Old 08-21-2013, 06:54 PM   #575
lostmessengers
Drives: 2013 Scion FRS Whiteout
Originally Posted by Diggitydog89 View Post
I just wish there was a good tuning company that is around here b/c I dont feel comfortable driving across the country just to tune a car.... closest one is Florida
AWDtuning is in Flowermound and they are more then capable of tuning a car with this setup. Keith is one of the best tuners in Texas and hes not far from Arlington at all.
lostmessengers is offline   Reply With Quote
Old 08-21-2013, 07:01 PM   #576
Diggitydog89
Drives: 2005 Chrysler Crossfire
Ima have to check that place out I know where Flowermound is... ssweeet
Diggitydog89 is offline   Reply With Quote
Old 08-22-2013, 02:13 AM   #577
Calum
That Guy
Drives: 2013 asphalt FRS MT
@ptuning What are you guys planning for the PCV system? Would you recommend vented to atmosphere, or sealed, if anything?
Old 08-22-2013, 01:07 PM   #578
ptuning
ptuning's Avatar
Drives: White FR-S
We're retaining the factory PCV for now. We'll likely add a boost friendly check valve in line too. All of our blow-thru turbo kits simply vent the crank breather through a separate K&N mini filter. On a healthy engine, you will not get any oil or smoke coming out of the filter.
We'll engineer our own catch can system shortly. Our 400whp tune only used a spring clamp on the PCV and EVAP hose. We usually vent our catch cans to atmosphere, but we may also test having it connected to our intake pipe as well.
ptuning is offline   Reply With Quote
Old 08-22-2013, 03:30 PM   #579
ptuning
ptuning's Avatar
Drives: White FR-S
For those that have pre-ordered or are looking to order our turbo system, here are some more teaser pics of a few more production pieces.
We're just showing you guys the final products, not the many iterations that we may have gone through to make things perfect for this turbo system. We've had two CAD stations going non-stop during work hours for the past 3 months.
All parts are laser-cut, CNC formed, and are either powder coated lightweight aluminum or T304 stainless steel. Whenever possible, we use PEM's inserts too for easier installation of components.
Furthermore, for those that don't already know, ALL of our turbo and exhaust system components, actually all products in general, are made right here is the USA.
Now onto the pics:
Thick gauge T304 SS turbo support brackets prior to welding:
T304 SS Tial turbine housing heat shield:
Thick gauge T304 under tray support bracket:
We're still waiting on our production two-piece welded and powdercoated aluminum air intake shroud, but here is the aluminum shroud support bracket:
Powder coated aluminum oil scavenging pump bracket:
The Following 6 Users Say Thank You to ptuning For This Useful Post:
civicdrivr (08-22-2013), ecko04 (08-22-2013), kanundrum (08-22-2013), mnsayer (08-23-2013), Sbeezy (08-22-2013), SnapOv3st3r (08-22-2013)
Old 08-23-2013, 09:21 AM   #580
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Absolutely wonderful :-) this dedication to perfection and reliability really makes the wait worth while (coming from a guy who hates waiting 2 days for an Amazon shipment lmao)
MooKz is offline   Reply With Quote
The Following User Says Thank You to MooKz For This Useful Post:
ptuning (08-23-2013)
Old 08-23-2013, 09:57 AM   #581
Dinko
Drives: Scion FRS
Very awesome indeed and thank you for the pictures!!!
Dinko is offline   Reply With Quote
The Following User Says Thank You to Dinko For This Useful Post:
Old 08-23-2013, 07:20 PM   #582
MDSubarubrz
Drives: 2013 Subaru BRZ
Just spent a couple hours reading this thread beginning to end. Everything looks absolutely amazing. I don't think I could even consider another company after seeing step by step everything you have done throughout the entire R&D and production process. Transparency and honesty go a long way. Should I bite the bullet and go FI (and manage to put away that much $) I would not give my business to anyone else. I can see how you get your outstanding reputation. Thanks and keep up the hard work! Hope to work with you soon!
2013 Subaru BRZ Limited-
35% Tint ** 2" Perrin Stubby Antenna ** Plastidip White Wheels ** Interior + License Plate AutomationLED Package
..... So Far
MDSubarubrz is offline   Reply With Quote
The Following User Says Thank You to MDSubarubrz For This Useful Post:
ptuning (08-27-2013)
Old 08-23-2013, 07:33 PM   #583
MooKz
MooKz's Avatar
^ Agreed!! Can't wait till we have our own little Ptuning Turbo Kit thread :-)
Old 08-26-2013, 06:18 AM   #584
FR-Sizzle
Drives: brz
Originally Posted by ptuning View Post
That's totally understandable. No CARB exemption is a deal breaker for most Californians. Again, that's why we've always believed that no one product will fit everyone's needs.
Having lived in CA and FL, I have to say that CA weather is so much better (no humidity), but then again, owning a modded car there is definitely a nightmare.
I was hoping this turbo would work for us Cali people. Keeping the stock headers is what intrigued me at first but then I realized that the front/over pipe isnt stock so there isnt the 2nd cat which is needed for CARB.
Wish someone could make a kit like this that would work with both stock cats. Sucks because you need to retain both cats to have Carb exempt and most turbo kits use there own header. My dream would be to have a turbo like this that uses the OEM air box but it seems like for turbos you need to either have it attatched to headers or the front / over pipe from what I seen from all the turbo kits available. Us Californians get screwed for everything here.
FR-Sizzle is offline   Reply With Quote
Old 08-26-2013, 11:45 AM   #585
SnapOv3st3r
Drives: 400whp Scion tC
^You guys get all the other attention in Cali (shops, track media coverage...etc). Glad PTuning is on the East Coast.
SnapOv3st3r is offline   Reply With Quote
The Following 9 Users Say Thank You to SnapOv3st3r For This Useful Post:
civicdrivr (08-26-2013), diss7 (11-30-2013), ecko04 (08-26-2013), kanundrum (08-26-2013), MDSubarubrz (08-26-2013), mnsayer (08-27-2013), MooKz (08-26-2013), ptuning (08-27-2013), Sportsguy83 (08-26-2013)
Old 08-27-2013, 12:21 PM   #586
ptuning
ptuning's Avatar
Drives: White FR-S
Yeah, we love almost everything about Cali except for CARB LOL.
The Following User Says Thank You to ptuning For This Useful Post:
MooKz (08-27-2013)
Old 08-27-2013, 12:25 PM   #587
ptuning
ptuning's Avatar
Drives: White FR-S
Ramping up production. Welding up our CNC formed intercooler end tanks.
The Following 4 Users Say Thank You to ptuning For This Useful Post:
kanundrum (08-27-2013), mnsayer (08-28-2013), MooKz (08-27-2013), SnapOv3st3r (08-27-2013)
Old 08-28-2013, 01:19 AM   #588
ptuning
ptuning's Avatar
Drives: White FR-S
Here's an example of the design and engineering that goes into every PTUNING product. This is why it has taken so long for us to complete our FR-S/BRZ WMI System. We've literally taken hundreds of different measurements and have gone through multiple physical prototype designs to come up with a final design that is simple to install, simple to access, and ultra clean looking.
First three designs concepts:
Final design concept. Includes an integrated power and control module unit along with a billet aluminum mini battery tray holder:
civicdrivr (08-28-2013), ecko04 (08-28-2013), kanundrum (08-28-2013), MooKz (08-28-2013)
over 9000, ptuning, turbo kit
FA20CLUB.com Turbo Kit Sneak Peek.... FA20Club.com Forced Induction 98 12-14-2013 02:34 PM
Sneak peek at new 57Xtreme? vividracing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-07-2013 03:24 PM
Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. P&L Motorsports Forced Induction 179 01-31-2013 08:32 PM
AFE PROTOTYPE EXHAUST: SNEAK PEEK! autofashionfred Engine, Exhaust, Transmission 20 08-13-2012 02:22 PM
Tsukuba Circuit BRZ/FRS showdown Sneak Peek AVOturboworld BRZ First-Gen (2012+) — General Topics 19 06-23-2012 12:13 PM
