Old 09-23-2013, 02:04 PM   #1
slowbrz
Drives: '13 black BRZ MT
Can I drive with 29psi in my tire
My tires are at: 29, 30, 31, 32 psi respectively and use nitrogen.
From my understanding, only dealerships offer nitrogen for tires.
Is it safe for me to drive 10-15 miles to go to the dealership?
Does my warranty cover nitrogen to inflate my tires at the dealership?
slowbrz is offline   Reply With Quote
Old 09-23-2013, 02:08 PM   #2
OrbitalEllipses
Drives: Attitude
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
7thgear (09-23-2013), HunterGreene (09-23-2013)
Old 09-23-2013, 02:10 PM   #3
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Ok you are fine. Dealerships are not the only ones. Most tire shops have them. do not freak out warranty is fine. You can even put normal air into the tires. I know its crazy but its true.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-23-2013, 02:13 PM   #4
Slash
Slash's Avatar
Drives: 2013 FRS
This forum. I can't even...
Sent from my SGH-T999 using Tapatalk 2
Slash is offline   Reply With Quote
The Following 3 Users Say Thank You to Slash For This Useful Post:
7thgear (09-23-2013), OrbitalEllipses (09-23-2013), wparsons (09-23-2013)
Old 09-23-2013, 02:14 PM   #5
Dezoris
Dezoris's Avatar
29PSI is totally fine just don't be doing any high load turns as you will roll those tires over on the side wall much easier.
Old 09-23-2013, 02:16 PM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
Old 09-23-2013, 02:22 PM   #7
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
15 miles is ok. Once you hit 16 your car will explode.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-23-2013, 02:26 PM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
NO ONE, ever, will guarantee or warranty you the pressures in your tires.
And while your tires come with low pressure indicators, you should MAKE IT A HABIT to inspect your tires occasionally by using a tire pressure gauge.
Nitrogen or Air don’t make a difference, for everyday driving you’re not gaining anything by using nitrogen. Use a normal compressor to pump it up and call it a day.
Pressure differences across the tires don’t make much of a difference for daily commuting either, but generally keeping them uniform is good practice.
Welcome to the world of car ownership… it's a sad day in panda land that you are one but I’m sure as hell glad that you’ve come here with questions.. I suggest you ask a lot of them any time something comes up with your car.
And don’t go to the dealership… for anything.
The Following User Says Thank You to 7thgear For This Useful Post:
Muskokan (09-23-2013)
Old 09-23-2013, 02:28 PM   #9
HunterGreene
Hail Magnet
HunterGreene's Avatar
The atmosphere is 78% Nitrogen, so really, all our tires are filled with (mostly) Nitrogen.
TL: DR--Don't waste your money getting nitrogen fillups. There is no benefit.
P.S.--you're fine. Just go top off your tires. No warranty concerns, just increased tire wear.
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
King Tut (09-23-2013)
Old 09-23-2013, 05:09 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yes.
No.
I would instead buy your own air compressor and add some 78% nitrogen air to get the tires back up to 35 psi cold.
Old 09-23-2013, 05:46 PM   #11
chutrain
chutrain's Avatar
Drives: WRB BRZ
Nitrogen tends to maintain pressure better over time and no influence by temperature, so a track situation, the benefits are better exploited. However, for normal daily driving you are better off using regular air. If you do not have an air compressor, you can fill up at any gas station. You won't have to worry about finding a shop that can fill.
But keep in mind, once you introduce air to a nitrogen fill you will need to have the the wheel and tire combo reprepped if you go back to nitrogen. They will need to completely remove all the air and then refill with nitrogen. They will charge extra for that.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
The Following User Says Thank You to chutrain For This Useful Post:
Old 09-23-2013, 05:53 PM   #12
HunterGreene
Hail Magnet
Most of your information is correct...but nitrogen is affected by temperature the same as any other gas. The pressure change may be less, simply because its a single gas as opposed to an atmospheric mixture. If you really want a fill thats not affected by temperature, fill it with a liquid.
Old 09-23-2013, 06:47 PM   #13
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Go to Costco - free nitrogen. The station is usually situated right outside their Tire Service area.
Anthonytpt is offline   Reply With Quote
Old 09-23-2013, 06:55 PM   #14
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
When we took delivery of my wife's CR-V the dealership had done the Nitrogen trick. I was happy enough with the deal we got not to make an issue over their little trick to get some more money out of our pocket. The few times we've had to raise the pressure in the tires I just use my home air compressor. Nothing will be harmed by mixing the two.
whaap is offline   Reply With Quote
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 04:59 PM
Saturday 3/23 DRIVE: Last chance to drive "The Most Dangerous Road in California" PMok Northern California 173 05-02-2013 03:11 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 09:30 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 12:14 PM
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 04:13 PM
