#1135 | |
The bolts were obviously way overtorqued and stretched. I might have to do the polish treatment on mine as well, that looks good. |
#1136 | |
Drives: '13 FR-S Raven 6MT
As other have said though, it seems that you may have over-tightened the nuts. I notice that you have a Crawford sticker on the strut-to-firewall brace. Is that just a sticker or are those aftermarket braces as well? |
#1137 |
Drives: FRS :D
Been a bit now since I've had mine and just did a autox with it. No issues at all. Still love it but now I'm deff goin to sand and polish that Grimmspeed logo.
Out of the FRS game
#1138 |
Drives: 86
OMG im scared. i torqued mine to 12ft/lb according to my torque wrench but it feels pretty tight. then i used the torque wrench to tighten the stock nut near the firewall and it turned a little more. left it overnight then saw the above post and i loosen all nuts a bit and hopefully they won't snap.
#1139 |
Snow Don't Hurt!
![]() Sorry, no install pic. Been raining like crazy here. I LOVE the feel of the car! Definitely a noticeable difference! Thank you so much, Sirs! |
#1140 | |
It appears that the problem is most likely with your torque wrench. The fact that all 4 studs snapped makes no sense, because if the bar was the issue at least one side of the bar would have had to remain attached in order to apply force to the opposite side's studs. Even if that did happen, the other two breaking with no applied force is physically impossible. What makes even less sense, is that you were able to recover the studs and bolts, and that they did not fall to the ground somewhere during your spirited drive. The only explanation for this failure mode is that the studs were over torqued either during the install, or were over-torqued at a previous instance that caused the studs to begin to stretch, at which point they were already ruined. The fact that all 4 failed backs up the fact that either the torque wrench is out of spec, or that the studs themselves were a poor material composition (however unlikely). Again, we're very sorry that happened to you, this is why we made it very clear to be careful on these studs. However, unless the material composition on all 4 studs was bad, 12ftlbs is the factory torque spec, and would not cause the studs to stretch. Additionally, the bearing surface (the surface of the strut bar that would physically interact with the stud) is substantially thicker than the stock triangulation bars, and thus substantially lowers the shear force acting on the stud, it does not raise it. Think cutting through something with a thin knife blade, and then trying to cut through the same thing with the opposite, dull side of the knife that is substantially thicker. So, I can safely say it is not "terrible design." I would think about throwing away that torque wrench, or try to remember if you or anyone had previously torqued those studs before this incident. We'd like to hear more about it to help prevent this from happening in the future, and as always you can give us a call or send us an email to talk about it. 612 379 0000 or engineering@grimmspeed.com Chase Engineering |
| The Following 6 Users Say Thank You to GrimmSpeed For This Useful Post: | Captain Snooze (09-09-2013), chanomatik (09-09-2013), Evil Jesus (09-10-2013), kwood9000 (09-09-2013), mfbmike (11-10-2013), mRdeMs83 (09-09-2013) |
#1141 |
Ridge Racerrrrrrrrr
Good news, LOVE this strut bar
Installed the bar and my MCB and both look at home in my car I have to take some new pictures of my car so the will end up in my build thread. Love the stuff you make Grimmspeed! Now where is your intake info thread? month out or so? I need something else to follow religiously this christmas
#1142 | ||||||
![]() Quote:
Hahahaha, I am not sure of when yet. We are still very early into this project, but I promise there will be a development thread. 5150ultd thanks again for giving me a call so we could figure out what happened, hopefully it doesn't happen to anyone else. Folks, thank you to everyone so far for the nice comments, and for posting up pictures of your installs and how you have customized the logos, and ac line brackets. I honestly love to see what you guys are coming up with, and I have to apologize for not coming up with any cool custom bar yet myself. It'll happen! Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | chanomatik (09-09-2013) |
#1143 |
Cones are bad
Drives: 2013 BRZ Premium
It has begun. A little behind schedule, but whatever. GrimmSpeed Cherry Blossom paint
| The Following User Says Thank You to RazBRZ For This Useful Post: | SkAsphalt (09-09-2013) |
#1144 |
Are new people still installing these? Impressions? Issues?
Can't wait to pick mine up if all is well. |
#1145 | |
Drives: Skoda Yeti DSG diesel 4x4
In Oz, waiting. ![]() I would appreciate knowing if the broken studs were overtorqued so we can relax about that aspect? |
#1146 | |
How tight is 12 ft/lbs anyway? Just slightly snug? Not looking forward to buying a $100 torque wrench to put on a $160 part if I don't have to. :happy0180: |
#1147 | |
Drives: 2018 Golf R
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
#1148 | |
Less than pleased...
Drives: '13 BRZ Ltd SSM 6MT
| Anyone using the STi Flexible Strut Tower Brace? | ngabdala | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 08-15-2019 01:59 AM |
| F/S Beatrush Strut Tower Brace Type-2 $175 | Dan-in-Japan | Brakes, Suspension, Chassis | 2 | 02-24-2013 01:38 PM |
| FT-86 SpeedFactory Strut Tower Brace Review | F1point4 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 35 | 01-07-2013 04:31 AM |
| DIY - Strut Tower Brace - FT-86 SpeedFactory | F1point4 | DIY (Do-It-Yourself) Guides | 4 | 10-28-2012 04:30 PM |
