Old 09-24-2013, 05:55 PM   #15
mad_sb
Drives: 2013 Asphalt FR-S
can we get some more folks to check their IAM and see if it resets? To be clear, i want to know if the IAM resets to the original IAM value when the car sits overnight.
So, if you start it in the am and the IAM is .7 and as you drive it works up to say 1.0. Does it stay at 1.0 over night or does it reset back to .7 the following am?
@feldy, maybe we should create a poll or something?
Old 09-24-2013, 06:59 PM   #16
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
From Toni IAM is always reset to .7 or 1.0 depending on where I set it for the customer after each flash
I'm thinking its this way incase of bad gas or something?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
SportInjected (09-24-2013)
Old 09-25-2013, 11:52 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep, that is normal after a reflash, but it should not be reset after sitting overnight.
Old 09-25-2013, 12:09 PM   #18
feldy
feldy's Avatar
Mine always resets when the car has been sitting.
Old 09-25-2013, 01:42 PM   #19
mad_sb
same,
what is your rom id? im on ZA1JA00C
To be clear guys, we are not talking the iam resetting after a reflash, that is normal. We are talking about the IAM resetting after the car sits for a couple of hours, no flashing involved.
Old 09-25-2013, 02:08 PM   #20
feldy
feldy's Avatar
Originally Posted by mad_sb View Post
same,
I'm on
ZA1JA01D now. But I started on ZA1JA00D
On my E85 tune it jumps up to 1 with in ten minutes of the car being on. On pump gas it takes a bit longer.
Old 09-25-2013, 02:25 PM   #21
xjohnx
Grip>Slip
xjohnx's Avatar
Mine sat overnight and did not reset.
Old 09-25-2013, 02:27 PM   #22
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I will test this tonight after work, and tomorrow after an overnight sit.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
mad_sb (09-25-2013)
Old 09-25-2013, 02:31 PM   #23
R2
My observations are subjective and I can't see what the IAM is doing, but after a hard drive (ex. autox) the car is noticeably quicker for the next few driving cycles, even driving to work the next day. I always assumed this was because the IAM had ramped up with learning with the high engine loads and rpms, and would then back off to a lower number with daily driving. This is quite consistent and within a couple of days of daily driving it is back to feeling "normal". This is with 94oct gas.
R2 is offline   Reply With Quote
Old 09-25-2013, 03:17 PM   #24
mad_sb
IAM doesn't ramp down unless the ecu believes knock is present or the iam resets after key off like myself and feldy are seeing.
You do have to be "on it" for the IAM to increase though, not neccesarily wot, but you do need to work the rev range with a little bit of load for the ecu to decide to click the IAM up then it re evaluates. So, it is very possible you are seeing the same thing, but we won't know unless you can log the IAM
Old 09-25-2013, 03:18 PM   #25
mad_sb
what build date and rom ID?
I have a feeling it is build date related more than rom id. I will post up my build date tonight.
Old 09-25-2013, 03:23 PM   #26
xjohnx
Grip>Slip
xjohnx's Avatar
build date is April 2012.
rom ID is ZA1JA01C
Old 09-25-2013, 03:56 PM   #27
feldy
feldy's Avatar
my build date is also 4/12
Old 09-26-2013, 04:31 PM   #28
feldy
feldy's Avatar
Were you able to do any logging?
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 10:47 AM
Tein Street Advance 99c NR 86drift Australia Classifieds 0 05-23-2013 05:06 AM
Help NEEDED ASAP, Thanks in advance! FR_Soldier_77 Other Vehicles & General Automotive Discussions 9 03-20-2013 10:10 AM
YR-Advance ANREX Cosmetic Modification (Interior/Exterior/Lighting) 11 10-31-2012 09:08 AM
