#2003 |
Drives: VW
#2004 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Has there been an issue with hot air?
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#2005 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Not for me, we had some hot weeks at the tale end of summer plus 28c, noticed a little less timing but no fail safe issues
Sent from my SGH-I337M using Tapatalk 4 |
#2006 |
Is there a reason the controller isn't stored inside the car?
#2007 |
Drives: 2013 FR-S, 1995 Civic Coupe
Would the flat foot shifting mod for ecutek racerom allow you to stay in boost through several gears?
#2008 |
Drives: WR Blue BRZ, 240Z
The way flat foot shifting works is it opens and closes the throttle plate to maintain rpm. The problem with this while using the ESC is that the compressor is still turning and we don't have a BOV. Now, at max rpm, the ESC isn't making a heck of a lot of pressure, but it just seems (to me) that closing the throttle plate while spinning a compressor without any way to relieve the pressure might lead to problems. I say "might" because I don't know this for sure, but just to be safe I didn't include that feature (or launch control) on my ECUteck tune.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | asher187 (09-27-2013) |
#2009 | |
![]() Sent from my HTC One using Tapatalk 4 |
#2010 |
#2011 |
controller placement
Sometimes I just can't help myself with my completely insane ideas.... Insane Idea #991 Mount it inside the air filter box PRE-filter so it can in no way be accidently sucked in (3m 2sided tape) ? theres room and it's a cool air charge /shrug |
#2012 | |
Drives: 2001 NB MX-5
A bypass is actually a neat idea because it would bleed boost in the region where the CEL triggers but would allow full boost in the higher RPM. Then again I always look for the mechanical solution for a problem. -Grant |
#2013 |
Drives: 2013 BRZ | 2013 WRX | 1991 318i
I think I am considering this option, but a few things still don't quite feel right. First, given the rpm limitation of this system it will only be useful up to a certain cfm. My guess is that once you bolt this on there will be minimal gains from additional mods, such as headers and exhaust. People that have already invested in na mods that gave them 20% gains might only get a fraction of what is advertised for the ESC. Again, the reason being that unlike turbos and belt driven SC, this system has a static output.
Still seems like a great system for the person that is certain it will be their only mod. The other thing I can't wrap my brain around is why turbos and SC systems have evolved to generate the power curves which are common today. It would be possible to engineer any FI system to offer the power in a similar distribution as the ESC. Seems to me that their are practical reasons for this, and over time the user of this system would discover them. I have no idea what I am talking about so please feel free to ignore. Also, I've read this entire thread in a single sitting and can't see straight at the moment... |
#2014 |
Drives: series 10 FR-S (2361)
interesting comment ... the low end torque/response is were this system seems to shine ... imagine a hybrid system (ESC and SC) getting the best from both worlds. That would allow a larger SC (ESC disengaging once the Large SC was at full tilt) giving higher numbers in the top half of the curve.
#2015 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#2016 | |
If it's running full out and doesn't need to be, it's wasting electricity, so I'd rather limit boost with the controller than a bypass.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
