View Poll Results: What oil
Mobil 1 113 41.70%
Castrol Syntec 38 14.02%
Valvoline Synpower 6 2.21%
Quaker state/ Q horsepower 5 1.85%
Penzoil Platinum 17 6.27%
Royal purple 28 10.33%
Eneos 5 1.85%
TRD oil (dont know if still available) 6 2.21%
Castrol "think with your dipstick jimmy" Edge 10 3.69%
..... motorcraft?....... 2 0.74%
Other. please specify 60 22.14%
Multiple Choice Poll. Voters: 271. You may not vote on this poll
Old 01-23-2012, 03:39 PM   #183
DSR2409
Drives: 05 Nissan Sentra Se-r Spec V
Originally Posted by ryude View Post
Just so you know Royal Purple no longer uses their Synerlec additive package in their regular oil. You have to buy Royal Purple HPS to get the "old" Royal Purple. The regular RP is now just a Group II base stock with common additives that everyone else uses.
That is not true, I don't know where you heard that...the HPS is a new oil developed for cars with higher mileage outside of factory warranties. It has a much higher zinc and phosphorus content, the two main antiwear metals in oil. That is why it is not SAE approved, because it exceeds their allowances for those two metals. The reason the SAE won't approve more is because it can damage catalytic converters, thus the oil is designed for cars outside of warranty (a non SAE approved oil will void your warranty, should anything go wrong). The standard Royal Purple is the same as it was...
DSR2409 is offline   Reply With Quote
Old 01-23-2012, 04:31 PM   #184
ryude
Drives: Volkswagen GTI
http://www.bobistheoilguy.com/forums...Number=2319761
RP has changed their lineup.
The normal RP sold at Advance Auto and other places is the new AP SN formula that does not contain any Synerlec because it cannot be used and meet SN standards. They are in switchover right now, so you can tell the difference by the bottle style as the new SN has the new bottle design (as does the new HPS below)
They have added a new oil the High Performance Street (HPS) that still contains Synerlec and higher levels of ZDDP (around 1200 ppm). This oil has been reformulated with more Synerlec than the previous "normal" RP (I got this from the RP tech line). In addition the under 40 weight oils had the ZDDP increased to the 1200 ppm ZDDP rather than the 1000 ppm previously used to meet the SL standards. The 40 and 50 weight oils previously and still have 1200 ppm ZDDP
The XPR (extreme performance racing) line is unchanged as far as I know.
ryude is offline   Reply With Quote
Old 01-23-2012, 07:03 PM   #185
DSR2409
Huh...that kind of sucks! I have been using HPS, anyway, but that is kind of cheap. The Synerlac is what has saved my engine...
Old 01-23-2012, 07:12 PM   #186
serialk11r
Drives: '06 AM V8V Coupe
Also, someone mentioned the BRZ/FRS will require 0w20...I don't know if that is confirmed, but it would make sense, since most newer cars are using that viscosity, and, to my knowledge, no one makes a conventional 0w20...
Most cars are specifying 0w-20 now. If the first number is 0 that's better since it means it's thinner when cold, so more oil can flow upon startup, reducing wear. I think the only way to get 0w-20 is synthetic, as non-synthetics have poor viscosity index.
Old 01-23-2012, 11:20 PM   #187
ryude
Synerlec is he best additive pack in the industry, no point in buying RP without it IMHO.
Old 01-23-2012, 11:45 PM   #188
DSR2409
I am, admittedly, a Royal Purple fanboy, but I don't disagree...The HPS still has Synerlac, so I will keep using that on my Spec, but I might have to use Amsoil (the next best oil, in my opinion) in the BRZ/FRS...Maybe I will give Redline a try, but you will never catch me with Mobil 1 in my car...
Old 01-24-2012, 09:14 AM   #189
ryude
Redline uses the best base stock, but due to their low quality additives you can't use a long OCI like you can on RP.
Old 01-24-2012, 06:37 PM   #190
DSR2409
I was looking around on bobistheoilguy.com to see how UOAs from the new Royal Purple stack up, and it just doesn't look like it is worth the extra money, but I did run across a guy who also had an 02 Spec V, and ran RP XPR 0w10 for 5k miles, with excellent results, so I might get some of that to try it out!
Old 01-30-2012, 10:05 PM   #191
Jamifra
Jamifra's Avatar
Drives: 2013 Civic Si
Amsoil Signature Series! 0w30!
Jamifra is offline   Reply With Quote
Old 02-03-2012, 10:44 PM   #192
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Amsoil is good enough
Tradewind is offline   Reply With Quote
Old 02-03-2012, 10:46 PM   #193
Tradewind
Actually
XADO Atomic oil is shaping up to have some potential - need to test it for longer yet
Old 02-12-2012, 01:47 AM   #194
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Originally Posted by whaap View Post
Thanks for the laugh. I bought my first car in 1952. It was a '47 Ford convertible. Of course that was shortly after the crust of the earth cooled and long before synthetic oil was known by the common man. In the years since I have never (key word being NEVER) had an internal engine problem with an automobile, boat or motorcycle engine that I've owned. And now you're telling me I've been wrong all these years. I'm going to have to go set in the corner and cry !!
I'm impressed. I'm assuming you're at least in your mid-70s. If you plan on buying an FR-S or a BRZ I want a picture of you driving out of the dealership!
Enemies is offline   Reply With Quote
Old 02-18-2012, 02:53 PM   #195
TRDGT86
TRDGT86
Drives: 86
TRD for sure.........
TRDGT86 is offline   Reply With Quote
Old 02-18-2012, 08:27 PM   #196
superman105
Drives: civic
which ever is on sale ...
superman105 is offline   Reply With Quote
