Old 03-16-2013, 04:43 AM   #43
cruzinbill
Drives: Argento 6spd FR-S
Originally Posted by michaelahess View Post
On this car, a little bit of everywhere!
The trunk, parcel shelf, doors, rear quarter panels are pretty bad. The front doors actually aren't that bad, the firewall and floor seem ok to me.
Any larger panel will vibrate with a sub, and all the wire's and connectors that aren't wrapped in foam will drive you crazy. Pad as much as you can.
I agree for the most part. Tho I had no issues from the rear quarter panels, and had a ton of problems from the doors. Also, my exhaust heat shield is out of control at this point. I still need to address it.
cruzinbill is offline   Reply With Quote
Old 03-16-2013, 05:37 AM   #44
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by husker741 View Post
Where should I do this the most just to reduce rattle? I'm fine with road noise/exhaust sound, but I just don't want anything to rattle when I get my OEM Audio Plus system.
If rattle is your only concern then you only need some CLD tiles.
From Sounddeadenershowdown.com:
"CLD
Constrained Layer Damper. What we have traditionally called "Sound Deadener". Controls panel resonance"
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 03-16-2013, 08:43 PM   #45
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Yeah, probably varies a bit for everyone, the quarter panels don't rattle so much as "boom" with road imperfections. The CLD bits stopped that cold. The door beams had a bit of rattle, but CLD around them as best I could stopped that.
michaelahess is offline   Reply With Quote
Old 03-24-2013, 01:48 AM   #46
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Thanks for the input... I'm getting a good idea what to target. The Invidia N1 exhaust went on today and it's LOUD, but tuned with the Unichip is a nice bit of improvement, performance wise. However I will be addressing the boomy noise it makes starting tomorrow. Stay tuned for a new thread.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 04-05-2013, 04:22 PM   #47
l0aded
Addicted
l0aded's Avatar
Quick question: Will putting MLV in the doors significantly reduce road noise? Where should I deaden with MLV to effectively mitigate road noise? (not exhaust sound)
Old 04-05-2013, 04:41 PM   #48
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
I have a whole roll of this waiting for me to install. I don't know how much of a decrease it will be.
To reduce road noise, I would imagine that throwing MLV in the doors and rear quarter panels would give you the most benefit. Just remember that you need something like CCF to act as a buffer between sheet metal and the MLV.
rupert is offline   Reply With Quote
Old 04-05-2013, 07:26 PM   #49
l0aded
Addicted
l0aded's Avatar
I've heard about the CCF quite often; if I didn't use CCF would it be a drastic difference? In my trunk I used only MLV to reduce the exhaust note and it did a pretty good job.
Side question, is it necessary to have a perfect surround? If I use a few velcro strips to adhere the barrier to the door (not perfectly sealing every outer hole like glue would) would it be worse?
edit: After thinking about it it makes sense actually. Sound travels better through solids so creating a layer to decouple the metal from the MLV should noticably help reduce the sound. I may have to go back and stuff some CCF under my MLV in the trunk.
Old 04-06-2013, 12:20 AM   #50
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Originally Posted by WolfSongX View Post
Due to my back injuries, I missed out on much of the politics on DIYMA since I wound up unable to sit in front of the computer for long periods of time. It actually didn't change until I got my first tablet a few years ago. By that time I wasn't really spending a lot of time on forums and especially DIYMA because I was unable to work on my car.
Thankfully we've managed to get my back pain under control so I can do small projects without causing serious harm.
Parts Hurt and Distract. Been there, done that, fixed left knee lets me drive my 6MT BRZ. My dearly departed 88-year old, Mother once said that "Getting Old is Not for Sissies!"
Every day is a blessing, every meal is a feast.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 04-06-2013, 09:16 PM   #51
WolfSongX
WolfSongX's Avatar
Well said brother!!! Sounds like a very wise woman.
Not to start an auto vs manual flamefest, but I'm glad you've got the chance to enjoy this car like I have, with three pedals. There have been some infrequent days that I haven't been able to drive, and a few more where working the clutch hasn't been comfortable, but I don't think I made the wrong choice.
Derek
The Following User Says Thank You to WolfSongX For This Useful Post:
Brzzee (04-08-2013)
Old 04-08-2013, 01:10 AM   #52
Brzzee
Brzzee's Avatar
Knees and Other Important Things
Yes, she was. And no, you did not make a wrong choice, and your physical trials have been mine. Yet there is joy in perseverance.
There is a certain aspect to rebelling against the dying of the light that makes six consecutive, perfect shifts a point to remember on a gorgeous day with a lovely women who loves you and sits in the seat beside you.
My apologies to those who view this as off thread, but remember time waits for no one and those who have gone on before you deserve respect for having survived the experience.
Last edited by Brzzee; 04-08-2013 at 01:14 AM. Reason: "woman", sorry I'm not yet into fitting more women than one to sit in a BRZ front passenger seat!
Old 07-22-2013, 10:49 PM   #53
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
This was a great help to me, thanks!
The sound with stock door speakers is much improved.
Door closes with a thud, not a thunk/clunk.
The JPM Door speaker covers look so much better as well, thanks Andrew (JPM Coachworks)
I also installed JPM Coachworks Parking Brake Boot and Knee Pad
While I had the center console out I applied Raammat to the tunnel area in and around the Parking brake portion which is uninsulated from the factory.
I also applied Raammat to the area in front of the front seats on the floor and the area of the firewall that was reachable, the passenger side proved easier and more effective as the overpipe/frontpipe are close by. It is less noisy at WOT.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-07-2013, 03:51 AM   #54
WolfSongX
WolfSongX's Avatar
Thanks for posting your pics Tony, it's a very clean-looking install.
I love that "thud" sound, don't notice it as much with the BRZ (still more a "thunk" than a "thud") as I did with my Si, but I probably used 3 times the amount of Damplifier on that car. Used to be hilarious when someone new rode with me and was used to the stock Honda doors.
I may revisit the doors when I do the rest of the car now. I've been procrastinating, but circumstances now dictate I will be deadening and wiring the interior shortly.
Derek
Old 08-07-2013, 05:18 PM   #55
l0aded
Addicted
l0aded's Avatar
Anyone know where to buy MLV cheap? I just need like 20 sq ft (I'd like to pay less than 60 if possible..) but it's proving difficult since local shops are expensive and internet shops need bulk or have high shipping rates.
The best bet I found is ebay (http://www.ebay.com/itm/1lb-Mass-Loa...item1c1ec473e8) which sells 60 sq ft 1lb MLV for 134 free shipping which equates to $45 for 20 sq feet but I would need to find someone else to buy the 40 sq feet off me.
Old 08-07-2013, 06:06 PM   #56
rupert
rupert's Avatar
This is what I ordered:
http://www.tmsoundproofing.com/Mass-...d-40-feet.html
I know it is not the 20 sq/ft you were looking for, but it is less of the product.
What are you using for sound deadening ? mashal Electronics | Audio | NAV | Infotainment 108 11-06-2015 01:51 PM
SOUND DEADENING White64Goat BRZ First-Gen (2012+) — General Topics 7 04-22-2013 02:36 AM
Sound deadening yomchi1989 Electronics | Audio | NAV | Infotainment 16 01-02-2013 03:08 PM
Sound deadening yomchi1989 AUSTRALIA 9 12-27-2012 10:09 PM
Window not sealing NOHOME Issues | Warranty | Recalls / TSB 9 12-12-2012 03:57 PM
