CANADA Canada
Old 10-02-2013, 10:53 PM   #1499
Rutter
Rutter's Avatar
Drives: 13 Hot Lava FR-S AT
So harbinger, mountainside, thorlius and I are meeting at the gas station on the corner of king and fairway at 6:40 tomorrow to roll out as a small group, any other k-w people care to join? :-)
Sent from my Nexus 7 using Tapatalk 4
Rutter is offline   Reply With Quote
Old 10-02-2013, 11:02 PM   #1500
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
Originally Posted by Rutter View Post
That works for me lol, you guys want to meet up somewhere and cruise out together? Its on the far side of Guelph so fairway road is the quickest route. I know @thorlius lives close as well, could do a mini cruise :-)
Sent from my Nexus 4 using Tapatalk 4
I hope you're all ready to !
thorlius is offline   Reply With Quote
Old 10-03-2013, 10:53 AM   #1501
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Anyone here have a successful install of an aftermarket headunit? I just got my new Pioneer Z150BH in and am contemplating how I want to install it...Want to make sure it's 100% done properly and everything (wiring, etc.) is tucked away neatly.
A few concerns are
- routing the new mic since OEM isn't compatible
- routing GPS antennae to a good spot
- cost
Just wondering if anyone has a guy that did it for them or whether someone followed a really good DIY with no issues?
Thanks
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
Old 10-03-2013, 11:08 AM   #1502
Harbinger of Darkness
Front Toward Enemy
Harbinger of Darkness's Avatar
Drives: Asphalt 6MT
A few concerns are
- cost
Thanks
I've installed my own in several vehicles (including my 86). I'm more than willing to help an install. I'm free most week days after 3 and weekends. A new head unit is about a 20 min install with 20 min of soldering before hand. Shoot me a PM and I'll find a time to walk you through it.
Sent from my HTC One X using Tapatalk 4
I spent a lot of money on booze, birds and fast cars - the rest I just wasted. -George Best
Harbinger of Darkness is offline   Reply With Quote
The Following User Says Thank You to Harbinger of Darkness For This Useful Post:
tiz22 (10-03-2013)
Old 10-03-2013, 04:44 PM   #1503
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
A few concerns are
- cost
Thanks
Yup super simple. I didnt have to mount a GPS antenna but I would say it would be most out of the way on the rear parcel shelf... but thats a lot of extra wiring routing. Im sure harbringer will steer you right. I mounted my mic using a tiny piece of 2 sided tape on the top of my steering column right next to the gauge cluster. Its nearly invisible and gets great audio. Others have run the mic up into the roof to where the OEM one is.
Best of luck on the install! I would also recommend a relay to allow your passengers to watch videos on the road... and remove other stupid pioneer limitations that despite being for your safety are downright annoying.
RandomHero is offline   Reply With Quote
Old 10-03-2013, 10:20 PM   #1504
tiz22
tiz22's Avatar
Can I just ground out the parking brake wire? I would rather make it as discrete as possible I've heard using those relays can get you into trouble insurance-wise if they ever find it after an accident
Old 10-04-2013, 05:35 PM   #1505
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
You cant ground it on the new head units because it requires a special sequence to signal the safety feature. In Pioneers case I think they are all OFF-ON-OFF-ON. You can wire in a switch to the ground wire which should work? however I think it needs to go from seeing Positive to Negative signal so it cant just be a simple on/off. Don't quote me on that part though because I used a relay...
Regardless it is no longer as simple as grounding out the park wire.
Old 10-05-2013, 01:24 AM   #1506
tiz22
tiz22's Avatar
Can you link the relay you used?
Old 10-05-2013, 03:54 PM   #1507
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
I actually used a standard automotive relay available at Canadian Tire for around $5. http://www.caraudioforumz.com/instal...bypass-263025/
that link will give you the info you need about how to wire it. If you want to go the "official route" this [ame="http://www.amazon.com/AVH-X1500DVD-AVH-X2500BT-AVH-X3500BHS-AVH-X4500BT-AVH-X5500BHS/dp/B00A9AQPUU/ref=sr_1_1?ie=UTF8&qid=1380999115&sr=8-1&keywords=pioneer+bypass"]Amazon.com : Parking Brake Override Bypass Fully Automatic Video in Motion for Pioneer Models AVH-X1500DVD AVH-X2500BT AVH-X3500BHS AVH-X4500BT AVH-X5500BHS : Electronics[/ame] is the prebuilt one from amazon but i couldnt find it easily in Canada.
Let me know if you need anymore help. Do a little research and make sure the Z150 uses the same double pulse as the X5500 (which is what I have). I cant find any official documentation on it.
Old 10-06-2013, 03:23 PM   #1508
Davr
Davr's Avatar
Drives: Scion 10 series FR-S / MT
just thought I'd say hi to the people in the KW area, picked up my new FR-S a few days ago. newbie question: how do i upload pics? and anybody know a good place to get my windows tinted?
Davr is offline   Reply With Quote
Old 10-06-2013, 11:34 PM   #1509
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Welcome to the group.
Attaching a picture is done with the paper clip, but, the challenge is to come within the site's pixel sizing restrictions. I usually go old school and use MS Paint to resize, but, you can link to any pic sharing sites (just have to set the correct permissions) using the same paper clip function.
I had my tint done through Ziebart Glass next to Guelph Toyota and Scion, but, they (Guelph Scion) do it as well (they can chime in and correct me if I am wrong). Mine is pretty decent, but, I have heard that Ziebart can be inconsistent. There are numerous places unless you have your sights set on ceramic or something like Huper Optik (very premium).
Demandred7 is offline   Reply With Quote
Old 10-07-2013, 07:43 AM   #1510
mountainside
// how hard can it be?
mountainside's Avatar
Drives: 10 series frs : 6MT
Not a good place - Heffner Toyota. Got our tint done there at the same time as some bodywork after being rear ended and there are some pretty bad air bubbles (and a hair!) under the tint.
Sent from my SGH-I747 using Tapatalk 4
mountainside is offline   Reply With Quote
Old 10-07-2013, 10:07 AM   #1511
jamies31
jamies31's Avatar
Drives: 2014 Scion Frs (Argento)
our guys here do amazing work, and if they dont they are always happy to warranty pretty much anything, they do all my demos i wouldnt drive with out it now.
Ziebart was a great place to get your tint done, we used them all the time then a few years back they switched owners and quality went downhill hill,
jamies31 is offline   Reply With Quote
Old 10-07-2013, 10:20 AM   #1512
tiz22
tiz22's Avatar
that link will give you the info you need about how to wire it. If you want to go the "official route" this Amazon.com : Parking Brake Override Bypass Fully Automatic Video in Motion for Pioneer Models AVH-X1500DVD AVH-X2500BT AVH-X3500BHS AVH-X4500BT AVH-X5500BHS : Electronics is the prebuilt one from amazon but i couldnt find it easily in Canada.
Got it all installed today! Thanks to both of you for the help really appreciated it....took me way longer than a professional install would have taken but I saved 100$+ which I will now spend on other stuff
Wrote a quick DIY if anyone wants to check it out
http://www.ft86club.com/forums/showthread.php?t=48505
*Last thing I have to figure out is what I want to do with e-brake...I wired it up properly (legally) for now to see if I can live with it but I may have to go the relay route.
D-4S Thread WingsofWar Engine, Exhaust, Transmission 85 03-31-2020 05:25 PM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 01:24 PM
New thread, because new thread because new thread _hollywood Off-Topic Lounge [WARNING: NO POLITICS] 9 02-01-2012 12:49 AM
The "if you wanna kiss the backside of white musicians make a thread about it" Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 8 12-19-2011 08:59 PM
