#43 | |
I cut that brown wire half and connected it as described in DIY, but still no trunk pop. I don't know what I did wrong. |
#44 |
Drives: Firestorm FR-S AT
Hi guys, I installed this kit in my FR-S this weekend, and I thought I'd share some notes.
First of all, many thanks to Chaetagnath for the DIY, it was very helpful. Its possible that I'm the first in Canada to have this done, since EasyGo (selling via Amazon.com) doesn't ship to Canada. I contacted EasyGo about this, and they said they will be selling via Amazon.ca "soon", but I didn't want to wait so instead I used a service called Kinek.com. Basically you have your package shipped to a location just across the border (in the US, Lewiston NY in my case, but they have a whole bunch of locations) and then you drive down and pick it up. Cost me $10 plus the gas to get there and back. Of course, this only works if you live within a "reasonable" distance of the border, which I do (about 1.5 hours). Plus I'm still breaking in the engine so I'm happy to put some KMs on. ![]() I started about 10am on Saturday, went till about 9:30pm, and then spent about another 4 hours Sunday afternoon. I think it would have been twice as fast if I'd had someone helping me. As I was I constantly had to stop what I was doing to go back and refer to the DIY pictures and other documentation. But nothing about it was really hard. Well, aside from running the wire from the door to cabin, as has already been mentioned. That was really a bitch. Also, I wasted a good two hours on a really stupid thing. Turns out the brain will refuse to lock the doors via the keyfob if the door is open, and since you are working on the drivers side you probably have the door open. Unlock works, lock doesn't. I thought I had a wiring problem. Even worse, on Sunday when I was finishing up I couldn't get the locks to work again, even with the door closed! The "door open" light on the dash stayed on even with both doors closed. I was freaking out, I thought I had fried something. Turns out the car considers the trunk to be a "door", and I had the trunk open. Closed the trunk and everything started working. ![]() I used T-taps for the wiring and was pretty happy with how they worked. But it is cramped down there. When shopping for the Scytek Inverter, be aware Scytek also has a similar device called the DLRM. I ordered this by mistake, because it said "Inverter" in the description of the product and it looks really similar (slightly bigger, a couple extra wires). I had trouble getting the locks to work on Saturday because of this, and I thought I was screwed. But I did some research Sunday morning and it turns out you can wire this thing to be a an inverter so I was ok. But just buy the right thing and you won't have to worry about it. ![]() Related to this, I bought the fuse tap as suggested to power the inverter, but I bought the wrong one (I needed a *mini* fuse tap). So instead I just put a t-tap on the 12V line of the ignition harness, problem solved. I kinda prefer this anyways because I can put the lid back on the fuse box. As with the other guys, the remote start doesn't work (starts, runs for 3 seconds, stops) and the trunk release doesn't work. I contacted EasyGo today and they are going to send me a new brain. I was hoping the box I was sent would already have the brain with the "fix" but no such luck. Installing the door handle was pretty easy (except for the wire as mentioned above), and the paint matches perfectly (Firestorm Red), in case anyone was worried about that. As for running the wire I ended up using a unbent metal clothes hanger, with the wire taped to it to fish it through the rubber piece. I think it would be much easier to do if you just took the door completely off, but I don't know how hard that would be. Installing the button itself was the easiest part. Contrary to the instructions I found I didn't have to remove the center console. I just popped off the trim on the right side and reached up inside and pushed out the USB connector (as described) and the just pulled out the panel out. The new panel with the button then just popped back in. Then just fish the button wire out the left side. Took 5 minutes. I used option A for the steering wheel lock, which worked great, except that the cover won't go on because the key is in the way ( the cover has a stem which is supposed to slide into the cylinder where the key is supposed to go). So I'm not sure what I'm going to do about that. I might look at option C, or maybe cut the stem off and glue the thing on somehow. It was a little pricey (I figure it'll be $750-$800 by the time I'm done), but I'm super happy with it. I grin every time I push that button and the engine fires up. |
#45 | |
Drives: Whiteout FRS
#46 |
Got the new brain last week and installed it Saturday, the remote start now works! But, as with @nunonuna, the trunk release still doesn't work (which was really the thing I was more worried about).
I'm pretty sure I've got the right wire, because if I disconnect either of the two wires (red/black and white) then the trunk release button on the dash doesn't work. And when I push the button on the remote for the trunk release I can hear the brain clicking (relay I assume). Contacted EasyGo support, I'll see what they say. |
#47 | |
Did they send you one? And did you try to hook it up with relay? |
#48 |
Sorry for the delay, had some trouble with this and finally got it sorted out last night.
Yes, apparently it requires an extra relay. They didn't send me one (I guess they were supposed to) but I just ran out and got one, $3 at the surplus store (the local auto parts store wanted $26!). Also got a socket for the relay that made it a bit easier to wire up. I guess these relays are pretty standard, if you find a 5 pin relay that has the pins numbered as described below (30,85,85,87,87a) then you have the right thing. If you followed the instructions in the DIY you cut a the brown wire to hookup the red/black and white wires from the brain. So, disconnect those and wire up the relay like this: 87 and 86-12 volts constant 85-red and black wire from the brain (trunk release wire) 87a-cut trunk motor wire(car side) 30-cut trunk motor wire (trunk side) The white wire from the brain is not used. This works. I originally connected the 12v to the ignition harness, same 12v I used for the Scytek Inverter. But when I popped the trunk the car would come on into ACC mode (!). So I changed that and tapped the fuse box (as described in the DIY) and now it seems to work fine. Apparently this is an FR-S specific issue, as support says the brain works fine with all other Toyotas and Subarus they have tested without the extra relay. I have to give props to the company, both support (for dealing with this issue) and customer service (for handling the replacement brain) were very helpful and responsive. |
#49 |
Drives: Toyota GT86 2015 Black Aero Kit.
for the trunk release, are you guys sure you wired it correctly?
according to http://www.ft86club.com/forums/showthread.php?t=30665 the trunk release is the blue cable. Maybe give that a try and see if it works? |
#50 | |
#51 | |
Blue wire never works for me too~ We have to deal with trunk motor not the switch. Last edited by nunonuna; 08-19-2013 at 01:41 PM. |
#52 | |
Hmm it is strange that it still happens to me despite I used 12v from fuse box. I just tapped the red wire from fuse tap which is already connected to scytek inverter. |
#53 |
I finally did Clutch bypass.
There are two switches attached to the clutch padel & the top one is the one I used. I will take picture and upload if I have chance. It works perfect and very useful. Sent from my Galaxy Nexus using Tapatalk |
#54 |
Memphis
Drives: 1989 MR2 S/C, 2014 Scion FR-S
would you be able to use the factory handles in place of yours?
"It's ok... It's not structural."- Mikey
#55 |
Cool Guy
sub'd
#56 |
Drives: 2014 Scion FRS
Any chance you can describe/picture this. would be much appreciated!
| Tags |
| easygo, remote start |
| STI Push Button Start | Proud of BOXER | Cosmetic Modification (Interior/Exterior/Lighting) | 117 | 08-05-2019 05:19 PM |
| Push Button start... | usptwins | DIY (Do-It-Yourself) Guides | 155 | 07-31-2019 11:10 AM |
| Q: push button start frs | blanco | Electronics | Audio | NAV | Infotainment | 8 | 08-09-2013 04:58 PM |
| BRZ STI push to start button | notFRS | Interior Parts (Incl. Lighting) | 4 | 04-24-2013 12:24 PM |
| TRD push start button | nix | Australia Classifieds | 1 | 11-27-2012 12:53 AM |
