#15 |
Drives: 2013 Asphalt FR-S
can we get some more folks to check their IAM and see if it resets? To be clear, i want to know if the IAM resets to the original IAM value when the car sits overnight.
So, if you start it in the am and the IAM is .7 and as you drive it works up to say 1.0. Does it stay at 1.0 over night or does it reset back to .7 the following am? @feldy, maybe we should create a poll or something?
~Namaste~ |
#16 |
Drives: 2013 FRS Asphalt
From Toni IAM is always reset to .7 or 1.0 depending on where I set it for the customer after each flash
I'm thinking its this way incase of bad gas or something?
2013 Scion FR-S AT Picked up 5/30/2012
| The Following User Says Thank You to feldy For This Useful Post: | SportInjected (09-24-2013) |
#17 |
NASA SpecE30 Racer
Yep, that is normal after a reflash, but it should not be reset after sitting overnight.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#18 |
Mine always resets when the car has been sitting.
#19 |
same,
what is your rom id? im on ZA1JA00C To be clear guys, we are not talking the iam resetting after a reflash, that is normal. We are talking about the IAM resetting after the car sits for a couple of hours, no flashing involved.
~Namaste~ |
#20 | |
I'm on ZA1JA01D now. But I started on ZA1JA00D On my E85 tune it jumps up to 1 with in ten minutes of the car being on. On pump gas it takes a bit longer.
#21 | |
Grip>Slip
#22 |
That guy
Drives: Ultramarine mt FR-S
I will test this tonight after work, and tomorrow after an overnight sit.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
| The Following User Says Thank You to Hawaiian For This Useful Post: | mad_sb (09-25-2013) |
#23 |
My observations are subjective and I can't see what the IAM is doing, but after a hard drive (ex. autox) the car is noticeably quicker for the next few driving cycles, even driving to work the next day. I always assumed this was because the IAM had ramped up with learning with the high engine loads and rpms, and would then back off to a lower number with daily driving. This is quite consistent and within a couple of days of daily driving it is back to feeling "normal". This is with 94oct gas.
#24 |
IAM doesn't ramp down unless the ecu believes knock is present or the iam resets after key off like myself and feldy are seeing.
You do have to be "on it" for the IAM to increase though, not neccesarily wot, but you do need to work the rev range with a little bit of load for the ecu to decide to click the IAM up then it re evaluates. So, it is very possible you are seeing the same thing, but we won't know unless you can log the IAM
~Namaste~ |
#25 |
what build date and rom ID?
I have a feeling it is build date related more than rom id. I will post up my build date tonight.
~Namaste~ |
#26 |
Grip>Slip
#27 |
my build date is also 4/12
#28 | |
Were you able to do any logging?
| iPhone plugged in via USB not acknowledged after restart | OnTheFence | Electronics | Audio | NAV | Infotainment | 5 | 08-20-2013 10:47 AM |
| Tein Street Advance 99c NR | 86drift | Australia Classifieds | 0 | 05-23-2013 05:06 AM |
| Help NEEDED ASAP, Thanks in advance! | FR_Soldier_77 | Other Vehicles & General Automotive Discussions | 9 | 03-20-2013 10:10 AM |
| YR-Advance | ANREX | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 10-31-2012 09:08 AM |
