Old 08-28-2013, 11:01 AM   #15
wparsons
wparsons's Avatar
You are basically describing what a turbo timer does and no, I don't have an electric pump to keep coolant circulating in my car. I take it easy about 2-5 minutes before turning the car off everytime.
Any turbo timer I've seen keeps the whole car running, not just an electric pump for oil and/or coolant.
flickr
Old 08-28-2013, 11:19 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, indeed, but again don't see the need with a water/oil cooled turbo. As long as you don't run it and straight turn it off you will be good.
Old 08-28-2013, 11:31 AM   #17
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
With older oil-cooled turbo cars, the oil available at the time could coke (degrade/burn) if left in a hot turbo if you didn't let it circulate and cool down. You would be hard pressed to coke a modern synthetic oil, even if you were trying to.
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Sportsguy83 (08-28-2013)
Old 08-28-2013, 12:10 PM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by gdrider77 View Post
Anyone do this? Thoughts?
No. Waste of expensive 93 octane.
Old 08-28-2013, 12:26 PM   #19
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
All my turbo cars its always been the same. I just take it easy 2-3 min from my destination. Clutch in and roll when I park. Stop. Set ebrake. Fiddle with radio. Undo seat belt. Roll up windows. Open door. Then turn it off. Don't really do a cool down, just do everything else I normally do when I park.
Unless your doing a WOT pull, then going straight into a parking lot and shutting it off I wouldn't worry too much.
Nolan
pheoxs is offline   Reply With Quote
The Following User Says Thank You to pheoxs For This Useful Post:
wparsons (08-28-2013)
Old 08-28-2013, 03:07 PM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
Originally Posted by InvalidJohnny5 View Post
Turbo timers are kind of a thing of the past with new tech no?
On new cars with stock turbos unnecessary, because the turbos are technically being cooled even when the car is off because either the oil or coolant is still passing through them and the cooling is designed from the ground up with the car. Aftermarket wise its not that necessary unless you constantly go WOT all day long every day.
Old 08-28-2013, 06:29 PM   #21
lexusb3
Drives: FRS
I do wot on the highways alot but by the time I
Pull into my Neighboor and sit at the stop light for a few minutes no need for like a cool down unless you wide open throttle str8 into your garage lol
lexusb3 is offline   Reply With Quote
Old 03-31-2014, 12:54 AM   #22
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
What about when racing? Autocross, drags, or roadcourse. You usually go hard then shut off to cool with the hood open until your next run. Should you leave the car running instead of shutting down?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 03-31-2014, 01:04 AM   #23
ZionsWrath
Thanks
ZionsWrath's Avatar
If you drive like this you might need a turbo timer
[ame="https://www.youtube.com/watch?v=eUNywnlZ5d0"]DTA SCION FR-S DOING HER FIRST BURNOUT - YouTube[/ame]
Old 03-31-2014, 08:41 AM   #24
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
i think i would cause more problems with fuel dillution on e85 in my oil than anything letting it idle all the time. Thankfully i have along enough dirt driveway to not worry about it.
Old 03-31-2014, 08:45 AM   #25
Sportsguy83
Drives: Limited BRZ
Right after a run I would let it idle for a minute then shutoff.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
blackfireball5 (03-31-2014), shiro (03-31-2014)
Old 03-31-2014, 09:09 AM   #26
Dimman
Kuruma Otaku
Dimman's Avatar
Lots of old school cars were also water/oil cooled. Issue is how hot the turbine housing gets and then heat soaking the bearing section after the car is off and fluids aren't circulating.
Because titanium.
Old 03-31-2014, 09:15 AM   #27
mrk1
Drives: Sterling BRZ Ltd
If your parking spot is at the end of 1/4 strip then sure. Other wise the time spend cruising to your parking spot should be fine. New tech has made it less important but it still should be kept in mind.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Sportsguy83 (03-31-2014)
Old 03-31-2014, 09:15 AM   #28
Sportsguy83
Drives: Limited BRZ
I know that is the issue. My point is water/oil cooled will not get hot enough cruising around to warrant using a turbo timer. Old school or not. Now, right after running the car hard, even water/oil cooled should be let cool down for a minute or two. Whether the person feels a turbo timer is needed depends on his/her discipline to always let the cooldown happen before shutoff. (Cooldown meaning cruising/coasting or letting idle the minute or two).
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Introducing the D3PE "KLR" turbo system... Evan@D3PE Forced Induction 25 06-15-2013 01:24 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions... NickFRS Forced Induction 40 05-10-2013 01:55 PM
Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans vh_supra26 Other Vehicles & General Automotive Discussions 1 02-19-2010 02:53 PM
