crank up the music or get a nice exhaust
h4nh is offline   Reply With Quote
The Following User Says Thank You to h4nh For This Useful Post:
Old 10-05-2013, 12:37 AM   #5
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Try this 30s fix. Stopped most of my rattles after I put coilovers in http://www.ft86club.com/forums/showthread.php?t=42065
Takes 30s so you've really got nothing to lose trying it @FutureFT86
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Old 10-07-2013, 03:24 PM   #6
Pneub
Drives: Dark Grey BRZ
My car is pretty modified at this point and I noticed more rattles popping up. My rear deck and both my doors rattled especially when the audio was on. I decided to redo the audio in my car and while I was at it place in a good amount of hushmat. For $40 in hushmat the car was rattle free. Also the rear window light was rattling a lot so I opened it up and tightened everything down and the rattles went away. Good luck.
Pneub is offline   Reply With Quote
The Following User Says Thank You to Pneub For This Useful Post:
FutureFT86 (11-21-2013)
Old 10-07-2013, 03:34 PM   #7
B L U E S L A T E
Drives: BMW E84
Because race car. lol
B L U E S L A T E is offline   Reply With Quote
The Following User Says Thank You to B L U E S L A T E For This Useful Post:
Old 10-07-2013, 03:40 PM   #8
frslee
Just drive it
Drives: 13' FR-S
I'm prepared for more rattle in this winter.
frslee is offline   Reply With Quote
The Following User Says Thank You to frslee For This Useful Post:
Old 10-07-2013, 04:02 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My car rattled stock with only a few miles.
Old 10-07-2013, 08:46 PM   #10
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Haven't touched a fucking thing other than swapping the stereo for the newer one and it rattles like crazy. Fixed rattled from the trunk with WD-40. Driver's door lock and dash near the stereo have been rattling like crazy though.
Mandy is offline   Reply With Quote
The Following User Says Thank You to Mandy For This Useful Post:
Old 10-09-2013, 02:00 PM   #11
bakerr6
Drives: 2013 raven black fr-s
I have konis, mach v springs, new lcas and my car rattles like crazy. I just check the suspension every few weeks and that's all I care about haha.
The rattles are fine. I just need to get a sticker for the inside of my car that says "because racecar" so that my wife stops asking me why my car does "x" that she doesn't like.
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
Old 10-09-2013, 04:57 PM   #12
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
-Just think of it this way- The more you modify a car with "track" oriented parts, the less "street conveniant" the car becomes. So yes its normal to start hearing more squeeks and rattles as you stiffen and lower the vehicle. But it becomes more FUN
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
CAMBAM_6 is offline   Reply With Quote
The Following User Says Thank You to CAMBAM_6 For This Useful Post:
Old 10-11-2013, 11:32 AM   #13
gily25
Drives: Silica BRZ 6MT
Get some insulation foam [ame="http://www.amazon.com/4026-Double-Sided-Foam-Tape-Squares/dp/B005S4GWA0"]the double backed 3m type[/ame]. You can usually buy a bag of squares. Try to figure out the pressure point on each panel that rattles (you'll probably have to have someone else drive while you investigate), then pull away the panel and put the foam under that point to stop the rattle. I recommend the foam because it's lighter than dampening mat but you could use squares of dynamat/raamat/crazy cowboy/etc.
gily25 is offline   Reply With Quote
The Following User Says Thank You to gily25 For This Useful Post:
Old 10-11-2013, 02:02 PM   #14
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
My headliner rattles, but was worse w/ headers/overpipe/exhaust before the turbo upgrade.
What's funny is if I push on it, whatever's rattling behind it stops--but I get tired of holding it after a while... lol
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 11:24 PM
How to stop exhaust rattles? IAmNotTheDriftKing Engine, Exhaust, Transmission 13 09-27-2013 07:17 PM
Hard to fix rattles qoncept Electronics | Audio | NAV | Infotainment 6 07-17-2013 04:32 AM
Stereo rattles FR-anco89 Issues | Warranty | Recalls / TSB 2 04-19-2013 08:44 AM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 04:07 PM
