Old 08-20-2013, 05:20 PM   #71
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by swift996 View Post
Intro:
The purpose of this thread is to provide a reference for owners on available options and solutions for engine and ECU tuning. This is an objective information-based perspective with the intent that the user will further research the options to make their own conclusion.
* Disclaimer* If you are considering a tuning solution please search this forum, talk with other owners, vendors, and tuners about your specific goals. This thread is not the end-all-be-all. It's merely a community resource.
FAQ:
- What is engine tuning?
Engine tuning is changing certain engine variables (fuel maps/timing) to optimize performance. This is typically done via an OBDII port connection. A tuner can remap your existing ECU parameters or add additional hardware (see flash/piggyback/stand alone section below) to control certain variables and parameters of the flow of fuel and timing.
- How can modifying the cars Air, Fuel, and Timing increase performance?
OEM manufactures typically design automobiles to have certain thresholds of failure and safety. They typically have to manage the cost/risk of a warranty and other reliability measures. Tuners can lower that threshold. Also, with the addition of bolt on parts such as intakes and headers the engine can move a greater volume of air in and out of the engine. Thus a tune can help optimize the new capabilities of the engine set up.
Air/Fuel Raito:
A car's Air to Fuel ratio (A:F) is the measure of units of air to units of fuel. A Standard Association of Engineers (SAE) study suggests that a 12.5:1 ratio is optimum for performance. That is over simplified as the engine load (throttle position), fuel type, engine geometry, and engine temperature all play a role as variables in the optimization equation. The SAE study suggested a 16:1 ratio is optimal for thermal efficiency. Typically a ratio above 14.7:1 is considered lean where under 14.7:1 is considered rich. The engine application determines the optimal point. Typically tuners will run a richer mix through higher RPMs (more fuel than the engine can burn) to cool the cycle and help catalytic converter performance. They also like ovoid leaning out the engine and causing detonation (more common in turbo applications).
Timing:
Advancing the timing allows the spark to fire sooner in the upstroke of the piston in the cylinder block. This allows the combustion to generate more pressure and in effect force the piston downward with more force (thus creating more power). The risk is allowing too much advance will cause turbulence and decrease power and introduce knock in the engine. There is a non linear equation that typically dictates power. The best way to tune timing is to tune the car on a dyno. A tuner can adjust the timing and test it under certain loads and engine speeds to determine if advancing the timing creates more power. Conversely, a tuner can retard timing (the opposite of advancing).
[B]- What is E85 and Flex Fuel? How can these fuel mixtures enhance performance?
E85 is a fuel with 85% of it's volume as ethanol. Flex fuel typically refers to a mixture of pump gas and ethanol. Companies make sensors that can read the ethanol content and w/ EcuTek can adjust timing accordingly. The benefits of running E85 is a higher resistance to knock. In effect E85 acts like 96-98 octane which allows tuners to add more timing without the same risk of knock with pump gas. For forced inducted applications, this typically can yield an additional 2-3psi of boost safety net.
- What's the technical difference between a flash, piggyback, and stand-alone solution?
Flash - A technique used to replace the existing ECU parameters and fuel/timing maps. This is typically done via the OBDII port. It allows a tuner to control many parameters from the factory ECU sensor system.
Piggy-Back - Typically a unit that plugs another computer with loaded maps into the sensory system of the factory ECU. This typically will adjust parameters on the fly and in effect change the tune of the factory maps.
Stand-Alone - This requires replacing the factory ECU with an aftermarket computer. Some systems reuse factory sensory components, while the new computer allows for additional sensory (ex: wide-band-02).
- What kind of performance gains can I expect by using a tuning solution?
For the BRZ/FRS/GT86 tuners have shown gains from about 10-18whp running high octane pump gas. Those results can increase with the use of E85. HP gains can typically be greater paired with upgraded air flow components such as a performance intake filter, intake system, header, etc.
- Why should I consider a dyno-calibrated tune?
A dyno tune allows a tuner to make adjustments to the maps on the fly. A tuner can test and validate many scenerios and see the performance outcome in real-time. While data logging and reviewing can provide feedback to adjust map settings, a dyno allows a tuner to get a more optomize tune to your specific vehicle. This can become more important with the addition of a turbo charger.
- Can the dealership "see" that I have a tune installed?
On the BRZ/FRS/GT86 it has been reported that a dealer's system can pick up an event stored on the ECU every time the maps are reflashed. A piggy-back or stand-alone system can avoid leaving a footprint on the factory ECU.
- Will a tune void my warranty?
- Will a tune effect my MPG?
Tuners can help optimize volumetric efficiency which can help improve fuel efficiency. However, typically the goal of a tune is to increase power and at some points (especially in high RPMs) the tune isn't focused on creating fuel efficiency. Most owners of tunes have reported pretty consistent fuel efficiency as OEM.
- What other capabilities or features should I consider with a tuning solution?
Many tuning applications offer enhanced features such as auto-blip throttle (rev matching), launch control, flat foot shifting, map switching, etc. Ultimately, a prospective buyer should evaluate the different features offered by a tuning solution for best fit with their individual requirements.
- What are the limits of the stock fuel system?
Tuners have reported that fuel upgrades such as a fuel pump or injector become necessary in the 270whp-300whp range. Please consult with a tuner to understand the limits on your configuration. Injectors may become necessary with forced inducted applications, especially running E85. Perrin found on the Vortech kit around 6.6k rpms that the stock fuel pump could do no more at 12psi of boost (~300whp).
Available Solutions:
EcuTek - via the EcuTek Cable an owner or tuner can reflash the factory ECU with the EcuTek RaceROM.
Features: Map Tuning, Data Logging, Map Switching, Rev Limit Control, Launch Control, Auto-Blip Throttle, Flat-Foot Shifting, and e85/flex fuel support.
Pricing: License $250, Tune ~$200-400, Cable (Optional) ~$350
Tuners (Other vendors, please let me know if I missed you):
Visconti
FA20Club.com
Drift Office
PERRIN
Moto East
PTUNING
DD Performance Research
Evasive Motorsports (also Fcon IS tuning available)
Other/Resellers/Authorized Dealers:
FT-86 Speed Factory
Pure Automotive
Unichip - a plug and play EMS/piggyback unit. Maps can be downloaded via the Unichip file-share library and flashed via the Unichip USB flash cable.
Features: Map Tuning, Plug and Play Harness, Map Switching, Map Library (all maps are free), Doesn't Require a VIN License, OBDII Reader, and Additional Features Under Development.
Pricing: Plug and Play Kit (Harness + Tune) $445, USB Flash Cable (Optional) $45, Flux2 Unit (Optional) $265 + $45 Cable
Unichip EMS
Unichip Map Downloads Thread
Unichip MapsQ software Thread
BRZEdit (ECUEdit) - via the Epifansoft cable an owner or tuner can reflash the factory ECU.
Features: Map Tuning, Data Logging, Map Editing, Rev Limit Control, and Additional Features Under Development.
Pricing: Personal License $499, Tactrix Openport 2.0 (Optional) $169
Epifansoft
Hydra EMS 2.7 - a plug and play EMS/Stand Alone unit.
Features: Map Tuning, Data Logging, Map Editing, Launch Control, Flat Foot Shifting, Rev Limit Control, e85/flex fuel support, and Additional Features Under Development.
Pricing: EMS Plug and Play Kit $1899, Wideband O2 (Optional) $449, Flat-Foot Shifting Harness (Optional) $79
Element Tuning
Can we get visconti removed from this list? I'm sure if there was a petition or like this comment or something, I'm sure the community would back me up on this request.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-20-2013, 05:24 PM   #72
swift996
swift996's Avatar
My intent was to provide resources not promote or blacklist any vendors. If a vendor is removed from the forum, I'd feel comfortable removing them from the thread but people can seek feedback and make their own judgments on tuners and their individual needs.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Nightbringer (08-21-2013)
Old 08-21-2013, 01:41 AM   #73
Fast_Freddy
Drives: Passat
Great example of mob mentality. I for one would not back up your asinine request.
Fast_Freddy is offline   Reply With Quote
Old 08-21-2013, 09:15 AM   #74
itdansharpe
itdansharpe's Avatar
WTF is everyone flaming him for anyway? The care fire? How is that his fault? Maybe I'm missing the details here.
John and I have been working closely since June e-tuning my car, and the results is fantastic!
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 08-21-2013, 08:46 PM   #75
soodxn
Drives: S2000
is it worth getting a tune on a completely stock car?
Does the stock ecu ever unlearn or overwrite the tune after driving for a while?
thanks for answering my nooby questions
soodxn is offline   Reply With Quote
The Following User Says Thank You to soodxn For This Useful Post:
Mooseknuckle44 (03-31-2014)
Old 08-29-2013, 01:44 PM   #76
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Maybe add OpenFlash Tablet under developing. They support TunerPro.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 08-29-2013, 02:41 PM   #77
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I think it is more over the way he handled the sale of his flex fuel kit. He sold an unsafe kit and then offered to sell more parts to make it not unsafe. You might think the results are fantastic, but if you don't have another tune to judge it against, then how do you really know? My results were not fantastic, same Full Blown kit you have:
The Following 2 Users Say Thank You to King Tut For This Useful Post:
448hpsti (09-01-2013), Nightbringer (08-29-2013)
Old 09-01-2013, 12:04 AM   #78
TIE Pilot
TIE Pilot's Avatar
MAP-ECU (piggyback) with wifi (for PC map editor and iphone app) . Just uploaded a wiring diagram for the Toyota GT86, Scion FRS and Subaru BRZ:
http://mapecu.co.nz/PMR/wp-content/u...S-MAP-ECU3.pdf
Cool stuff:
iMAPCAL iPhone ECU App (like dashcommand)... if this had map managing will be a killer!
http://mapecu.co.nz/PMR/wp-content/u.../IMG_05191.png
Old 09-05-2013, 07:55 AM   #79
TIE Pilot
TIE Pilot's Avatar
OpenFlash Tablet - a portable hand held flashing device with high-resolution backlit color touchscreen with internal speaker. It comes with a USB cable, OBDII cable and download links for the OpenFlash software (map manager), map editor (Tuner Pro) and XML definition files.
Features:
-Free Off-The-Shelf (OTS) maps files-In-dash Boost Gauge (0-20psi)
-On-board datalogging
-Realtime Data Screen
-Trouble code reading/clearing
-Diagnostic activation for water pump and cooling fans
-Adaptation resets for battery, octane, VANOS, VVT, transmission, DME, lambda, AFR and Throttle
-Activation for transport mode
Initial installation takes approximately 2 minutes; Each flash write takes approximately 5 minutes; Launch control and No-Lift Shift/Flat-foot shift implemented. Both are user adjustable; Generic and does not contain any unique vehicle identifiers (immobilizier, VIN data, etc,.) so entire ROMs can be flashed; Other maps (for cars running on E85 and with more mods) will follow
Pricing: $495 (intro)
OpenFlash Stg 1 tune FR-S stock 171.64 vs FR-S tuned 178.20
OpenFlash Tablet Thread
OpenFlash FAQ (Vishnu)
The Following User Says Thank You to TIE Pilot For This Useful Post:
swift996 (09-05-2013)
Old 09-14-2013, 08:42 PM   #80
Razor
Razor's Avatar
Drives: FR-S in Raven 6MT
I want to know what I can expect to gain on everyday driving with an aftermarket tune. I have a Takeda cold air and a Greddy lite exhaust. I only plan to use the car as a daily driver but as an enthusiast I enjoy brisk acceleration. I do not intend to race at all.
Thanks for the help!
Razor is offline   Reply With Quote
Old 09-17-2013, 12:08 PM   #81
TIE Pilot
TIE Pilot's Avatar
brzEdit update
this
Originally Posted by brzEdit View Post
Update: Pricing has been adjusted for Personal $249usd & $175usd for Lite Version. Personal Version now allows direct file sharing between peers.
King Tut (09-17-2013)
Old 09-17-2013, 01:56 PM   #82
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Even if you're not racing, the gains from this tune aren't all about the horsepower, it's the intangible benefits. The drivability is the major improvement. Idle smoothness, throttle response, etc. The torque dip is notably improved and the power onset is smoother across the entire rev range. Much more enjoyable to drive, even just rolling around at low RPMs during daily commutes.
Nightbringer is offline   Reply With Quote
Old 09-21-2013, 11:22 AM   #83
meadowz06
THE CORVETTE KING!
meadowz06's Avatar
Drives: 2013 FR-S, and 2016 FR-S!
I may have missed it, but what exactly is causing the torque curve to fall out around 4-4.5K? I would love to have that tuned out.
2013 Scion FR-S.
2005 Corvette.
meadowz06 is offline   Reply With Quote
Old 09-21-2013, 12:18 PM   #84
Nightbringer
Drives: Scion FR-S
The torque dip is roughly where it switches injection methods from what I understand it, and the factory tune is VERY conservative in this area. It can be minimized on pump, but all the extra timing advance you can run on E85 really takes care of it. Only way to wholly remove it though is with headers, but the tune goes a long way. I didn't even notice unless I was fixating on it.
The Following User Says Thank You to Nightbringer For This Useful Post:
meadowz06 (09-21-2013)
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 03:34 AM
Ford Racing Suspension tuning guide? mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-22-2013 02:00 PM
fact or fiction on this performance and tuning guide? davey90 AUSTRALIA 10 07-19-2012 08:45 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-21-2012 12:33 AM
86/FRS/BRZ Tuning Guide ESBjiujitsu Engine, Exhaust, Transmission 18 05-30-2012 07:42 PM
