Old 01-22-2012, 08:11 PM   #57
serialk11r
Drives: '06 AM V8V Coupe
^^ lol er...thanks?
ryude how are you getting that conclusion? If say he gets 40mpg on the highway portion of his commute (let's say this is most of the 90 miles) with the manual, and 10% better with the auto, he'd be using 2.2 gallons of gas for the manual vs. 2.05 gallons for the auto. 0.15 gallons * say, 300 days, is 45 gallons of gas, which at 4 dollars a gallon is 180 dollars a year. I'm predicting better than 40mpg (at 60-70mph), and I may be overestimating gas price so let's say 160 dollars. 6 years to pay off the auto, assuming he ONLY drives on the highway. In the city, he may not necessarily lose mpg if he avoids using 1st gear past getting the car rolling. The auto box also needs to power its hydraulic pump, which would sap some amount of energy too.
Old 01-22-2012, 08:23 PM   #58
miata
Drives: 2006 Miata 5 spd
I agree. It will take about 5 years but not over 10 years to make up $1000 initial cost.
If the mpg is 10% better the annual fuel spending will be 10% less.
If one spends $3000/year the difference will be $300/year and will take little over 3yrs to get $1000 back.
miata is offline   Reply With Quote
Old 01-22-2012, 08:34 PM   #59
ryude
Drives: Volkswagen GTI
The automatic gets 3mpg more on highway, which means average mpg will increase by 1 maybe? 1mpg is so insignificant that it will take you a very long time to recoup the extra cost. If you're going to buy the automatic, don't buy it for the fuel economy. Buy it because that's what you really want/need.
ryude is offline   Reply With Quote
Old 01-22-2012, 08:34 PM   #60
devinclfalcons
Drives: Evo X MR
Will the gearing be the same on the FR-S and BRZ? Because I am going to get the BRZ.
devinclfalcons is offline   Reply With Quote
Old 01-22-2012, 08:38 PM   #61
ryude
http://fueleconomy.gov/feg/Find.do?a...31315&id=31377
Auto vs manual cruze eco.
Annual Fuel Cost Auto: $1,635 Manual: $1,536
But in the real world, the difference is very minimal.
Old 01-22-2012, 09:56 PM   #62
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
It will probably be the same but you never know...
tripjammer is offline   Reply With Quote
Old 01-23-2012, 03:36 AM   #63
serialk11r
EPA highway test favors manuals as it involves a lot of changes in speed. Real world highway driving favors locked automatics, which almost always have higher gears.
EPA city screws autos over as it should.
Old 01-23-2012, 12:35 PM   #64
iff2mastamatt
Feeling Iffy?
iff2mastamatt's Avatar
Drives: it like I stole it
^ true that.
iff2mastamatt is offline   Reply With Quote
Old 01-23-2012, 09:34 PM   #65
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
just manually shift the auto so it stays at low rpms in the city... i heel toe everywhere in my manual even at low speeds out of habit, if i go the auto route ill be upshifting and downshift manually ALL the time
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 01-23-2012, 10:53 PM   #66
devinclfalcons
Drives: Evo X MR
That's what I do in my Evo X MR
Old 01-23-2012, 11:07 PM   #67
serialk11r
Well you don't want to accelerate at too far below 2000 rpm since the engine loses too much heat to the cooling system at low speeds, but it's okay if you do that in 2nd gear since you got out of 1st gear early. Anything is better than an unlocked torque converter.
I'm not sure how gear spacing would change the equation. If the gears are spaced out farther then the auto would theoretically lose more energy to the engine needing to slow down more to match the next gear's speed, but effect is probably very small.
Old 01-24-2012, 12:15 PM   #68
phenoyz
Drives: 2011 Honda Fit Sport
is 3000 rpm at 60 mph normal or high?
phenoyz is offline   Reply With Quote
Old 01-24-2012, 01:11 PM   #69
Jehuty77
Drives: AE86
Premium gas only?
Jehuty77 is offline   Reply With Quote
Old 01-24-2012, 01:44 PM   #70
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by Jehuty77 View Post
Premium gas only?
yes
Out of the FRS game
Mr.Jay is offline   Reply With Quote
