Old 08-21-2013, 09:46 PM   #43
DNAPoPo
GreddyBRZ meets GreddyFRS
DNAPoPo's Avatar
Drives: SSM Limited BRZ
Originally Posted by RandomHero View Post
Easiest route: Buy an amp with High Level inputs
Slightly more advanced:
A line output converter. Because its a full signal you can use it on speakers or a sub with appropriate crossover points. Only problem is the "Sub" volume control on whatever headunit you are running will have no effect. You would have to boost the lower frequencies yourself, which is often possible on line converters (many have built in eq's) or your HU.
:happy0180:
One last question, the amps I have in mind do speaker level inputs, would I be tapping into wires (A) or (B)?
(A)
White = LF Speaker amplified out (black line means -) [PIN 1 and 5]
Grey = RF Speaker amplified out (black line means -) [ PIN 2 and 6]
(B)
Green = Left speaker signal input from HU [PIN 3 and 9]
Purple = Right Speaker signal in from HU [PIN 4 and 10]
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club
Tuesday Night Irvine DJ Meet Thread
Irvine FR-S & BRZ Car Meet(FaceBook)
DNAPoPo is offline   Reply With Quote
Old 08-22-2013, 11:17 AM   #44
mid_life_crisis
Drives: FR-S 10 #103 AT
Not knowing if (B) is amplified from the HU or line level (probably amplified), I would try (B) first. If it doesn't produce any real volume, you haven't hurt anything. You can always still connect (A) with the gains down and see what happens if (B) isn't loud enough.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
DNAPoPo (08-22-2013)
Old 08-22-2013, 11:24 AM   #45
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
You definitely want to tap (B), I use (B) for the speaker level inputs on my amp. (A) is the powered signal going to the door speakers.
(B) is coming from the HU, (A) has been "amped" by the factory trunk amp and no one is really sure if that amp has any crossovers or filters or other sound shaping built in.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following User Says Thank You to f0rge For This Useful Post:
Old 08-22-2013, 02:17 PM   #46
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
(A)
(B)
Use B as inputs. @f0rge is correct. The white and grey wires will now be powered by your aftermarket Amp as these wires go directly to your door speakers (ie no filter exists between this harness and the door so set your HPF and LPF on your amp as you desire)
RandomHero is offline   Reply With Quote
The Following 2 Users Say Thank You to RandomHero For This Useful Post:
Alak (05-17-2014), DNAPoPo (08-22-2013)
Old 08-22-2013, 05:19 PM   #47
DNAPoPo
DNAPoPo's Avatar
Ther I go lying about last questions... Hopefully last question pin 3&4 correspond to white wire on speaker RCA connection or red?
SoCal 86 OC Club
Old 08-22-2013, 05:41 PM   #48
kuhlka
Drives: 2013 BRZ Limited AT
I'll just do a YouTube video tonight showing my setup. I recently moved my wires from the HU to the amp and it works fine. I'm using posi-taps.
kuhlka is offline   Reply With Quote
The Following User Says Thank You to kuhlka For This Useful Post:
Old 08-22-2013, 08:13 PM   #49
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Did you use the speaker outputs or HU signal to wire to your sub amp?
I was thinking to take these below and convert to RCA and use as sub output from HU, since BRZ HU does not have RCA out, will this work?
Sorry, I was sick and didn't check the forum for a while.
It's already been answered and f0rge explained it well.
I used signal wires. PIN 3, 4, 9, 10.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
DNAPoPo (08-23-2013)
Old 08-22-2013, 09:19 PM   #50
BRZnut
Drives: BRZ DGM Limited
Looking forward to seeing it!
The Following User Says Thank You to BRZnut For This Useful Post:
Old 08-22-2013, 10:10 PM   #51
kuhlka
[ame]http://youtu.be/ma5s8GLOd7w[/ame]
The Following 5 Users Say Thank You to kuhlka For This Useful Post:
Agent 86 (02-11-2016), DNAPoPo (08-23-2013), hmong337 (07-27-2014), housecat (12-17-2014), Shankenstein (09-10-2013)
Old 08-22-2013, 10:11 PM   #52
kuhlka
I'll do better videos after I move. I have garbage lighting in my dinky garage. Where I'm moving I'll have access to a full pneumatic lift and TONS of tools.
Old 08-24-2013, 04:21 PM   #53
BRZnut
Thanks for the video..doesn't look too bad to do
Old 08-27-2013, 01:41 AM   #54
kuhlka
The only annoying part is running the positive lead. I'll flop my back seat down, get a shop light, and do a better video when I'm all moved next weekend. I still need to shorten some of the wires and eventually get a custom enclosure for the driver's side corner.
Old 08-28-2013, 02:57 PM   #55
mmontes
Drives: limited brz
Talking
:happy0180: this post helped my life in so many ways!
mmontes is offline   Reply With Quote
Old 08-29-2013, 01:48 PM   #56
Chase Bays
Chase Bays's Avatar
Drives: FR-S | 335i | S13
I will be using this write up to install an AMP for my speakers and sub. I'll take some pictures to share.
Perks of the job: My battery is in the back. (May need to upgrade the size haha)
Chase Bays is offline   Reply With Quote
Wideband LC-1 wiring. MattF Forced Induction 9 07-09-2013 10:33 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 02:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 10:24 PM
x940bt wiring help encity5 Electronics | Audio | NAV | Infotainment 10 08-31-2012 05:08 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-27-2012 12:54 AM
