#127 |
AutoX-10/10ths every run
Just finished reading this thread for the first time. Thanks to everyone for their inputs.
#128 |
Curious cat.
Drives: 86 GT base M/T - Red
@CSG Mike
Do you think coilovers you mentioned with ultra high spring rates (such as the Tein SRCs you mentioned) would work well with non-extreme, 225 or 235 width street tires or would they tend to overpower the tires and/or demand high grip tires such as RS3s, Z2s, Rivals and the like? What do you think of pillow ball upper mounts for bad roads? And at which point would you recommend paying the premium for JRZs or Ohlins DFVs? Also, how well would they work on less than ideal pavement?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
| The Following User Says Thank You to ultra For This Useful Post: | Anthonytpt (08-24-2013) |
#129 |
Drives: AE86, 2x GT86, TE27
Interesting read.
Although I have more questions ha ha. Also, I realise now I know nothing about coilovers. |
#130 | |
While they force a heavier load on the tire, we haven't had any issues. Ohlins DFV's are NOT a premium product, only a premium name. They have more expensive products that are more representative of the Ohlins name. Are JRZ's worth the money? Hell yes, if you can appreciate a good damper. I wouldn't recommend the RS-1 though. RS at the minium, and RS-Pro to really get the full experience. Pillowballs can be rebuilt; we drive on terrible roads in Southern California, and while they do eventually wear out, we can't really document the wear because the platform hasn't been around long enough. We'll keep everyone posted. As a data point, every rebuild/revalve of our SRCs also involves a full inspection to document any potential wear, tear, and issues, and we're still using the original pillowballs that came with the dampers. They haven't been reconditioned or rebuilt yet. |
#131 |
#132 | ||
Heres a quote of a post I made in the thread about Teins. Quote:
I'm looking at FA in a bit more detail now. These also have a local dealer. He said he can't rebuild, but will only charge $200 return shipping when that time comes. He has advised 6kg F and 6Kg R. I am thinking that maybe I could step up to 6kg F, 8kg R, so I don't get rear end squat. He has also advised he's happy to swap springs free of charge, if I don't get them right first time; nice touch I thought. Happy to hear your thoughts? Be honest, brutal if need be. I can take it
#133 | |
Drives: FR-S Whiteout
#134 | |
6k/8k will result in a fairly loose car (and I personally prefer looser cars...); you can add a front sway to compensate to a degree. |
#135 |
For now? The SRCs; we haven't developed the JRZs as extensively. Now at a similar level of development, I suspect the results would be different, but this could be said about ANY high end damper we develop.
#136 | |
Currently trawling through the info about tarmac zero's. They certinaly are loved on here. Will just come down to the shipping cost, as the rrp is very reasonable :/ |
#137 | |
Kuruma Otaku
So from this, can we expand into what to do with spring rates and bar strength interaction? I've read about the British philosophy of choosing springs for a front:rear frequency ratio of ~1.0:1.1 to manage pitching oscilations, then adjusting bars to desired over/understeer. Or starting simpler, the more basic soft spring/big bar vs hard spring/soft bar setups which kind sounds like the Atlantic vs Pacific coast setups.
Because titanium. |
| The Following User Says Thank You to Dimman For This Useful Post: | solidONE (08-26-2013) |
#138 |
So I'm assuming "development" means the white car has been better set up closer to idea in terms of spring rates and damping/valving. The JRZ will likely work better when dialed in as your SRC's have, or do you mean the JRZ are made of superior construction/components?
#139 |
#140 | |
My preference was certainly the softer spring, hard bar setup. Don't ask me techinically why, it just felt better to the ol' butt dyno. |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 09:11 AM |
| Some observations | Nardi330 | AUSTRALIA | 20 | 02-07-2013 06:18 AM |
| 90 Day Anniversary ..some Observations | Scooby South | BRZ First-Gen (2012+) — General Topics | 6 | 09-03-2012 11:17 AM |
| Mike's track videos. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-16-2012 04:00 AM |
| First Payment sent, Observations after 6 weeks. | Scooby South | BRZ First-Gen (2012+) — General Topics | 27 | 08-01-2012 02:02 PM |
