Old 10-03-2013, 12:24 AM   #1
brn12345
brn12345's Avatar
Part throttle faster than full throttle
I noticed that when I am accellerating using half throttle and then push the pedal to full that the car seems to accelerate slower or bog. Has anyone experienced this?
brn12345 is offline   Reply With Quote
Old 10-03-2013, 12:54 AM   #2
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
I've only noticed full throttle bogging when I go from no/light throttle to full throttle at lower rpm's, and it only lasts for a second. When I go from half throttle to full throttle, there is a notable increase in acceleration for me.
Hanni_0176 is offline   Reply With Quote
Old 10-03-2013, 01:01 AM   #3
ft_sjo
Drives: GT86
Stock or remapped?
Old 10-03-2013, 01:09 AM   #4
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Actually yeah I was thinking about that two days ago. I feel that our car reacts more around 4 rpm.
Kelbyat07 is offline   Reply With Quote
Old 10-03-2013, 02:54 AM   #5
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I noticed the same thing today as I was heading home. Floored it trying to cut around traffic and felt the bog as you've described at full throttle. Slightly annoying, not sure what could fix this.
ck-GT86 is offline   Reply With Quote
Old 10-03-2013, 04:54 AM   #6
brn12345
brn12345's Avatar
Originally Posted by ft_sjo View Post
Stock or remapped?
Stock.
Old 10-03-2013, 09:36 AM   #7
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
I noticed the bogging on WOT with the stock map too
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 10-03-2013, 09:39 AM   #8
350matt
Drives: toyota mr2/ Toyota GT86
In theory you may get a gain lower in the rev range with a slightly closed throttle as this keeps the gas speed up but as you approach higher rpm the throttle will then need opening up
is this the case?
350matt is offline   Reply With Quote
Old 10-03-2013, 09:58 AM   #9
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I believe you're just feeling the torque dip fellas!
Subaru STI :
Old 10-03-2013, 10:34 AM   #10
mid_life_crisis
Drives: FR-S 10 #103 AT
Exactly. You only notice it when you stomp on the gas and expect to go somewhere.
This is definitely a driver's car. That doesn't just mean it's fun for a good driver. It also means you have to drive it well to get anything out of it, but it will reward you if you do. When you find yourself in a situation where you anticipate a likely need for sudden acceleration, downshift so you are above the torque dip and ready to go. When you stand on it, the car will take off nicely. Takes a little getting used to cruising along at 50 or 60 with the engine buzzing at 5,000 rpm but it works and it isn't usually for very long.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-03-2013, 01:48 PM   #11
yohan04
yohan04's Avatar
Drives: Your sister
Could be, but it also could be the fact when we're going WOT, we're expecting the force of acceleration (151lbs of fury!), so our bodies naturally tense up and bracing ourselves and therefore numbing the sensation.
I always feel like my 450+whp STI is slow when I drive it but, when someone else is driving and I'm in the passenger seat, I'm like
Just a theory
yohan04 is offline   Reply With Quote
Old 10-03-2013, 02:22 PM   #12
Squishy
Drives: 2013 WRB BRZ
http://www.avoturboworld.com/avoshop...2007-p-58.html
Seems that we all notice this behavior in late model Subaru's and drive by wire systems.
Squishy is offline   Reply With Quote
Old 10-03-2013, 05:09 PM   #13
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
thats most small engines.. goin full throttle at a low rpm is jus flooding the engine with air that it cant use yet, which is also compensated with more fuel
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 10-03-2013, 05:36 PM   #14
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
I noticed a while ago that after about 3/4 peddle there is no diff in power if I floor it. Thats in any gear any rpm. I believe it to be the drive by wire as well.
youcantseeme24 is offline   Reply With Quote
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
