Old 04-11-2013, 03:39 PM   #29
BeRZed
Has any brz owners install these?
BeRZed is offline   Reply With Quote
The Following User Says Thank You to BeRZed For This Useful Post:
Mersd (04-11-2013)
Old 05-10-2013, 07:14 PM   #30
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
One question for the Hotchkis rep. What is the warranty on your products?
Lakers86 is offline   Reply With Quote
Old 05-11-2013, 03:53 AM   #31
hapa_kcm
hapa_kcm's Avatar
Drives: WRB BRZ Limited
At the end of their install instructions...
http://www.hotchkis.net/_uploaded_fi...ns5218file.pdf
hapa_kcm is offline   Reply With Quote
Old 05-13-2013, 03:08 AM   #32
Dan@AWD
Drives: 2013 Argento FR-S
Just installed these on Saturday. Barely notice a difference in ride quality.
Dan@AWD is offline   Reply With Quote
Old 05-27-2013, 06:18 PM   #33
nightfire
Drives: 2013 SWP BRZ Limited manual
I second wondering how they feel on a BRZ? I'm between these and the Racecomp yellows...
nightfire is offline   Reply With Quote
Old 06-02-2013, 04:08 AM   #34
hapa_kcm
hapa_kcm's Avatar
Still a comfy ride on my BRZ. Oh I also cut the bump stop in the front even lower for more travel, but the rears are what is recommended by the instructions. The front OEM shocks still do not bottom out
The Following User Says Thank You to hapa_kcm For This Useful Post:
hmong337 (08-25-2013)
Old 09-10-2013, 05:47 PM   #35
Panda Grahams
Panda Grahams's Avatar
Drives: '22 BRZ
Any camber adjustments when installing these? Basically, do I need to order camber bolts too?
Panda Grahams is offline   Reply With Quote
Old 09-10-2013, 06:46 PM   #36
bfrank1972
Drives: 2013 FR-S Argento
There's nothing specific about Hotchkis springs, they're like any other spring with a 1" drop. Lots of info/discussion/debate on it in the forum. In a nutshell, yeah get the camber bolts, they're inexpensive and allow you to dial in some negative camber in the front (good for handling). Dial in as much negative camber as the bolts will allow. The lowering springs will give you an ok amount of negative camber in the rear at a 1" drop - you can get by fine with just that.
FYI, factory alignment specs are notoriously 'loose' on these cars, and if you want perfect alignment specs you may need camber adjustability on front and rear. If you want to really do it right, you get a pair of SPC adjustable lower control arms for the rear (add $250-$300) so you can set your rear camber where you want it.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
axelo (08-23-2014), Panda Grahams (09-11-2013)
Old 03-25-2015, 01:49 PM   #37
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Im trying to buy the hotchkis lowering spring directly from hotchkis.com.. However when i am at the order page i get the following message:
This Part doesn't fit your 2015 Subaru BRZ Series.Blue
Any reason why this part wouldn't fit my 2015 series blue?
Jfheisenberg is offline   Reply With Quote
Old 03-25-2015, 02:11 PM   #38
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
no reason it wont! Probably just haven't added it to the "approved fitment" list.
maybe try here...and use the code in my sig...
The Following User Says Thank You to continuecrushing For This Useful Post:
Jfheisenberg (03-25-2015)
Old 02-20-2016, 12:01 AM   #39
choiboie
Drives: 2013 Fr-S UltraMarine
Do u have spacers?
Sent from my SM-G920V using Tapatalk
choiboie is offline   Reply With Quote
Old 02-20-2016, 12:05 AM   #40
choiboie
I just installed my springs this afternoon..
driving with no front sway endlinks as the bolts were seized an had to cut them off..have to order on monday.
Driving home it didn't feel much different. Though it was fairly strsight ride home no twistys. Will see how it rides on my 40 mile hwy commute to work tomorrow. Planning to drive slower and take precautions just in case.has anyone ever run into this problem?
Old 02-22-2016, 06:13 AM   #41
hapa_kcm
hapa_kcm's Avatar
Originally Posted by choiboie View Post
Do u have spacers?
At that time I was running 25mm spacers all around on my stock wheels
choiboie (02-22-2016)
Old 02-23-2016, 03:12 PM   #42
choiboie
Did the front look flush. Not sure if I wanna do 22mm or 25
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 06:32 PM
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 07:26 PM
D2 RS/K-Sport Kontrol Pro Coilover Review DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 04-08-2016 02:32 PM
Hotchkis springs JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-27-2012 01:07 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
