Old 09-13-2013, 01:32 PM   #99
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Originally Posted by mad_sb View Post
That is more a function of you tuning software / log analysis software. Ecuedit, for example, does a fantastic job of that but im not sure if epifan will support these roms with ecudit from an editing and log analysis standpoint.
Yep. I wasn't sure what all came with the package. This appears to mainly be the device to transfer the maps to/from the ECU. I was mainly thinking out loud. The important thing is that I can get WB O2 into the logs along with what is coming from the OBDII port into the tablet so that it can be read later by the tuning software.
TunerPro might be a sufficient tuning application. But that's something to check later. I'll probably donate for the full version of that as I like to support the people that help the community.
I am definitely watching this thread for more updates though.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 09-13-2013, 02:02 PM   #100
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
This is great! Reminds me of when OpenFlash first started for the EVO VIII! I wish I would have waited before boosting the BRZ, this is a much better option.
Deepseadiver is offline   Reply With Quote
Old 09-13-2013, 02:18 PM   #101
Z0rr0
Drives: 2013 Raven 6MT FR-S
Not that I want to throw another wrench in the works, But I believe Tactrix/ECUFlash are soon to have support as well.
This is about the get very exciting..
I can already feel the boost.....
Z0rr0 is offline   Reply With Quote
Old 09-13-2013, 02:19 PM   #102
CajunFRS
Drives: Challenger R/T, CRX SI,
Does anyone know if Openflash will be supporting things like No Lift Shift, Launch control etc. I know data logging is coming.
CajunFRS is offline   Reply With Quote
Old 09-13-2013, 02:23 PM   #103
Rombinhood@OpenFlash
Drives: FRS
Yes, launch control and no lift shift is enabled in the 6MT OpenFlash maps
Rombinhood@OpenFlash is offline   Reply With Quote
Old 09-13-2013, 02:27 PM   #104
Z0rr0
How about MAP sensor scaling, is that available?
that is paramount to anyone wanting boost.
also the trick of using the purge solenoid output to control a wastegate solenoid would be good as well
Old 09-13-2013, 02:31 PM   #105
CajunFRS
Ahhh awesomeness!!! Someone needs to put up a YouTube video of this once they install it!!
Old 09-13-2013, 03:04 PM   #106
Drives: FRS
You can rescale all the sensors in the engine. I know Shiv rescaled the front o2 sensor to allow it to read a richer nominal AFR value instead of bottoming out. A MAF scaling table is also defined. Along with various others. I'll check the defs to see if one of them is MAP.
Old 09-13-2013, 03:44 PM   #107
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
hmm so no codes for a catless header??. also alittle off topic but does the 2nd cat prove a notable power loss? catless rasp is gettn to me lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 09-13-2013, 03:59 PM   #108
Sonolin
This thing is looking very interesting
Should hook up to an existing Flex/Fuel kit as well right? Can your tuners tune for that?
Interested in this. Looks like a much better & cheaper way to ecutek . I'm interesting in tracking this car and want to know if your tuners have any experience tuning track/performance oriented cars? I did see the post from your tuner about a more Daily Driver setup but I'm interested in a more performance tuned (while still being my daily driver of course) version?
Options:
8 Month "Open" Custom Tuning Support…$195
For those who want a more customized tune with even more performance than our Off-The-Shelf (OTS) maps provide, this 8 month support contract includes ongoing datalog review/analysis and up to 12 customized tuning files. You simply email us the datalogs (as generated by the OpenFlash Tablet and/or Procede), and we provide you with custom tuned ROM/Procede files to match your needs, modifications and operating conditions. Compared to using our free OTS map files, expect more power, even smooth boost control and peace of mind knowing that your engine is tuned properly by actual tuning professionals and NOT by inexperienced enthusiasts. More importantly, we provide you with fully viewable custom tune files. Unlike some "Pro Tuners", we do not believe in hiding anything from our customers. You are paying for both performance and knowledge of what is being done to your vehicle.
Sonolin is offline   Reply With Quote
Old 09-13-2013, 04:20 PM   #109
qoncept
qoncept's Avatar
What makes you think that?
qoncept is offline   Reply With Quote
Old 09-13-2013, 04:29 PM   #110
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Second cat (if a high flow) only has a 1-2 hp penalty. But it makes a huge difference in sound quality and output.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 09-13-2013, 05:25 PM   #111
jamesm
There's a thread on Romraider forums suggesting that the latest Ecuflash beta (and thus next version) contains subie diesel ecu support. the diesels share an ecu with the 86, only the rom id differs. so... that means ecuflash will soon be able to flash 86 ecus out of the box. all that is left after that is open source definitions. or at least that is how i understand it... i only know what's been public knowledge on the forums over there.
even with that in mind.... this is still a better deal. if ecuflash didn't require a tactrix branded cable it may be a different story. i still think you get your money's worth here with the device itself and support.
Old 09-13-2013, 05:37 PM   #112
qoncept
qoncept's Avatar
That post is several months old.. I don't think anything is being done with it. Not sure what's up with EcuFlash but I haven't heard from Colby in a LONG time.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
