Old 08-06-2013, 04:59 PM   #813
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by evo4g63 View Post
I did just that. Ran down to my local O'reilly's today and picked up an extra belt to have. I am suprised for as bad as my alt cover was chewed that the belt didn't really suffer any damage. I have since ordered a new cover and replaced. I keep checking tension and clearence now as I don't want this time happen again.
Very interesting, if you did not see any damage on the belt you should really investigate your auto tensioner. As mentioned I did have my stock one fail without the supercharger installed and my car was not even a year old.
mines13 is offline   Reply With Quote
Old 08-06-2013, 05:01 PM   #814
swift996
swift996's Avatar
On the topic of belts, I typically hear a little squeak between gears when shifting around 6k-6.5k rpms under WOT, shift, WOT. Normal, I'm assuming?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 08-06-2013, 06:01 PM   #815
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I looked at that as well. All looks okay as far as I can tell. Should I look for something else I may not be seeing on the tensioner.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 08-06-2013, 06:16 PM   #816
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
I dont hear any squeak with mine..
MattF is offline   Reply With Quote
The Following User Says Thank You to MattF For This Useful Post:
swift996 (08-06-2013)
Old 08-06-2013, 08:30 PM   #817
sw20kosh
Drives: 2013 Black FR-S
same. all I hear is the sweet supercharger whine when you get on it
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 08-07-2013, 03:44 AM   #818
evo4g63
evo4g63's Avatar
Had a few runs with a buddies Vortech car. The results were surprisingly very close. The Innovate kit gets the Vortech down low but his car would real me on up top. Vids coming as soon as they are edited. All runs done in Mexico of course
-2016 Subaru WRX
Old 08-07-2013, 09:32 AM   #819
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The racers around here run in Mexico too. Sounds like a pretty happening place.
The Following User Says Thank You to Draco-REX For This Useful Post:
evo4g63 (08-07-2013)
Old 08-07-2013, 09:38 AM   #820
Draco-REX
Corner Junkie
Draco-REX's Avatar
Have you changed your clutch yet?
Old 08-07-2013, 09:38 AM   #821
invisage
Drives: Thunder Silver 86 GTS
Absolutely, one may even see a decrease in boost pressure with optimized exhaust components and tuning, while still making MORE power.
What cat back is everyone running?
On my initial install I had the perrin header back installed (unresonated). Just upgraded the rest of the exhaust including headers to 2.5 inch and seen minimal gains and still showing ~10psi. The tuner is saying it's possibly the Perrin catback still restricting things (single pipe into one muffler then splitting). Has suggested a design similar to the invidia would flow better or going 3 inch.
Thoughts?
invisage is offline   Reply With Quote
Old 08-07-2013, 09:59 AM   #822
brillo
Drives: 2013 Firestorm FR-S
Edmunds has their track test up for the innovate kit. pretty impressive when you realize their launch was ~2,800rpm and they can't hit 60 in 2nd gear.
The kit makes the car do easy low 6 sec 0-60s and I bet a good driver with a more aggressive launch and a rev limiter increase could be in the low 5s.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
mines13 (08-07-2013)
Old 08-07-2013, 10:01 AM   #823
xjohnx
Grip>Slip
xjohnx's Avatar
For those that are interested (and lazy): http://www.edmunds.com/car-reviews/t...ck-tested.html
swift996 (08-07-2013)
Old 08-07-2013, 10:05 AM   #824
MattF
MattF's Avatar
Thoughts?
I don't buy the explanation that the exhaust is causing the bottle neck and causing the boost to creep up. The reason being is that innovate tested and tuned there car with everything completely stock other then the blower. So if the exhaust was causing the boost to creep to 10PSI I think they would have mentioned that maybe?
I think it has more to do with the valve overlap/timming on the tune could be causing the boost to creep up. Don't get me wrong I completely agree that a restrictive exhaust can cause boost to creep up on a supercharged car. I just don't that is the case with our cars.
Old 08-07-2013, 10:16 AM   #825
phloozy
phloozy's Avatar
Drives: Scion FR-S
I read through just about this entire thread but couldnt find to much on everyone's impressions of the SC. I will be going FI soon and have been closely looking at the innovate SC. I have had turbo cars but I am new to adding FI to an NA car so just seeing these numbers doesnt help me get a feel for how it transforms the car.
So my question to you guys is this awesome innovate club is what is driving the twins like after adding the SC? Is it a rush of power to the small car? Or would you say the gains are just enough to make it a slightly more enjoyable car?
phloozy is offline   Reply With Quote
Old 08-07-2013, 10:25 AM   #826
canu_50
canu_50's Avatar
Drives: Scion fr-s
Mexico is getting pretty big!!! we are always there when snow comes around for some heavy drifting night!!!
canu_50 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
