#393 | |
Thanks, yeah it's on e85. It seems to be a little louder (whines more) on 93 but maybe that's just because it's slower and I perceive more noise than movement.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#394 |
Drives: 2013 SWP BRZ
quality build, i am envious.
PLEASE post up some videos from VIR with that thing! I'm dying to know how the Innovative SC handles track duty. |
#395 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#396 | |
#397 |
Drives: 2006 WRX TR
Location: 1080 Motor City Drive , Colorado Springs 80905
Love this build thread keep it up
| The Following User Says Thank You to HeubergerMotors For This Useful Post: | swift996 (08-21-2013) |
#398 |
Drives: 86
Awesome car.
Small question. can light wight pulleys be used with innovate SC?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#399 |
Thanks and yes they can. I might upgrade to some when I get a smaller pulley but given the layout of my header it looks like I'd have to remove it to get the crank pulley bolt out, so I don't know yet. Essentially it would reduce the parenthetic drag helping give back the few ponies it robs from the engine and give quicker engine response.
| The Following User Says Thank You to swift996 For This Useful Post: | 8686 (08-22-2013) |
#400 |
Update:
I received a bunch of goodies in the mail. I'm about to install my rear tow hitch, 3-bar MAP sensor, and flash my new tune (update to follow). I received: - A spare belt - Sonax wheel cleaner (used a full bottle trying to clean my wheels last time!) - OBD II extension - Perrin rear shifter bushing - Omni Power 3-bar MAP sensor - First pre-read book for my MBA program I start in two weeks (UNC Kenan-Flagler) ![]() ![]() I also got the car detailed today. I had some soap suds building up on the car so they took care of that with a clay bar and put down a coat of wax. ![]() Now to get busy with some install..I should receive my 2-liters of oil today (top off the oil) and will receive my trailer light wiring kit tomorrow. Stay tuned!
#401 |
Drives: 2012 FR-S and BR-Z
super clean build!
| The Following User Says Thank You to Evasive Motorsports For This Useful Post: | swift996 (08-22-2013) |
#402 |
Update:
I pulled the rear bumper off and installed the tow hitch. It lays against the stock muffler a little bit so I stuck an old exhaust gasket between to cut down on any vibration. I'll deal with it later, it's not rattling but the exhaust echos through the bumper a little...actually sounds like a mild aftermarket muffler I ran into an issue when installing my MAP sensor. It was reading high voltage. It seems that the innovate MAP extension might have got messed up when I installed it. I removed it and just tugged the factory MAP cable and it just gets around and on. I got my oil and topped it off (was about 1/2 a quart low from the perrin oil cooler install): ![]() Rear bumper removed: ![]() Sits right flush in there: ![]() ![]() But to get the stock bumper beam back on you need to trim a little edge off to get it over the tow hitch. I used an angle grinder and took my time to make it clean. For me it was easier to take a little off both sides rather than more off one side: ![]() My welding/cutting gear (good thing it was 90 degrees today!): ![]() The bumper beam back on: ![]() My temporary ghetto rig: ![]() Nice and stealth even jacked up in the rear you can't see it: ![]() I get my wiring kit and ball tomorrow, hopefully everything goes well on the install. I pick up the trailer on Saturday and head to Richmond to visit a friend. Then it's on to VIR for two days! 3-BAR MAP sensor installed: ![]() I flashed the new tune from @moto-mike. So far it feels great, only took it for a quick spin. My boost hit 8.1 psi: ![]() I also installed the OBD II extension. Unfortunately it's a left hander and the cable wants to run that way given the orientation. So for the time being I just ran it under the dash panel (lower one under the steering wheel) and inside the weather stripping up to the dash for easy access to plug in my bluetooth adapter.
| The Following 3 Users Say Thank You to swift996 For This Useful Post: |
#403 |
Update:
I received my tow hitch and wiring kit. I wired everything up in about 1.5hrs and got all packed up. Picking the trailer up in the AM and some E85 jugs tomorrow and off to VIR! ![]() ![]()
#404 |
Drives: G37x
I think your videos and write-up in this thread have me nearly convinced to get a BRZ and throw on the innovate supercharger. I got rid of my G37 and my old truck about 3 months ago, because we badly needed a new truck to fit the whole family. I did this with the intention of eventually purchasing another car as a DD. After looking at Everything in a $50k price range, I'm disappointed with what exists out there. Have checked out everything from the Infiniti Q50 to the 135is, 335i, CTS-V, Mercedes, and even Lexus. I don't need a luxury car anymore, refuse to buy a WRX STi, and have already been the Evo route a few years back. I like the price of the BRZ, and that it's a RWD car. If they had a turbo version, I'd buy it without hesitation. This seems to be the best bet without having to spend $6k + tune on a turbo kit, and a much more difficult install. Having a 9 month old kid, time is something I don't have a lot of anymore. I plan on getting a new vehicle near the end of the year, so I shall keep up on what you've been doing. Thanks for all the info.
#405 |
Got back from VIR:
Check here for pics/video/etc: http://www.ft86club.com/forums/showthread.php?t=45394 Perrin Oil Cooler working good!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() Last edited by swift996; 08-28-2013 at 11:06 AM. |
#406 |
NASA SpecE30 Racer
Oil temps look awesome. Great to see Forced Induction cars doing track days. Did you have any fuel starvation issues? How low did you run the tank?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| 2013 BRZ Limited (black) | Epictetus | Cars for Sale/Trade | 2 | 11-14-2012 12:38 PM |
| My crystal black brz limited | chadz | Member's Car Journals | 37 | 09-12-2012 07:26 PM |
| BRZ, Black, 6MT, Limited...DELIVERED! | boarder1995 | BRZ First-Gen (2012+) — General Topics | 3 | 06-14-2012 05:03 PM |
| Need a black AT Limited trim BRZ! | jaytaurus | Northwest | 4 | 05-18-2012 06:29 PM |
