Old 07-04-2013, 11:49 AM   #29
Tofu driver's Fr-s
Tofu driver's Fr-s's Avatar
Drives: Whiteout Fr-s
Originally Posted by Grey View Post
The Toyota part no. for this kit is PT413-18130.
These fog lights are available from any of the Toyota dealership vendors here on the forums. My local Toyota dealership met the best price on the forum with no charge for shipping. I paid $350 out the door for this kit.
Yes, it is more expensive than some other kits. Yes, some other kits use OEM parts and they look exactly the same. I justify the cost of this kit and rank it higher than the others because of the OEM dash trim and button, plain and simple. No aftermarket switch uglying up your dash, no screwing around with the stalk and steering column.
I couldn't see in the pics, but what is the bulbs wattage?
"The Dream"
Tofu driver's Fr-s is offline   Reply With Quote
Old 07-04-2013, 03:13 PM   #30
Grey
Ghost
Grey's Avatar
Drives: FR-S (Whiteout)
No idea, I assume 55? I'll go look for you in a few.
Edit: Yeah, 55W.
Grey is offline   Reply With Quote
The Following User Says Thank You to Grey For This Useful Post:
Tofu driver's Fr-s (07-05-2013)
Old 08-01-2013, 03:48 PM   #31
mush
mush's Avatar
I cant for the life of me get the inner clips to snap on for the bezel
Old 08-06-2013, 06:53 PM   #32
UsAhop
UsAhop's Avatar
Drives: Argento Scion FR-S
I'm thinking of switching out the foglight bulb for a HID 6000k.
UsAhop is offline   Reply With Quote
Old 08-17-2013, 02:45 PM   #33
1010110
Drives: 2013 Scion FR-S Manual in Whiteout
Here are the official install instructions.
1010110 is offline   Reply With Quote
The Following 4 Users Say Thank You to 1010110 For This Useful Post:
6spd (10-02-2016), idreamofdrifting (11-28-2014), slim blanco (08-25-2014), Thedishdoc (01-30-2019)
Old 08-17-2013, 03:59 PM   #34
FR-S Matt
Installed this kit a few weeks ago. Very simple. I swapped out the stock bulbs for 6000k LED's from HID_Powerhouse to match my 6000k HID's and DRL's. They look amazing. I put turn signals in that aren't illuminated unless I signal. Having the signals on and the fog lights together was just too much.
Old 08-18-2013, 12:19 PM   #35
1010110
did you remove your bumper? I found most of the install simple except removing the driver side turn signal harness.
Old 08-18-2013, 02:53 PM   #36
FR-S Matt
Yes, I removed my bumper and took it inside. That way I can check every clip on the bezel, make sure they're all snapped, then mount the light. Very easy if you pull the bumper. It would be very hard if you followed the directions to a T.
Old 08-18-2013, 03:31 PM   #37
1010110
I did the install yesterday as per the instructions. It was certainly doable, but very frustrating trying to unplug those harnesses. The rest of the install is very simple.
I'm a little hesitant to remove the bumper because of the reports that it doesn't always line back up when reinstalled. I was going to wait to install radiator, oil cooler, and turbo all at once so I only have to take the bumper off once. Matt, did you have any issues realigning?
Old 08-18-2013, 03:31 PM   #38
mush
mush's Avatar
those clips were pretty tricky, it was getting hot and i was getting frustrated so i stopped lol
i got it to snap on the next day.
i didnt remove my bumper or raise the car to install these
Old 08-18-2013, 11:40 PM   #39
FR-S Matt
No, I haven't. I've taken mine off 3 times or so. I just carefully snap it back.
The Following User Says Thank You to FR-S Matt For This Useful Post:
1010110 (08-19-2013)
Old 08-19-2013, 04:38 PM   #40
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
how did you manage to get to the turn-signal harness w/o removing the bumper? i thought i tried every which way...
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S
Current: 2015 Tacoma/2020 Sequoia Pro
Future: 2022 CWP Limited Est Delivery 06/22
euroshowoff is offline   Reply With Quote
Old 08-19-2013, 05:26 PM   #41
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
How to Access the Front Signal Connection without Removing the Front Bumper
Very simply undo the front part of the wheel well liner and that would actually be easier if you lift the front end of the car.
We are talking some 5 or 6 retainer clips per wheel well liner and then you can - easily - access the electric connection directly above\in-front of the unclipped liner.
I would think you don't want to mess with removing the front bumper.
Zagmeister is offline   Reply With Quote
The Following User Says Thank You to Zagmeister For This Useful Post:
euroshowoff (08-20-2013)
Old 08-19-2013, 09:17 PM   #42
mush
mush's Avatar
yup thats what i did, my garage has a little step so i had the front wheels at the edge of the step for more clearance
TOYOTA emblem... JDM vs USDM lbroskee Cosmetic Modification (Interior/Exterior/Lighting) 89 08-15-2013 04:00 PM
Has anyone install a light weight flywheel? 20valvewynn83 Engine, Exhaust, Transmission 44 08-08-2013 10:52 PM
Custom Third Brake Light Install (incl. Pics) Skorov AUSTRALIA 14 07-27-2013 05:04 AM
Glovebox LED light Install Tech DIY (Do-It-Yourself) Guides 0 03-26-2013 08:21 AM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 08:11 PM
