Old 09-02-2013, 12:29 AM   #1
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
EDIT: An update on my original setup, after about a month it became apparent I couldn't use these most of the time I wanted more light, other drivers were around, I disabled them. I looked for a bit for real aux reverse lights, similar to fog lights with a flat upper cutoff, but nothing would easily integrate into the rear of this car. So there you have it, $100+ later I would have been better off leaving stock alone and not putting an illegal setup on my car, yes illegal. All exterior lights are regulated for output, directional intensity is VERY important and my setup overpowered a light with a proper cutoff with a massive blinding flood light.
EDIT: TL,DR don't waste your money like I did, stock is as good as it gets without a real custom setup to mount real aux reverse lights.
My setup was without question illegal and was removed about a month after install, being an illegal setup I chose to remove the how-to. It's not a hard setup, but I'm not interested in giving a how-to on an illegal setup.
fuzzymachinist is offline   Reply With Quote
The Following 10 Users Say Thank You to fuzzymachinist For This Useful Post:
504 (12-07-2013), Dadhawk (12-06-2013), Panda Grahams (09-02-2013), ShutterSpeed (09-02-2013), SkAsphalt (09-02-2013), Techfl3x (10-31-2013), Travisty75 (10-08-2014), ts87 (09-02-2013), unvevo (04-08-2014), YDNA (09-02-2013)
Old 09-02-2013, 12:29 AM   #2
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
Edit: deleted
Old 09-02-2013, 12:56 AM   #3
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Thats interesting
Young_makaveli is offline   Reply With Quote
Old 09-02-2013, 01:21 PM   #4
DIM
Where'd you purchase the switchback's from? Link.
DIM is offline   Reply With Quote
Old 09-02-2013, 08:02 PM   #5
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
Edit: delete
Old 09-02-2013, 08:26 PM   #6
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Wouldn't you be able to just tap the wire which produces the white leds to go on into the wire that sends the signal to your stock reverse lights? That way they go into white mode when you're in reverse?
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 09-02-2013, 08:39 PM   #7
mashal
DADA
mashal's Avatar
Drives: 2013
This is a better option. I actually made a small harness at work to do this but I decided not to and instead bought super bright lights
mashal is offline   Reply With Quote
Old 09-02-2013, 08:44 PM   #8
fuzzymachinist
Drives: '13 FRS MT
Real reverse lights
Edit: too bright, illegal etc
Old 09-02-2013, 08:47 PM   #9
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
great idea
mezdup is offline   Reply With Quote
Old 09-02-2013, 10:42 PM   #10
ts87
Thanks for the right up!
ts87 is offline   Reply With Quote
Old 09-02-2013, 10:58 PM   #11
Brody602
Drift King
Brody602's Avatar
Originally Posted by fuzzymachinist View Post
I could, and I actually did that for version 1, but as the pics show these are obscenely bright and I didn't want to put other drivers through that when backing up at night. Maybe with other switchbacks it wouldn't be an issue or at least less of one but with the V3s I used there was no way I would personally run them without a switch. If you saw them in person I think you would agree with me on the necessity of a separate switch and to only use them as needed. At the end of the day though its up to the owner to decide what they want to put other drivers through.
Considering they're switchbacks and used as DRL's normally, I'm under te impression they'd be very bright but shouldn't be blinding, otherwise they'd be a hazard if installed as their intended use..?
Old 09-03-2013, 08:46 AM   #12
fuzzymachinist
Drives: '13 FRS MT
True, they are used in the front as parking lights but for me after tieing directly to the reverse lights I thought they were too much and needed a switch. Just test them with a test lead before hacking up your factory harness if you have any question about it.
Old 12-06-2013, 02:15 PM   #13
jm1681
Drives: MKVI VW GTI
I love this idea. But I am completely incompetent when it comes to wiring >.<
Is this as easy as tapping into the hot for the reverse lights, and sending that to the power for the LEDs? I really know nothing on the subject of wiring and whatnot, but my driveway is impossible to negotiate in the dark and this would be a huge help.
jm1681 is offline   Reply With Quote
Old 12-07-2013, 12:59 AM   #14
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Did you tint your reverse lights at all?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 08:42 PM
HID Reverse Lights mezdup Cosmetic Modification (Interior/Exterior/Lighting) 10 06-19-2013 05:47 PM
reverse lights xdbuix Cosmetic Modification (Interior/Exterior/Lighting) 8 06-11-2013 11:00 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 09:38 PM
GTA: CREE Reverse Lights Selvedge Canada Classifieds 0 12-27-2012 07:37 PM
