Old 02-03-2013, 12:57 AM   #1
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
Exclamation Passenger Door Courtesy Light Wont Turn Off
As stated the passenger door courtesy lights do not turn off at all.
Even when the car is off.
I accidentally squished the housing of the door light and now it wont turn off at all.
Also its on constantly at a dim setting compared to usual.
Help please.
zex is offline   Reply With Quote
Old 02-03-2013, 01:00 AM   #2
Mo707
Mo707's Avatar
Close the door?
Mo707 is offline   Reply With Quote
Old 02-03-2013, 01:43 AM   #3
zex
zex's Avatar
Originally Posted by Mo707 View Post
Close the door?
Thanks.
Maybe if you read it and received proper education you would understand "at all" to mean that in no situation will the light turn off unless there is no bulb or disconnected from the wiring, which would be common sense.
Old 02-03-2013, 01:51 AM   #4
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Try taking off the housing of the lens as you may of squished the contact points.
I assume the driver side is okay, so it may also be the door switch as well... Then again if it is...then your window would not respond at all either if you open/close the door.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 02-03-2013, 02:36 AM   #5
Mo707
Mo707's Avatar
Try disconnecting then re connecting the battery.
The Following User Says Thank You to Mo707 For This Useful Post:
zex (02-03-2013)
Old 02-03-2013, 12:05 PM   #6
zex
zex's Avatar
I tried switching the driver side over to the passenger side and it still doesnt work
Old 10-04-2013, 01:38 PM   #7
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Any follow up on this issue? Did warranty replace the BUI or they made you pay?
Had the same issue happen to me today with a brand new 3 day old 2014 BRZ dealership service people trying to blame it on the LED's which is BS because they are same voltage and consume even less power and noone else that i know had the issue with their LED's..and bulb works perfect on the driver side but not on the passenger side
Help please if someone knows
tdotBRZ is offline   Reply With Quote
Old 10-04-2013, 01:54 PM   #8
Migero86
Migero86's Avatar
Drives: 2015 Trailhawk
Happened to a buddy of mine on his new (2013 MY) car and dealer replaced a module.... shrug. he had LEDs in there as well.
Migero86 is offline   Reply With Quote
Old 10-04-2013, 01:55 PM   #9
tdotBRZ
tdotBRZ's Avatar
Did he put halogens back before going to the dealer? did the warranty cover it? did he put LED's back after it got replaced and it works fine now?
Old 10-04-2013, 01:57 PM   #10
Migero86
Migero86's Avatar
Sorry... Yes... Warranty covered it, Kept the LEDs in the whole time and they work now as well.
Old 10-04-2013, 02:00 PM   #11
tdotBRZ
tdotBRZ's Avatar
Lucky..Stupid dealer service people trying to blame it on LED's now and saying might not be warrantied...even though has nothing to do with LED's as they are same voltage and even less power than halogens..and all the other LED's work fine just that passenger courtesy one doesnt such BS that they are trying to give me..pisses me off
Old 10-04-2013, 02:05 PM   #12
Migero86
Migero86's Avatar
Sorry to hear that man.... Some dealers are just better then others when it comes to keeping the customer happy post sales.
Old 10-04-2013, 02:31 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I am not expert but i had this module issue after installing LEDs on RSX-S back in time. ever since that, i don't install LEDs in interior. module itself is very expensive. my suggestion is to visit different dealer but put back to OEM bulbs
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 08:15 AM
Door Ajar Light will not turn off Aznek Issues | Warranty | Recalls / TSB 15 02-02-2015 10:40 AM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 09:39 AM
LED WHITE COURTESY FOOT LIGHT- Group Buy F-T Exterior Parts - Lighting 2 03-04-2013 05:59 AM
