Old 08-26-2013, 12:08 AM   #15
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Originally Posted by Suberman View Post
Correct, an anti perforation warranty. However, manufacturers will assess early rusting and sometimes elect to remedy it early. For suspension though they will not since it is a cosmetic issue.
I could have sworn you needed suspension for driving ...
I don't think its just cosmetic...
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
The Following 3 Users Say Thank You to Wo6M For This Useful Post:
bestwheelbase (08-28-2013), infinite012 (08-26-2013), Suberman (08-27-2013)
Old 08-27-2013, 05:12 PM   #16
gily25
Drives: Silica BRZ 6MT
BRZ a lot closer to the ground than the SUV...going to make a difference. Are you near the shore? When I lived near the ocean everyone's brand new cars were a mess. There are petroleum products you can spray underneath on bolts and brackets for those areas, can't say I know what's good anymore but here a link to bull frog to give you an idea http://www.bull-frog.com/products/. You may need to get under there with some steel wool and sandpaper to clean things up first.
gily25 is offline   Reply With Quote
Old 08-27-2013, 05:51 PM   #17
JR007
JR007's Avatar
Drives: Ultramarine FR-S
@BRZnut, I have some rust like yours in the first few seconds clips (where the exhaust pipes meet) and at a few bolts down the pipe. I have an FR-S, even though it shouldn't matter.
Can you please let us know what the dealer says and if they'll correct?
Thanks!
JR007 is offline   Reply With Quote
Old 08-27-2013, 11:50 PM   #18
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by Young_makaveli View Post
Well I just got my frs a few days ago and I think Ill rust prof it right before the snow and salt hits the ground!
Your car is already rust proofed from the factory. You don't need to do that.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Old 08-28-2013, 04:13 AM   #19
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
My frs is not rust proofed..
Well Theres no signs at least (oil nor wax)
Can you explain please?
Thanks
Young_makaveli is offline   Reply With Quote
Old 08-28-2013, 04:53 AM   #20
dori.
Seρor Member
dori.'s Avatar
Drives: white BRZ 6MT
Thanks
the chassis itself comes galvanized from the factory
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
Young_makaveli (08-28-2013)
Old 08-28-2013, 04:57 AM   #21
Young_makaveli
Drives: 2013 frs
Thanks for the reply
I thought galvanization is only to protect from rock chips?
I haven't looked under the car yet ..i know the bottom of the doors are galvanized only
Old 08-28-2013, 09:31 AM   #22
infinite012
Drives: 13 DGM BRZ Ltd
[ame="http://en.wikipedia.org/wiki/Galvanization"]Galvanization - Wikipedia, the free encyclopedia[/ame]
Quote from wiki article:
Galvanization (or galvanisation) is the process of applying a protective zinc coating to steel or iron, in order to prevent rusting.
It will do nothing to protect against rock chips.
infinite012 is offline   Reply With Quote
The Following User Says Thank You to infinite012 For This Useful Post:
Old 08-28-2013, 10:40 AM   #23
Suberman
Thanks
Well, my Subaru dealer had an Impreza displayed on a roll up stand showing the entire underbody. The whole thing is heavily coated in black flexible epoxy paint. That's rustproofing and protection against stone chipping of the underbody.
You cannot see any of the internal rustproofing but it is there.
Good to know Subaru also galvanizes the sheet steel. Porsche and Audi also galvanize their metal. The hood of the Subaru is aluminum and needs no corrosion protection beyond paint.
Old 08-28-2013, 10:47 AM   #24
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Rust proofing also help bolt and fasteners. You don't want to snap bolts and have a hard time changing parts in a few years just for regular maintenance. How many times did I ever snap the 8mm bolt holding the brake line to the strut, or fucked up a sway bar link because the rust took the hex threads away - enough for me to yearly shoot rust check on all the suspension parts and fasteners.
Rayme is offline   Reply With Quote
Old 08-28-2013, 11:02 AM   #25
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
All car manufacturers galvanize their metal parts upon manufacturing. Some manufacturers may have a lower quality galvanizing process (pre-inspection, cleaning of the steel), probably why some cars are more prone to rust (ie. Mazdas) off the lot.
Thinking of doing Krown rust proofing before winter time (Canada), but I think they'll drill holes in your car so they can spray the inside... not so sure if I want that.
Myv is offline   Reply With Quote
Old 08-28-2013, 01:35 PM   #26
Young_makaveli
Drives: 2013 frs
I assume toyota/scion does the same process?
Im going to rust proof my frs anyways just for piece of mind
Best place would be krown?
Even if they drill holes they cover it up very well
Old 08-28-2013, 01:42 PM   #27
qoncept
qoncept's Avatar
It would take hundreds of years for any of those parts to rust through to the point of failure. It is cosmetic.
qoncept is offline   Reply With Quote
Old 08-28-2013, 04:18 PM   #28
Wo6M
Wo6M's Avatar
Sorry if I sound unsympathetic but no it would not take hundreds of years. Maybe if it was in a condition where it would allows it but in this cases like up north conditions it would take just a few years . Take a look at junk yards....
Just my opinion .
Mods:
Broken down FRS-T! video inside Silverdub Forced Induction 26 05-22-2013 03:21 AM
Chirp (Video Inside) StOpNG0x Issues | Warranty | Recalls / TSB 17 12-13-2012 10:06 AM
Question about Whiteline COM-C + KW V3. Video Inside. D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 11-11-2012 10:04 PM
Took her to the NASA Auto-X at VMP today! (video inside) xjohnx Tracking / Autocross / HPDE / Drifting 4 08-27-2012 10:54 AM
Idle RPM dip.... video inside. CSG Mike Engine, Exhaust, Transmission 24 08-17-2012 02:45 PM
