Old 08-23-2013, 12:42 PM   #29
choi
choi's Avatar
Drives: 2013 BRZ Limited Silver
how big/small is this antenna compared to beat sonic? is it smaller, shorter? And did you say it was $190 so ~ $200?
choi is offline   Reply With Quote
Old 08-23-2013, 04:06 PM   #30
DSOmegaX
DSOmegaX's Avatar
It's smaller in every dimension, but that's because it won't fit on the BRZ Limited's antenna base unless you mod/remove it. Beat-Sonic's is designed for the large base, but it makes it look comically large as a result.
@dsomegax.cars
Old 08-24-2013, 12:19 PM   #31
choi
choi's Avatar
Are we both talking about the STI antenna? What mod would I have to do to make it fit? Can't believe there's enough of a difference between jdm and usdm that the shark fins don't fit.
thanks in advance(really waiting for this thank button to appear lol)
Old 08-24-2013, 12:28 PM   #32
DSOmegaX
DSOmegaX's Avatar
The antenna bases are different. JDM vehicles do not have satellite radio, and use the same base that the FRS has (premium BRZs as well). Just look it up and you'll see the immediate difference.
@dsomegax.cars
The Following User Says Thank You to DSOmegaX For This Useful Post:
Beyer Subaru (08-24-2013)
Old 08-24-2013, 12:51 PM   #33
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Your kinda right @DSOmegaX.
All three antenna are different -
USDM BRZ - The biggest of the bunch. Most all of the piggy back style shark fins won't work.
USDM FR-S - The middle of the bunch. Most all of the piggy back style shark fins will work. This is a fixed upright antenna.
JDM/World BRZ/86/GT86 - The smallest of the bunch. All of the piggy back style shark fins will work. The difference between these and the USDM FR-S is that it is mobile and can stand erect or laid as flat as possible. This is like the current antenna used on the WRX/STi and past model Impreza/Forester.
Beyer Subaru is offline   Reply With Quote
The Following User Says Thank You to Beyer Subaru For This Useful Post:
DSOmegaX (08-24-2013)
Old 10-04-2013, 10:54 PM   #34
Nitesh31
Nitesh31's Avatar
Drives: Black BRZ Black STI
Here's it in black
Props to @Beyer Subaru
Nitesh31 is offline   Reply With Quote
The Following 2 Users Say Thank You to Nitesh31 For This Useful Post:
Beyer Subaru (10-07-2013), DAEMANO (10-20-2014)
Old 01-09-2014, 01:37 PM   #35
wh1te0ut
wh1te0ut's Avatar
Drives: Whiteout FR-S
Is this antenna plug and play compatible with the FR-S? Thanks.
wh1te0ut is offline   Reply With Quote
Old 01-09-2014, 02:20 PM   #36
Beyer Subaru
I have no clue. The harness for the BRZ looks kinda like a number 8. The only pic I have is from the first page -
Old 01-09-2014, 02:21 PM   #37
Beyer Subaru
You can see where the two wires go into the right side of the harness and the left terminal is empty. The left side is where the XM (Sat) wire should be.
Old 01-12-2014, 02:57 PM   #38
wh1te0ut
wh1te0ut's Avatar
Found this pic in the for sale area. Looks like the ends might match up. Thanks again.
The Following User Says Thank You to wh1te0ut For This Useful Post:
Beyer Subaru (01-14-2014)
Old 01-14-2014, 11:49 AM   #39
Beyer Subaru
Yerp. That's it. So it "should" be plug-n-play. My reception kicks butt now and the NAV works as well with the Shark Fin.
Old 01-16-2014, 08:58 AM   #40
Bongertz
Drives: Brz
So what's the verdict, is this better than the beat sonic fins? Hahahaha.
Bongertz is offline   Reply With Quote
Old 01-16-2014, 09:49 AM   #41
Beyer Subaru
I wouldn't say it's better or worse than the BeatSonic. It's just different. The BS is a piggy-back style on top of the OEM antenna and the STi is a full replacement of the OEM antenna.
Old 06-11-2014, 08:26 PM   #42
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
Anyone has the part number for this for USDM now that the Blue Edition comes with this sharkfin?
voyager2285 is offline   Reply With Quote
Flat low profile antenna (non shark fin) Enigmus Cosmetic Modification (Interior/Exterior/Lighting) 177 09-02-2015 05:13 PM
20$ Shark Fin Antenna srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 13 05-08-2013 02:13 AM
Shark Fin Antenna Sparda29 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-20-2013 11:49 PM
Tom's antenna shark fin Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 15 10-28-2012 01:44 PM
Shark Fin Antenna geb2391 BRZ First-Gen (2012+) — General Topics 15 09-09-2012 10:05 PM
