#15 | |
However, if I don't do the pedal dance, VSC/TC will kick in virtually every time there's even a HINT of wheel lift. Additionally, I can't trail brake without the pedal dance. Autocrossers generally brake deep, rotate, and power out, due to the nature of their setups (they favor quick small direction changes and fast response, over static cornering grip; this is MASSIVELY beneficial in slaloms, but at the cost of heavily pushing in sweepers). This makes it so they don't run into the trail braking problem that I have. I can't count the number of pictures of my car (and most cars I drive) on two wheels. These pictures are at different corners. CSG David: Me:
#16 | |
Drives: 2013 BRZ Ltd. MT
You're on the power, though, right? You're not braking heavily at that point. Don't some of the autox guys suffer from increased "ice mode" incidents with the pedal dance? They're still braking when they raise up and lock one wheel, which the ABS dislikes intensely it appears. "Do that, will you? I'm taking away your brakes, then!"
#17 | |
As always, YMMV, but my on-track experience is duplicated by quite a few guys in SoCal. |
#18 | |
Oh, I believe you, Mike. Always have. Your experience is what encourages me.
#19 |
Drives: Subaru BRZ Sport Tech Satin White
I thought the traction control off setting cannot be actuated if the traction control has been active at any time during an ignition cycle. Not the pedal dance (which I shall try) but the press and hold traction control off. I've had to switch off and restart the engine to be able to switch off the traction control if it has been active.
#20 | |
#21 | |
Drives: Attitude
Mike, if you're lifting rears a lot... have you considered different (sprung stiffer with firmer rebound) shock tuning and removing the rear anti-roll bar? |
#22 |
EBD is just a refinement of ABS. Brake proportioning valves limit brake line pressure to the rear wheels mechanically. ABS can do the same job electronically.
EBD is more active in cornering or other left to right asymmetrical road grip situations. Lifting two wheels on the same side of the car isn't maximizing available grip. Lifting one wheel (should be the inside front for rwd and the inside rear for fwd) is an artifact of roll stiffness compromises. Ideally, the roll rates are adjustable front to rear an all four wheels will contribute cornering grip. If fixed roll rates are required then maximum grip will inevitably lift the inside none driven wheel. The more power you have the sooner that inside wheel will lift if you seek maximum cornering grip under power. Under braking all four wheels should be firmly on the ground. |
#23 | |
#24 | ||
No we're not. At least I'm not sure. My reading tells me that the EBD has replaced the mechanical proportioning valve on modern cars. I don't know if that's true. I'm thinking, as perhaps you are, that surely they must have some mechanical backup to prevent rear wheel lockup in the event of EBD/ECU malfunction. But, I don't know.
That's why I'm asking people with more experience driving these cars with EBD disabled. I'm reluctant to employ empirical testing on public roads. I don't like the lack of runoff areas, among other things. I certainly don't wish to learn about this at the expense of a fellow motorist. Quote:
It gets "applicable" right quick when the rears try to pass the fronts heading into a corner. Try it sometime. Then come talk to me. I'll buy you a beer if you survive the experience. ![]() Quote:
Perhaps we have a different idea of the function of the EBD system. My understanding is that this system provides a level of control heretofore UNAVAILABLE to a driver. Basically, the EBD/ECU controls the braking force at EACH individual wheel, independently of the other three wheels. I never saw a road car with even two, never mind four brake pedals, the EBD equivalent. People whine about heel-toe being difficult. Imagine giving them FOUR brake pedals. It would be a Candid Camera moment, don't you think?! Even in modern race cars, I doubt the driver is manipulating the front/rear brake bias LEVER in real time in the midst of heavy braking, down into a corner. She sets it and then accepts the level of front/rear bias for the upcoming corner. There's no skill involved other than the normal threshold braking skills required; the front/rear bias is set, at least until she adjusts the lever again. In any case, none of this is applicable to any road car I've ever driven. The front/rear brake balance is what it is, as set by the manufacturer in my cars. It's not something I can alter through skill in real time on the road. As Mike alluded to, I can alter the balance a bit with different pad compounds, etc. But, again that's a fixed state, once selected, and cannot be altered on the road by any especially skillful use of the brake pedal by anyone or me. Again, I've read that modern cars do not have brake proportioning valves, which leaves me wondering what happens when we turn off the EBD? Does it bite, now? I don't know. Like you, my first thought is that they cannot be that stupid as to create a monster in the absence of a functioning EBD system. Well… Mike assures us that this is not a problem. He's driving the car at the limit, or close enough that his experience reassures me that it would be safe on the public roads. Call me cautious, though. I should add, too, that where I'm really going is here: I want to turn off the ABS, too. Don't like it. It's dangerous, in my opinion. (But, we're straying way too far from the OP's questions.) Where will that leave me? In a coffin, maybe? ![]() I wouldn't like that. I've asked people to disable everything, pull the ABS fuse, and hit the track. Then tell us about it. So far, I have not read of anyone doing this. Care to be the first? It could be perfectly safe on some tracks at certain corners, I'd think. Just don't do it where you could hit anything if things go awry. Safety first. If it doesn't work out, return to the pits and plug that ABS fuse right back in. I long for yesteryear when cars were simpler and the man at the wheel was in control, not a computer. Ah well, nice chatting with you. :happy0180: |
#25 |
#26 |
#27 | |
Now when our tires are bald.... (might have to wait a bit). |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Porsche (08-18-2013) |
#28 |
Drives: UK GT86
Check out Fensport's car here in the UK. Its a turbo track car (GT86R) and he runs the Toyota Sprint Series. He removed the ABS fuse and did nothing but slow him down. The brakes just liked to lock up and made the car unstable.
http://www.gt86ownersclub.co.uk/foru...able+ABS#49563
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Porsche (08-18-2013) |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 02:48 PM |
| CEL Traction Control ON then OFF | HATED1 | Issues | Warranty | Recalls / TSB | 5 | 09-24-2012 08:11 PM |
| TPMS and Traction Control | Mavrik | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-02-2012 02:50 PM |
| traction control issue | *KID* | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 07-08-2012 09:13 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
