Old 08-18-2013, 05:02 PM   #267
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Ran at Sebring again without a cooler.
Last time (June 2013 in the high 80s and low 90s) oil temps on Day 1 were 290-300*, then Day 2 oil temps were 285-294*, and I was running, and then yesterday, with temps in the 90s, oil temps were 278 to 284.
Weird that oil temps keep getting lower and lower.... In June I was running German Castrol 0w30, yesterday I was running the Toyota 0w20, but theoretically the heavier weight oil should help keep oil temps down. Back in June the car had 1k miles on it and it was the first track event with the car, and yesterday was the 3rd event with 2k miles on the clock.
And water temps on every day have been between 205 and 215, so water temp is fine.
Still not convinced on the need for an oil cooler.
Also had the pleasure of seeing this thing on track. Very surprised to see it running stock calipers! Not sure if they are running an oil cooler.
smbstyle is offline   Reply With Quote
The Following 2 Users Say Thank You to smbstyle For This Useful Post:
orthojoe (08-18-2013), smmmurf (08-20-2013)
Old 08-21-2013, 08:28 AM   #268
swift996
swift996's Avatar
Check out this post I just put up on some data collection.
http://www.ft86club.com/forums/showt...53#post1156053
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-21-2013, 09:10 AM   #269
maj75
Drives: Blue FRS 6sp, 95 M3
And where would one find these for sale? I went to a Robispec site and could find no listing for an oil cooler, sandwich plate or anything to do with engine cooling. In fact, no engine part were listed at all...
A link would be appreciated. I am prepping my car for an October Sebring HPDE and need to get a move on.
Originally Posted by robispec View Post
whatever oil cooler you want you may like our take off plate.
drilled for sensors too
no thermostatic option available.
maj75 is offline   Reply With Quote
Old 08-21-2013, 11:37 AM   #270
Wepeel
Drives: '13 BRZ Ltd
For autocrossers who might be logging... what kind of oil temps do you see?
Wepeel is offline   Reply With Quote
Old 08-21-2013, 12:19 PM   #271
charged86
charged86's Avatar
Some have said 130
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-21-2013, 12:23 PM   #272
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by charged86 View Post
Some have said 130
130C? Wow that's a lot hotter than what I would have suspected for autocross.
Old 08-21-2013, 01:11 PM   #273
dsgerbc
Drives: BRZ(sold), STI
Cooler and heavier oil means your pistons are getting fried.
Old 08-21-2013, 01:36 PM   #274
smbstyle
smbstyle's Avatar
uh, where are you drawing this logic from? care to elaborate how running 0w30 vs. 0w20 will "fry" your pistons?
Thicker oil is going to offer slightly better protection at those high temps. I'm not saying dump gear oil in the car, it's one step increase in viscosity, which Subaru actually recommends for harsh/aggressive driving
Old 08-21-2013, 01:56 PM   #275
dsgerbc
Heavier oil -> less flow at high rpm -> less cooling of pistons=hotter pistons. Thicker (synthetic) oil does very little in terms of oil film strength. Heavier oil recommendation in the manual is probably a carryover from old manuals written for dyno oil. I just run 0w-20.
Old 08-21-2013, 02:35 PM   #276
smbstyle
smbstyle's Avatar
Sure, definitely understand. I think the old logic behind running heavier weight is for better protection, but I don't think it's reasonable to say that 0w30 from 0w20 will "fry" your pistons?
Old 08-21-2013, 03:03 PM   #277
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
My Subaru service adviser specifically said to run a heavier weight oil if I plan to track the car.
Old 08-21-2013, 03:51 PM   #278
brillo
Drives: 2013 Firestorm FR-S
is there any issue running a 0w-20 weight oil with an oil cooler as far as oil pressure? I thought I saw someone post about that indicating you needed to up the weight to compensate.
In general I haven't seen Perrin, Mishimoto or any of the folks offering a kit mentioning this. Has anyone tested their oil pressure with a cooler?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 08-21-2013, 03:56 PM   #279
smbstyle
smbstyle's Avatar
Yes I believe @Dave-ROR did some testing and found a pressure drop when installing the oil cooler, and that 0w30 fixed the issue, but I'd check with him to verify.
Old 08-22-2013, 07:51 AM   #280
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Can someone cite what the oil pressure should be at a specific RPM? I'd like to know to see if I've lost or gained pressure by adding my oil/water laminova cooler.
mtimney is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
