#29 |
Drives: Some kind of Subaru
Thanks for sharing, though. |
#30 |
I have about 50 launches on concrete and 100 or so on asphalt with an RTR setup. No problems thus far. Don't recall ever experiencing wheel hop.
#31 |
Drives: 2013 FRS Asphalt
That guy posted on facebook not long after that about the diff saying it was actually the axle that gave out after they looked at it.
2013 Scion FR-S AT Picked up 5/30/2012
#32 | |
My rear axle started to click on Friday.
#33 |
Grip>Drift
Drives: FRS
I had this failure also. It happened to me back in June, I was around 33K miles at the time and around 35 autoX events most with co-driver. Also mostly concrete with 245 RS3s then 255 ZIIs.
#34 |
Was it covered under warranty?
#35 |
Grip>Drift
Drives: FRS
No, Toyota field rep denied the claim due to "the car being lowered which changes the axle angle." I had the car towed in on my autoX wheels/tires and I won't make that mistake again.
However the dealer was super cool, got the car back to me in 3 days and it was only just over $600 out the door for the DEALER to do it so. Regardless I think we've found the weak point in the driveline. I'll tale weak axles over weak ring/pinon anyday.
#36 | |
Was the axles clicking or clanking at all before they let go? And did both go or only one side?
#37 | |
Grip>Drift
Drives: FRS
I bet I'm also an inch lower than you. I'm on V3s.
#38 |
Ya I'm only 20mm lower then stock.
#39 |
Grip>Drift
Drives: FRS
I'm almost 2" lower in the rear. If it fails put it back to stock suspension (just springs leave dampers) and I bet warranty will cover it. My buddy is a tech at my dealer (who helped me get the car back super fast for more autoX) told me the field rep local to me sucks and is an asshole so I likely stood no chance of a claim anyway.
#40 | |
Did your carrier assembly also split in two like in the picture above? Wondering if that part of the axle is serviceable to save buying a new axle everytime.Also do you have a list of the part numbers needed to fix this?
| The Following User Says Thank You to feldy For This Useful Post: | whataboutbob (08-09-2013) |
#41 |
Are right and left axles the same part number?
#42 |
Drives: 2013 fr-s 6sp
If you're wanting to have warranty work done on your modified car you'd be a fool not to replace with stock IF THAT'S AN OPTION for you. Seems like common sense. Why give the dealer any sliver of a reason to back you into a corner with the whole "modified car spiel"? If you have the ability, go back to stock.
| DDM HID Problem | LinknLog | Cosmetic Modification (Interior/Exterior/Lighting) | 18 | 04-11-2013 01:43 PM |
| A bit of a problem | Gost | Other Vehicles & General Automotive Discussions | 13 | 02-12-2013 08:07 PM |
| Problem! | axss | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 11-24-2012 03:31 PM |
| ABS Problem | chrislee2423 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 07-09-2012 05:06 PM |
| anyone with this problem? | debs0712 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-30-2012 11:17 AM |
