Old 01-16-2012, 03:39 PM   #43
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
US equivalent to ZC6A2-E8-2FC-7J @ 26-29k USD
thats where im going
also...the fact that GT5 has the right ratios for this car is WIN!!
WingsofWar is offline   Reply With Quote
Old 01-16-2012, 03:56 PM   #44
Tbxgz
Tbxgz's Avatar
Drives: 2013 BRZ Limited 6MT
zc6a2-e8-7j?
Tbxgz is offline   Reply With Quote
Old 01-16-2012, 03:57 PM   #45
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Originally Posted by DSPographer View Post
My calculation doesn't agree with that value. The ETRTO rolling circumference for a 215/45R17 tire is 1907mm according to here:
http://www.club80-90syncro.co.uk/Syn...calculator.htm
Even calculating for increased circumference at a speed of 100 km/hr for 215/45R17 87W here:
http://bndtechsource.ucoz.com/index/...alculator/0-20
Only increases the circumference to 1909.7mm. So my calculation for 2nd gear at 7500 RPM is:
1909.7/25.4/12*7500/(4.1*2.188)/88 = 59.5 MPH.
This value seems a bit too low for good 0-100 Km/hr. times unless the fuel cutoff is extended slightly in second gear. Given the 3.727 rear end ratio then 2nd gear reaches 65 MPH at the stated 7450 red-line: which seems higher than expected from some of the posted videos. I wonder what ratio Subaru will use in the US?
BTW I noticed that the gear ratios including the 4.1 rear end ratio are exactly as given in the GT-5 game as I posted here:
http://www.ft86club.com/forums/showp...5&postcount=25
http://www.ft86club.com/forums/showthread.php?t=2500
If you watch the silver/blue BRZ video you can see it hit 100kmh=62mph in 2nd.
Spaceywilly is offline   Reply With Quote
Old 01-16-2012, 04:00 PM   #46
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Originally Posted by Tbxgz View Post
zc6a2-e8-7j?
ZC6A2E82FC7J
ZC6A2=BRZ
E8 = 6mt Premium Model
2FC = All Limited Options
7J = Satin White Pearl
Old 01-16-2012, 04:19 PM   #47
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
thats where im going....
ZC6A2E82FC7J
ZC6A2=BRZ
I think you are spot on WoW. Just hoping for the low side of that range.
BRZGrincherhood
Zgrinch is offline   Reply With Quote
Old 01-17-2012, 06:24 AM   #48
ajc209
Drives: GT86 Cosworth
I was using a different wheel diameter... I would think the rev limiter is at 8000RPM so you should be able to hit the magical number: 62MPH. Although the momentum at 59.5MPH will keep it going so I dont think it will lose too much time. I would trade a good 0-62MPH for a good 40-80MPH anyways.
Also if you factor in the most of the time the speedo is usually 3-5% under it will "look" like it donig 62MPH at the red line anyway.
ajc209 is offline   Reply With Quote
Old 01-17-2012, 06:26 AM   #49
ajc209
Usually the speedo is slightly fast. Most of the time its about 3-5% over. DOnt forget that when you hit the clutch, the car is still carring momentum. But the time 3rd is enguaged it will be over 62MPH.
Old 01-17-2012, 07:52 AM   #50
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
I read a while ago that fuel cutoff is very close to redline. FWIW, you can not hit 8000 RPM in GT5.
Deslock is offline   Reply With Quote
Old 01-17-2012, 11:31 AM   #51
BeRZercar
Drives: 2007 Impreza Wagon
A minor point guys, but momentum won't keep it accelerating, keep it moving yes, but not accelerating. If you disengage the clutch at 59mph on a flat road it's not hitting 60.
BeRZercar is offline   Reply With Quote
Old 01-17-2012, 12:06 PM   #52
ajc209
This is true.
Anyways 59.5MPH is close enough to 60MPH. When your racing that 2.0TFSI Rocco/A3 its only going to help having shorter ratios
Old 01-17-2012, 12:07 PM   #53
ajc209
At what RPM does it cut out in GT5?
Old 01-17-2012, 12:12 PM   #54
Kunzite
Drives: Toyota Auris
Unless going downhill, or in free fall
Kunzite is offline   Reply With Quote
Old 01-17-2012, 01:04 PM   #55
BeRZercar
^That would then be gravity, not momentum... can you tell I'm in engineering?
Old 01-17-2012, 02:16 PM   #56
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
^Truth.
2012 brz, 2012 subaru brz, 2013 brz, 2013 subaru brz, brz forum, brz forums, subaru brz, subaru brz forum, subaru brz forums
Subaru BRZ Chop *Updated with full body chop* Snoopyalien24 BRZ Photos, Videos, Wallpapers, Gallery Forum 32 10-19-2012 07:55 PM
Scion FR-S / FT-86 / Subaru BRZ Specs and Options. 200hp / 151 lb-ft tq Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 510 09-03-2012 07:39 AM
Full Specs and Info on GREDDY SCION FR-S vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 109 01-03-2012 12:11 AM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 02:11 PM
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 07:43 PM
