Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 09-17-2013, 08:44 AM   #1499
MFB
Avo Turboworld Phil Rep
Drives: Forester 2009 XT on e85
Hi Jeff,
Yes via ecutek thru Avo Turboworld.
MFB is offline   Reply With Quote
Old 09-17-2013, 11:12 AM   #1500
pearlhatchiroku
pearlhatchiroku's Avatar
Drives: pearl white eighty six
Originally Posted by dhoeze View Post
Congrats sir,..
other than the usual... check for a noise coming from the trunk, met 3 owners with this problem, that includes me...
Thanks sir... what is causing the noise sir? what kind of noise? knocking/ cranking, etc?...
thanks for the heads up pa3ck32, pcuerpo
pearlhatchiroku is offline   Reply With Quote
Old 09-17-2013, 11:19 AM   #1501
USMC
USMC's Avatar
Drives: 2013 Scion FR-s
Also pick up anew car during the day light hours. You can see much better all over car. I also like to take with me a flashlight to check other locations in the inside. Lastly, the check the oil level.
USMC is offline   Reply With Quote
Old 09-17-2013, 01:01 PM   #1502
Alabang BRZ
Originally Posted by pa3ck32 View Post
Congrats!
Check that the rubber stoppers/grommets are installed under your car.
It was not installed on my brz when I got it. Nasa glove box yung rubber stoppers. My agent didn't even know what it was for so I just installed it myself.
I think there was a post about it here somewhere before.
What are the stoppers/grommets for?
Alabang BRZ is offline   Reply With Quote
Old 09-17-2013, 01:21 PM   #1503
dagame
dagame's Avatar
Drives: Subaru BRZ ZC6 Lightning Red
Originally Posted by pearlhatchiroku View Post
hey guys, il be getting my 86 in a couple of days.... any headsup, tips or stuff i should keep an eye on before i accept the unit?
TIA, been involved wit other car forums and clubs looks like this is a fun club to be a part with, lots of cool peeps... hope im welcome hehe
congrats on getting your 86!
check for the plugs located below your car. it should be plugged as to avoid water and other stuff to get inside it.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson, Top Gear S19E3
dagame is offline   Reply With Quote
Old 09-17-2013, 01:23 PM   #1504
dagame
dagame's Avatar
if its not plugged if i'm not mistaken the sound is louder but water and odor from the outside environment can go inside the car. someone posted it here back in may 2013 i think.
Old 09-17-2013, 01:39 PM   #1505
NIKDENG
Drives: RED BRZ
They are used to plug the two tie down holes in the rear subframe which are used during the transportation of the cars from the factory. It should have been done as part of the pre-delivery inspection by the casa:
NIKDENG is offline   Reply With Quote
The Following 2 Users Say Thank You to NIKDENG For This Useful Post:
86ers (09-22-2013), jdmasfcuk (09-21-2013)
Old 09-17-2013, 10:40 PM   #1506
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
probably that's the reason why minsan pag traffic, parang may pumapasok na amoy usok.. tried opening the vents and it was worse so i dont think may problem yun
same case din ba for 86 owners or these are for BRZ lang? wala naman ako napansin na stoppers or anything na rubber sa glove compartment ko
pcuerpo is offline   Reply With Quote
Old 09-17-2013, 11:21 PM   #1507
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Originally Posted by NIKDENG View Post
@pcuerpo,
The 86/brz actually follows the standard DRL implementation of the DRL lighting up whenever the engine is running and the handbrake is deactivated. They should turn off when the headlights, parklights, or foglights are turned on or when the handbrake is activated.
question, my DRL lights up along with the park lights/head lights are turned on irregardless if engine is on or off and handbrake is activated or not... i just remembered this post of @NIKDENG about the DRL for the 86 and remembered mine isnt how it was described... so which is it supposed to be?
btw, my DRL was functioning already as i got it from the casa so i didnt put any relays anymore
Old 09-18-2013, 12:35 AM   #1508
dagame
dagame's Avatar
check your car based on the picture NIKDENG posted there should be a rubber stopper inserted there.
Old 09-18-2013, 02:19 AM   #1509
NIKDENG
Drives: RED BRZ
@pcuerpo,
Does your DRL light up when the engine is on, handbrake disengaged and headlights turned off? If not then your DRL is not enabled and what you are seeing is the led bar on your headlight functioning as park lights.
Old 09-18-2013, 06:15 AM   #1510
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
@NIKDENG, but is that the one that lights up also pag DRL or iba pa ba?
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
Old 09-18-2013, 06:54 AM   #1511
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
It's the same. The LED strip also lights up when you turn on the park lights. When the headlights are turned off, they should turn on if you disengage the e-brake. The only difference is that when they are functioning as DRLs, they light up stronger than as park lights.
Tye300 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tye300 For This Useful Post:
86ers (09-22-2013), pcuerpo (09-18-2013)
Old 09-18-2013, 07:39 AM   #1512
NIKDENG
Drives: RED BRZ
Exactly as Tye said. Its the same led bar but if your DRL function is not enabled, it will not light up when your park/headlights are turned off and the handbrake disengaged. The led bar will only function as park lights. The addition of the relay for the DRL is what enables this function.
The Following User Says Thank You to NIKDENG For This Useful Post:
