Old 10-02-2013, 07:49 AM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
OEM lug nuts the lightest?
So I've been looking into lug nuts, and based on this photo:
...the OEM lug nuts are the lightest I've found so far. Although I admit I kind of stopped looking once I realized they might be lighter than Rays. I'm suspecting maybe that scale is just not precise or accurate at such small weights?
Originally Posted by Anthony View Post
Lug nuts (x5)
0.59lbs - Muteki SR48 (Source)
0.44lbs - Muteki SR35 (Source)
0.41lbs - Gorilla Chrome Tuner (Source)
0.25lbs - Rays Engineering (Source)
0.25lbs - VMS Racing (Source)
0.20lbs - OEM (Source)
That just doesn't seem right. Maybe I screwed up the math? @JRitt?
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-02-2013, 09:30 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
use grams for lug nuts
Old 10-02-2013, 09:33 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yes, that scale doesn't look like it would be accurate for such a small size
also race application lugs are usually larger/longer for reasons of utility and strength
Old 10-02-2013, 09:34 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Yeah, that makes more sense. I'll convert them later, but still, the numbers will still convert to lower numbers for OEM vs. the others.
Old 10-02-2013, 09:38 AM   #5
Anthony
Weight Nazi
Anthony's Avatar
Once I get home (only 2 more months to go!!!) I'll be happy to weigh the stockers on a smaller scale and in grams. But until then, if someone wants to be heroic...
Old 10-02-2013, 12:32 PM   #6
xwd
I weighed mine on a decent small scale and apart from the really light aluminum ones they are lighter. The OEM lugnuts don't weigh much at all. The issue for me is the lug seat area on them isn't very long so if you are using aftermarket rims you probably don't want to use them. But for OEM rims I wouldn't bother with anything else unless you want to switch colors, are using longer studs, etc.
The Following User Says Thank You to xwd For This Useful Post:
Anthony (10-02-2013)
Old 10-02-2013, 01:29 PM   #7
CSG David
CSG David's Avatar
Shameless plug. CSG aluminum lugnuts are tested through rally and track conditions. A set of 20 lugs weighed in at 13 ounces (368.5 grams), or approximately 0.04 lbs (18.4 grams) per lug nut. Weight was done by third party individual: @Captain Insano.
http://www.ft86club.com/forums/showp...1&postcount=21
We have some ultra heavy duty lug nuts made from chromoly steel coming in for the guys who want to absolutely thrash their lug nuts to hell. They are 0.11lbs (49.9 grams) each. A sample of lug nuts were salt fog/environmentally tested to test the durability of the rust-resistant coating as well with certificate.
The Following User Says Thank You to CSG David For This Useful Post:
Anthony (10-03-2013)
Old 10-02-2013, 03:54 PM   #8
simpleisbest
Senior Citizen
Drives: Scion FR-S
OEM lug nuts suck. The internal threads seem to be soft and easy to damage. They definitely do not hold up well to regular mounting and dismounting, even if handled with care.
Personally, I don't think there is much "speed" to be found in lug nuts alone, unless you are in a racing class that allows for a huge range of mods. I look for reliability and convenience of use.
I wanted a cheap fix and picked up a set of these steel ones a while back and they are great! Just long enough that they are easy to handle and thread on by hand and being steel, there is no worries that they will stretch with heat.
http://store.arkdesign-us.com/Wheel-...HORT_p_51.html
They use a 17mm, so being slightly narrower than stock (19mm) is good if you have have any clearance issues with your aftermarket rims.
simpleisbest is offline   Reply With Quote
Old 10-02-2013, 04:56 PM   #9
Anaxilus
Drives: They have four wheels
How often have you guys had to retorque them between sessions? I've always avoided aluminum due to stories of them backing out or coming loose due to different thermal expansion rates w/ steel lug bolts.
Anaxilus is offline   Reply With Quote
Old 10-02-2013, 05:27 PM   #10
CSG David
CSG David's Avatar
Haven't had to retorque any of the lugs.
Old 10-02-2013, 06:31 PM   #11
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Gorilla forged aluminum are lighter than stock. Please refer to my wheel thread.
http://www.ft86club.com/forums/showthread.php?t=38679
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
Old 10-03-2013, 01:14 AM   #12
Anthony
Weight Nazi
Anthony's Avatar
Thanks for the info, guys. Updated my post: http://www.ft86club.com/forums/showp...&postcount=147
Old 10-03-2013, 01:24 AM   #13
Porsche
Drives: 2013 BRZ Ltd. MT
I dug up my OEM 2013 Subaru BRZ lugnuts and weighed them for you.
1 lugnut = 25 g (actual measurement)
5 lugnuts = 125 g (4.40925 oz., or 0.27558 lbs.) (actual measurement)
10 lugnuts = 250 g (actual measurement)
I weighed them on an accurate scale that measures in 1 g increments. I then measured 100 U.S. pennies as a reference check, and found it accurately measured 250 g, as it should. So, I think you can trust this measurement. Note that the lugnuts were not scrubbed clean and a 0.1 g scale would measure a bit of brake dust adhering to these dirty lugnuts. I hope this degree of accuracy is sufficient for your needs.
Stay safe.
And, thank you for your service.
Porsche is offline   Reply With Quote
The Following User Says Thank You to Porsche For This Useful Post:
Old 10-03-2013, 02:21 AM   #14
Anthony
Weight Nazi
Anthony's Avatar
Stay safe.
Nice! And 125g is only .3 grams off of what I already had listed, so it's good to know peoples' scales are reading so close. I'll use this as an additional reference.
Lightest wheels for the $$$ - besides the RPF-1's SubieNate Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 109 02-04-2016 05:50 PM
Lightest Brakes or BBK? Anthony Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-11-2015 03:33 PM
What are the lightest wheels for this car? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 10-15-2014 06:56 PM
Lightest 18 inch tire ysr50guy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-27-2013 11:59 AM
Top 10 Lightest 300 Horsepower Cars Axel Other Vehicles & General Automotive Discussions 2 11-22-2009 03:23 AM
