Old 08-23-2013, 01:45 PM   #15
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by PERRIN_Jeff View Post
WOW, those are some super awesome pics!!
Did your overpipe fit ok with the stock header and the Borla? Feedback on this would be great as you are the second person with that header and clearance problems and we may need to make some special notes about this. Did you try adjusting the V-band connection much to help the clearance?
I never explicitly looked at the clearance but I never heard the banging noise like I do now with the P&L. We did try many things: adjust the pipe at the v-band, loosen everything and hold and sinch, adjust at the gearbox exhaust hanger. Etc. I may look at it again next week if the noise doesn't go away.
I am open to trying any revised overpipes
F1point4 is offline   Reply With Quote
Old 08-23-2013, 01:47 PM   #16
F1point4
Photo Specialist
F1point4's Avatar
Originally Posted by Hawaiian View Post
http://www.flickr.com/photos/victorn07/9572469353/
The cable for the fans runs a little too close to the header here for my taste. I relocated mine inside the fan shroud to keep it from getting that close to the header.
It took 30 seconds and a zip tie.
Amazing photos again.
Next time I have the car in the air I'll reroute this wire. Thanks for the suggestion sir
Old 08-23-2013, 01:54 PM   #17
OrbitalEllipses
Drives: Attitude
This is a common problem with STI's and Group N mounts if you do a lot of lauches like in a AutoX event. A friend of mine use to go through 3 sets of these a year (had to use for class rules) and since installing ours, he has about 2 years of abuse and they are still perfect!
Also if they are the Group N STI mounts they will not work without some mods.
[IMG ]http://www.perrinperformance.com/assets/2012/09/06/PSP-DRV-050_07.jpg[/IMG]
This car does not make enough torque to mess up the motor mounts IMO. STI has new engine mounts out that fit this chassis, though significantly more expensive than Group-N mounts.
Old 08-23-2013, 03:39 PM   #18
stockysnail
Just the tip
stockysnail's Avatar
I've had Perrin engine mounts sitting at home for months now waiting for the JDL UEL headers I ordered months ago. Nice to see you enjoy the engine mounts. I'm guessing I will as well. I was going to install myself on a friends lift but it seems I'll need to make sure to have something to jack the engine up as well when on the lift. I'm guessing jacking it up with just the two engine mounts loose is all I would need to get them out? Or would I need to loosen anything else like trans mount?
Old 08-23-2013, 04:20 PM   #19
xwd
Do the new Perrin mounts weigh the same or more than the stock mounts? That's the rule for STX class, you can run any mount you want as long as it doesn't decrease weight.
There are BRZ-specific STI mounts now which are basically just much stiffer rubber. I'm not sure I see the same issues happening with those as the Impreza ones due to how much material there is, and there is quite a bit less force involved with launching a BRZ vs. a STI.
Old 08-23-2013, 06:44 PM   #20
F1point4
Photo Specialist
F1point4's Avatar
High speed cruising feedback above
http://www.ft86club.com/forums/showp...87&postcount=5
Example of the exhaust noise in cabin. Just to give a sense, not professionally recorded
[ame="http://www.youtube.com/watch?v=sF7IMei1uPA"]P&L Motorsports/Perrin Performance Exhaust High Speed Cruising - YouTube[/ame]
Old 08-23-2013, 09:00 PM   #21
Mobius357
Drives: '15 WRX '13 Legacy '07 Colorado
@PERRIN_Jeff I have the same problem with my overpipe after adding the P&L header, no clearance issues with the stock header, so there's nothing for you guys to be worrying about. The groupbuy thread has pictures of P&L's own overpipe with identical contact points. I swapped back to the stock overpipe for now.
Mobius357 is offline   Reply With Quote
Old 08-23-2013, 09:18 PM   #22
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
Wow, great review. Thank you! I just received my Perrin mounts yesterday and I chose them over cusco for the same reason as you. I also like the fact that they make the removal of the motor much easier for future work and maintenance.
How harsh are they for daily driving? I don't mind some increased NVH but I'm still curious.
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
F1point4 (08-23-2013)
Old 08-23-2013, 09:40 PM   #23
ft86me
ft86me's Avatar
Drives: 2013 FRS
seems like koyo radiator won't fit with this header.
ft86me is offline   Reply With Quote
Old 08-23-2013, 11:45 PM   #24
F1point4
Photo Specialist
F1point4's Avatar
The Pipes they make ze noise Herr doktor
My brother and I were going about town recording some sane driving sound clips and I got something to bang together a few times. I am pretty sure its the overpipe hitting the subframe. My car never made this noise before I installed this header. However all I have to go by is this noise, can't say for sure this is the root cause.
[ame="http://www.youtube.com/watch?v=6QWhflDntw0"]P&L Equal Length Catted Header and Perrin Overpipe Clearance Issue 001 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=NgS4m4hlXZM"]P&L Equal Length Catted Header and Perrin Overpipe Clearance Issue 001 - YouTube[/ame]
Old 08-24-2013, 12:21 AM   #25
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Thanks for the awesome write up/review and pictures (BTW what camera?)
Looks like you made a good choice by going with perrin. Any clue why the Borla cracked? Bad weld or is it due to the flex section creating uneven expansion ect possibly?
The Following User Says Thank You to Kiske For This Useful Post:
F1point4 (08-24-2013)
Old 08-24-2013, 12:34 AM   #26
F1point4
Photo Specialist
F1point4's Avatar
Thank you. Here is my current gear. I'm a prime guy
Olympus OM-D EM5
Olympus 12mm f/2.0
Panasonic 20 f/1.7
Panasonic 25mm f/1.4
Olympus 60mm f/2.8 macro
Olympus 75mm f/1.8
FL-600R Wireless Flash
I do post processing in Lightroom 5 and Photoshop CC.
I think the combination of poor welding plus the heat from FI plus a track day ultimately led to the crack. I think there is no way to really know for sure.
Old 08-24-2013, 12:40 AM   #27
F1point4
Photo Specialist
F1point4's Avatar
Last group of videos for today. Enjoy
Going about in town
Overall I find the system to be very easy to drive with going about in town. The exhaust definitely lets you know its there when you go through the powerband, but when you get to a easy cruise speed, it quickly gets out of the way. P&L Motorsports and Perrin definitely make good products.
The following videos were just my brother and I going around Dallas. We found some good roads to stretch out Lola's legs while just having random chat. All of it was recorded on a windshield mounted OM-D. I had to rotate all the videos because the camera was upside down :|
After trying this setup, i'm not sure if I want a go pro haha.
[ame="http://www.youtube.com/watch?v=4Kdr8o26drU"]P&L Equal Length Catted and Perrin Headerback - In Town Cruising 001 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=dF-PQ_QYWFY"]P&L Equal Length Catted and Perrin Headerback - In Town Cruising 002 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=JeSaJSw5fQ4"]P&L Equal Length Catted and Perrin Headerback - In Town Cruising 003 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=a8wQOJNtdPg"]P&L Equal Length Catted and Perrin Headerback - In Town Cruising 004 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=ww_wd5yGxOY"]P&L Equal Length Header and Perrin Headerback - In Town Cruising 005 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=PkkonLu5lM0"]P&L Equal Length Catted and Perrin Headerback - In Town Cruising 006 - YouTube[/ame]
Old 08-24-2013, 05:59 AM   #28
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
How hard are the motor mounts to install ?
and are they doable at home easily ? i know @Sportsguy83 did it but said it was a pain in the ass !
Nameless Performance Equal Length Stepped Header Jason@Nameless Engine, Exhaust, Transmission 4525 11-21-2022 05:38 PM
P&L Motorsports BRZ / FR-S 4:1 Equal Length Header - Naturally Aspirated P&L Motorsports Engine, Exhaust, Bolt-Ons 244 09-24-2015 04:44 PM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
SOLD: P&L Motorsports Equal Length 4-1 Header yamsta Engine, Exhaust, Bolt-Ons 18 08-07-2013 10:24 AM
Borla Releases Equal Length Header, Catless Huehuecoyotl Engine, Exhaust, Transmission 1 04-05-2013 09:44 PM
